I need to work out of a temporary shop that need to be cleaned and ready for others to use when I am done. It is thus critical that I can pack stuff up and put it into storage and that the transition time is as low as possible. I never need to lift stuff, so not that type of mobile, on wheels and compact is good enough.
So far I have two MFTCs, one in the traditional setup and one with a KS60 mounted on top. I thought that was what I needed, but I constantly struggle with two things: thin rips, especially when I want to sneak up to something and getting proper miters (there is always a bit of flex in a miter saw). Already fairly kitted so the cutting station of the MFTC works nicely together with parallel guides. I have never considered the CS50, but after I realized it has a slider functionality it looks like it could replace my KS60 altogether with additional benefits of enabling thin rips etc. I believe I just will modify the MFTC that houses the KS60 and that should be good to go. Also, the KS60 on top of the MFTC was always a bit of a compromise. Should also be possible to house some accessories on that setup.
In that context I am a bit torn with respect to accessories. If I just look at the needs I have and what I think I need I think that I really do not need more than the base floor unit, maybe also the outfeed extension, in addition to a extendable side extension (like you have on the miter saws) with a flip stop (which one is this by the way? the one for the KS120?). What do you think about going this route and would it be stupid not going for more of the accessories? There is the set, but maybe there is not so much to be saved and a fair bit of money. Since I already have the MFTC setup and plan on matching the heights I am not sure that I even need the length/outfeed extension. Also less clutter on the MFTC would be great. Maybe the extra fence is nice with less flex, but I have heard the standard one is good enough. What do you think? Would the CS50 be a good replacement for the KS60?
Thanks a lot for comments or suggestions.
