Author Topic: An early Festool tracksaw  (Read 786 times)
Offline derekcohen
    • In The Woodshop
« on: October 15, 2022, 10:52 AM »
Fairly recently, I picked up a Festool tracksaw which I consider to be something of a bargain. Others here might think of it as a novelty.
Those familiar with my work would recognise me as primarily having a preference for hand tools, although I have a very well kitted workshop with higher end machines. There really has not been the necessity for a tracksaw, and indeed my small double garage/workshop does not spare the space for a tracksaw-friendly bench. Part of the reason for the tracksaw is that I can see occasions when it would be the preferred tool over a Hammer K3 slider, such as trimming ends of house doors, cutting large panels, and bevelling panels. Part of the reason, also, is that I am a tool junkie, and was curious to see what the fuss is about.
I decided to build a small bench, which could also house the systainers which have been slowly appearing. This is 1200mm long x 600mm wide. Also, while one of the systainers contains a Domino DF500, all joints here were full-on mortice and tenon. I believe they will resist movement better than a domino.
Peel off the 1/2” black rubber pad (great for glue ups), and there is a 1” thick foam for cutting ..
Underneath this is a wooden bench top …
It’s not going to replace my workbench … :)
On to the tracksaw. It is a AT 65 E, and likely dates back about 18 years ..
Now I don’t mind old power tools, if they are quality tools. I have a few Festo sanders (which became Festool) and 4 Elu routers. But the thing about this tracksaw was that it was essentially new. And very cheap.
Open up the steel body and it is spotless …
These teeth have hardly cut anything …
48 teeth should be good for crosscutting ..
I made a dust cover …
In a separate thread I asked about the best length track for my purpose - noting that I only work with solid wood, and do not cut up sheetgoods. I was thinking the 1080mm but it appears that this may be too short for 800mm wide doors. I have a 1400 Makita, which is cut into 800 + 600. A test with the 800 quickly revealed that this may only do a 550mm length. A little more testing to do.
« Last Edit: October 16, 2022, 08:08 AM by derekcohen »
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline Crazyraceguy
Re: An early Festool tracksaw
« Reply #1 on: October 15, 2022, 03:31 PM »
That thing looks virtually new, like somebody bought it for one job and has been stored ever since.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Jim_in_PA
« Reply #2 on: October 15, 2022, 08:08 PM »
Wow...talk about pristine!!! That's quite a find! Congratulations, Derek!
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax SC3C, FS350, MM16, Camaster Stinger II SR-44 CNC
« Reply #3 on: October 15, 2022, 10:39 PM »
Ya that saw’s pretty nice Derek…I have a hunch that there are a lot of these Festool’s out there that have minimal to zero road time on them…simply collecting nice tools has been a popular enterprise for the last 20+ years. Before that, not so much…that disposable income thing.
