Author Topic: A piece of Clear White Pine is kicking my butt  (Read 3025 times)
« on: October 29, 2014, 12:48 PM »
Greetings,
I was hoping my first significant post would be the home improvement project I am ever closer to completing, but alas no.
I have been using my RO 150 for about a year now, I had really thought I picked up the skills to use it. I sanded to finish about 1200 board feet of 4/4 African Mahogany with nary an issue.
I need to match some pine window trim with a new apron. Picked up a piece of 1X6X8' CWP at my longtime lumber yard. Pretty flat no appreciable cupping. Started sanding in Rotex mode with 120 grit Rubin2.  I was getting sweep marks. Switched to Random Orbit, getting pigtails. Surface jointed the face and started over with 180 Rubin2 same result. CT is set at about a third. I have refaced and sanded this piece of wood so much over the last three days  that is now approaching a 1/2" and I will need to pick up another piece. I even did 220 Brilliant in Rotex with smaller sweep marks. I  am real close to driving the 45 minutes to pick up an ETS150/3.
I really can't go much finer than 180 otherwise I am burnishing too much and the stain match is terrible.
So what do you think? I have completely lost the knack? There is something mechanically amiss  with the RO? CWP is the only species of wood that Festool cannot be use on? Any thoughts would be appreciated.
Marvin
Offline SRSemenza
Re: A piece of Clear White Pine is kicking my butt
« Reply #1 on: October 29, 2014, 04:11 PM »
Have you checked the abrasive for residue build up from the pine?
Offline truck90278
« Reply #2 on: October 29, 2014, 05:44 PM »
I did not notice any reference to the use of dust extraction.  Assuming you are using dust extraction, I would recommend turning down the vacuum to about 1/3rd - assuming you are running it at full power.
CT22, CT26, Midi, TS55, MFT3 x 2, Domino 500, DTS 400, RO 125, RO 90, ETS 125, OF1010, CXS, Boom arm, Trion, parallel guides, LR32 system, shop cleaning set, T-18 +3, Kapex
Offline carlb40
  • Site carpenter
« Reply #3 on: October 29, 2014, 05:48 PM »
2nd paragraph 3rd line.  [wink]
Carl
Never never go, never never know [smile]
Flickr
« Reply #4 on: October 29, 2014, 06:07 PM »
That was one of my first thoughts, I was switching paper. Just for jollies, I grab a piece of the African Mahagony and took to a swirl free a swirl free finish. So I grabbed a long board and "faired" the pine out and stained it. I did drive in an picked up an ETS 150/3, just because.  So it appears the correct answer is that Festool equipment shouldn't be used on CWP.  ;D thanks for the responses.
Offline JCLP
« Reply #5 on: October 29, 2014, 09:38 PM »
I have use the ets125 and the dts400 for a few years now on may types of wood including CWP and have had excellent results. I have stopped using rubin paper and gone exclusively with granat paper. Will never go to anything else. Paper is second to none. I have contemplated buying the rotex but have not purchased one yet due to many comments on how aggressive the sander is, even in random orbit mode. I think I will invest in t he ets150/3 so I can do large surfaces quicker.
Offline PreferrablyWood
« Reply #6 on: October 30, 2014, 12:57 AM »
I have the Festool RS 300 EQ,NAINA  it is an orbital sander with 93x178mm pad, it is built like a tank, and not being RO won't be leaving me swirls or pigtails on any surface, I think if I still find it lacking I'll go with the new lowprofile ETS EC 150/3 fiinish sander.
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Worm Drive
« Reply #7 on: October 31, 2014, 10:40 AM »
It seems that the softer the wood, the harder it is to get a good finsh sanding with a r.o. sander. Try these things. Clamp the wood down, when possible. Start sanding with the finest grit possible. Wipe or vacuum off the work piece between grits. Whatever grit you finish power sanding with, do a final hand sanding with the same grit.
Offline roblg3
  • Transforming into a whole new machine
« Reply #8 on: October 31, 2014, 05:00 PM »
How I choose my "aggression" setting.
1 Am I leveling? yes Rotex.
2 is this surface prep? yes Random orbit
There's really no reason to go rotex if you are doing surface prep only.  It's just making swirl marks for no reason.  "We" sand wood to flatten and smooth it.  Flattening is the first step.  That is rotex.  the rest is just sanding out the swirl marks from the previous grit.
Rob Gardner
Operator
RL3 Enterprises
