Any autostart extractor that fits "Eurostandard" 36 or 50mm hose fittings will satisfy your requirements. As you'll be installing it as a dedicated SCMS extractor, you won't be requiring such niceties as a variable speed setting, portability (wheels), wet & dry pickup, HazMat certification etc.
Just about anything from the Festool/Kraenzle range will work well, as will any of the autostart ranges from the "big 2" Euro manufacturers Starmix or Nilfisk/Alto/Wap. The latter 2 specialist manufacturers market rebadged versions of the best of their own ranges to other large tool manufacturers such as Bosch, Eibenstock, Mafell, Metabo, etc. Yet prices can vary wildly, even with 100% parts compatibility. Meaning that maybe the cost of consumables (filters & bags) should also be considered.
Only Festool (I think) offer an OEM Longlife bag option, although for such a low-volume task it may not actually be financially viable. You really only need a compact HPLV vac with autostart. Anything with a minimum of 1 Kw power should suffice. Anything over 1.4, or even 1.2 Kw is probably unnecessary.
There's also quite a few East Asia sourced cheapies available these days that offer autostart functionality at a fraction of the price of fancier machines. In a dedicated installation, just about any half-decent vac can be easily & inexpensively adapted to Eurostandard hose fittings.
