Author Topic: Angle grinder AGC for stainless steel  (Read 415 times)
Offline PreferrablyWood
« on: September 13, 2020, 03:17 PM »
I will be doing some work with stainless steel. I would like to hear if anyone has used the Festool AGC angle grinder for this application.
From what I understand it's best with a lower speed threshold than the AGC offers but maybe it will do fine if you work slowly or take multiple passes.
The the alternative I'm looking at is a metabo WEV 17-125 QUICK INOX that is specifically designed for working with stainless steel.
thanks for any help in advance.
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Peter_C
Re: Angle grinder AGC for stainless steel
« Reply #1 on: September 13, 2020, 03:49 PM »
I just use a regular 4 1/2" grinder for stainless work *shrugs* Cuts, grinds, and works just fine with a flap disk. The Festool grinder sure would be nice though!
« Reply #2 on: September 13, 2020, 04:40 PM »
Both Fein & Metabo make several 5" grinders specifically for stainless work. All the stainless models are variable speed and the max speed is also lower than a traditional 5" grinder to prevent burning the stainless. A conventional 5" grinder runs 11,000-13,000 rpm while the stainless specific grinders stay within the 7,500-8,000 range.
The AGC is variable speed so you can throttle it down a bit. According to Festool, setting #4 is 6,900 and setting #5 is 7,700 so that puts you in the correct speed range.
Both the Fein & Metabo can go down to 2,000-2,500 rpm while the AGC will only go down to 4,500 rpm. However, I don't think that that will be a problem because I doubt you'd need to go that slow.
« Last Edit: September 13, 2020, 04:43 PM by Cheese »
Offline RJNeal
« Reply #3 on: September 13, 2020, 05:30 PM »
@PreferrablyWood, just a reminder , when working with stainless, remember not to slow the grinding wheel down on ferrous metal like a bench. It will contaminate the wheel and transfer to your work there after, allowing rust to set in later.
Offline rvieceli
« Reply #4 on: September 13, 2020, 10:13 PM »
Metabo makes a great grinder. I do not think you would be disappointed in their offering.
I have this one and it is smoother than all my other grinders.
METABO W 9-115 QUICK
https://bismetabo.com/sample-metabo-category/cutting-sanding-milling/angle-grinder/600371420-metabo-w-9-115-quick-4-5in-angle-grinder-10-500-rpm-8-5-amp-w-lock-on.html
As my others die I'm planning on replacing them with Metabo. And yes I have multiple grinders as I hate switching disks in the middle of a process.  [wink]
Ron
« Last Edit: September 13, 2020, 10:15 PM by rvieceli »
Offline Peter_C
« Reply #5 on: September 14, 2020, 12:38 AM »
Does the new Festool grinder have a brake on it? I bought a Milwaukee grinder due to the fact it has a brake on it. Going forward I will only buy grinders that have a brake on them for the added safety from "the spinning wheel of death".
So what does Festool mean by this below as it isn't clear? You would think a braking motor would be in the top of features list, if it had it, but I read and searched the instruction sheet and found "brake" was not used a single time.
"Soft start-up, electronic overload protection, motor brake and restart protection"
https://www.festoolusa.com/products/cutting/cordless-angle-grinder/575348---agc-18-125-li-eb-basicus#TechnicalData
« Reply #6 on: September 14, 2020, 03:35 PM »
I also read the manual and as you've pointed out, a motor brake is never mentioned.
I did however come across these 3 items:
Recoil protection:
In the event of a sudden speed reduction, e.g. if the power tool becomes jammed in a separat­ing cut, the motor is switched off immediately.  To put the power tool back into operation, it must first be switched off and then on again.
After machining metal:
Blow out the inside of the power tool through the vents using dry, oil-free compressed air. Otherwise, conductive dust deposits may build up in­side the power tool. This can cause a short- circuit.
Do not use this power tool for polishing or sand­ing surfaces using diamond discs or for appli­cations involving diamond or hard ceramic discs.
