Snip.The second the saw starts to need any effort to push it - in goes a wedge.
I've never used a track saw or circular saw on anything other than ply sheets. How do you wedge during a cut? Do you stop the saw and put the wedge in the open end, or put the wedge right behind the saw from the top surface while still ripping?
It's pretty simple, Chuck. Keep the saw moving (even if you have to slow it right down) - because if you stop cutting, the chances are that when you stop the saw, remove the blade from the cut, move it back a few inches, then re-plunge - the tiniest, fractional movement or deviation will become visible on the cut edge. I cut my own wedges from oak offcuts, but there are also plastic ones commercially available. They need to be around 3" long x a
minimum of 3/4" wide (wider is better if you have the material available), and taper from zero to around 1/2" thick - so we're talking longish, thin wedges. If you make them too thick, the wedge angle will be too steep and you'll only be able to get the very tip of it into the kerf - the objective is to have something which you can pop right in there quickly and easily, opening up the kerf with the smallest downwards push of the wedge - and yes, you put them in from the top, behind the saw. I’ve prepared a full photographic construction plan for you down below
![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
What I usually do is to scatter a bunch of them on the bench at regular intervals so you always have one close at hand. The number of wedges you'll need to use is determined solely by the tendency of the timber to close up on you, and how long your cut's going to be. I've cut boards where it was closing up after a foot of cut. As I said - you can feel this happening as well as seeing it. So as you move along, keep your eye on the kerf and just feel how the saw moves. As soon as you see any movement on the kerf, or you feel the saw starting to struggle or bind - pop in a wedge 6" behind the saw, press it down into the kerf until you see that it's opened up the cut line again - and keep sawing. The objective of using 3" wedges which taper from zero to 1/2" is that just a small downwards wedge press is enough to open the kerf up nicely (and we're only talking 2.2mm or 1.8mm on TS55's), so it's super-easy to do.
Then just keep repeating the process if necessary as you move along the cut. If it's a horrible, difficult piece of material, you might end up putting a dozen wedges in on a long cut. Hope that helps !!
Kevin
