Author Topic: 36mm hose, 50mm pipes??  (Read 376 times)
Offline sanjay
« on: October 12, 2021, 10:41 AM »
This may well be a silly thing to do, but I have found myself with 36mm hose and the 50mm vac pipes and industrial floor cleaner.  Is there a an adapter from the 36mm hose to the 50mm pipes (440412).  can i use the Festool Hose reducer D50/D36 CT Non-AS (452897), to do this, just use it the other way around?
Offline Peter_C
Re: 36mm hose, 50mm pipes??
« Reply #1 on: October 12, 2021, 12:24 PM »
Just use a "shop vac" hose for cleanups with your 50mm extension tubes and floor nozzle. Or sell them and get 36mm attachments. Necking down into a 50mm tube is going to kill suction.
Edit: https://www.amazon.com/WORKSHOP-Wet-Dry-Accessories-WS25022A/dp/B019C23JIQ/ref=sr_1_20?dchild=1&keywords=2+1%2F2%22+hose&qid=1634055998&s=hi&sr=1-20
« Last Edit: October 12, 2021, 12:30 PM by Peter_C »
Offline Coen
« Reply #2 on: October 13, 2021, 01:35 PM »
That's just a recipe for having blockages. Use the D36 pipes if you have a D36 hose.
Same applies to D27 hose with D36 pipes; plenty of blockages where the pipes end and the hose begins.
Offline rst
« Reply #3 on: October 13, 2021, 05:59 PM »
I use 50mm hoses for cleanup, sometimes with three sections 0f hose to clean my deck and shop and on my tablesaw...suction loss is not noticeable.
