Author Topic: 20mm Router Bits  (Read 42855 times)
Offline Eoghan Brown
20mm Router Bits
« on: February 08, 2013, 09:04 AM »
Looking for a 20mm router bit for a MFT project. Search found products from CMT and Festool but, looking for distributors of this product. Any Ideas?
TS55, CT36, Rotex 90 & 150, LR32, OF1400, Domino 500, MFX700, MFT.
30 years residential construction, 25 years of residential deconstruction, Professional Fire Service.
Online Peter Halle
Re: 20mm Router Bits
« Reply #1 on: February 08, 2013, 09:37 AM »
Welcome to the FOG!  You should be able to get the Festool bit thru any Festool dealer.  The  (  Festool USA Website has a dealer locator function.  Additionally there are numerous internet dealers, some of which participate here.  If you scroll down to the bottom of the FOG home page and see a name in blue then you usually will have found a dealer.
Offline Tom Bellemare
  • Inactive Member
« Reply #2 on: February 08, 2013, 10:08 AM »
I think you want Festool 491072.
Offline mparka
« Reply #3 on: February 08, 2013, 03:29 PM »
I ordered the Festool 20mm bit from Uncle Bob and received it a few hours ago. It looks more like a fostner bit than a router bit.  It really is designed for boring out a clean 20mm hole..
« Reply #4 on: February 08, 2013, 06:18 PM »
Thank you all.
Offline fritter63
« Reply #5 on: February 08, 2013, 08:48 PM »
Here's one of my new box beams made with the festool 20 mm bit (and lots of 4 mm dominoes!)
Offline thebicyclecafe
  • Woodworking in California!
    • Sheen Woodshop - Woodworking with Festool
« Reply #6 on: February 09, 2013, 03:18 AM »
Hey Eoghan,
 Either of these ought to work, if you're just looking for a straight bit, 1/4" shank only though...:
http://www.amazon.com/Freud-04-552-Diameter-4-Inch-Straight/dp/B000P18UNS/
http://www.amazon.com/CMT-811-200-11-Double-Straight-2-Inch/dp/B001NI6PGQ/
I've used the CMT before, it's a good bit.
My first woodworking experience was as a Cro-Magnon. As a six year old, I took silver maple branches, stripped the bark, and washed the sap off the branches. While they were still wet, I would bend them into the shape of a bow, tie them in place, and air dried them for a few days. Then, with my newly made arsenal, I launched homemade arrows at squirrels with miserable accuracy.
Offline hrrb
« Reply #7 on: February 09, 2013, 05:59 AM »
I'd go for Tom's suggestion too...or this one from CMT, part no. 392.200.11
82165-0
Kind regards
Henrik
Offline fritter63
« Reply #8 on: February 14, 2013, 12:40 AM »
Hey Eoghan,
I have to disagree. Pls see my thread comparing the two types of bits. That straight bit ain't for plunging.
Offline Jmaichel
    • Weekend Warrior Woodworking Magazine
« Reply #9 on: February 14, 2013, 01:47 AM »
I really like those box beams. Did you cover them anywhere else in the forum or this there first appearance?
James
TS-75, MFT/3, OF 1400, ETS 150, CT 26, CXS, Guide Rails, Clamps and a few other accessories.
« Reply #10 on: February 14, 2013, 09:26 AM »
(Attachment Link)
Kind regards
Henrik
Another view
Looks a lot like the Festool bit. The little perimeter scoring points are the key to a good cut.
.Less than $30 here.
Offline fastbike
« Reply #11 on: February 14, 2013, 10:54 AM »
Is the 10mm shaft going to fit in the US OF1400?
I was so much older then, I'm younger than that now.
Offline moody
« Reply #12 on: February 14, 2013, 12:29 PM »
Is it really wise to use a forstner bit in a plunge router? I would think the rotation speed of the router is much to high for a forstner bit?
« Reply #13 on: February 14, 2013, 12:42 PM »
Oops you're right, I stand corrected. It's a fine straight bit of course, the profile isn't that good for plunging those holes the OP wanted. Good catch!
Hey Eoghan,
  • Inactive Member
« Reply #14 on: February 14, 2013, 12:44 PM »
Those CMT bits are meant for boring machines.
Quote
The Festool bit I mentioned and the CMT bit that Michael linked to are both hinge boring bits. The Festool bit is for routers and has an 8 mm shaft. The CMT bit is meant for boring machines and has a 10 mm shaft.
« Reply #15 on: February 14, 2013, 01:09 PM »
Oops... the 10mm shaft spec slipped by me.
I don't have that CMT bit but I do have the Festool bit and while it does bore a clean hole quickly the hole is about .2mm oversize so things like Qwas dogs fit a little loose. But, it's made for drilling holes that cast hardware will be inserted into and for for that purpose slightly over-sized is a good thing.
Offline hrrb
« Reply #16 on: February 14, 2013, 06:26 PM »
Quote
Well...please notice that Michael and I are not referring to the same CMT part no. The one I'm referring to is a drill/router bit, part no. 392.200.11. According to the CMT catalogue I'm holding in my hand it's a boring bit for hand held drills AND ROUTERS and the shaft is 8 mm.
But it is correct, that Michael is referring to a boring bit part no. 317.200.11
...well according to his link it's a boring bit. But apart from the shaft diameter I don't know the difference.
But I can tell you that I have a lot of both Festool an CMT bits and I consider CMT to be high quality bits.
Kind regards
Henrik
« Reply #17 on: February 14, 2013, 10:34 PM »
Henrik,
I searched the 392.200.11 number and only came up with the boring bit (if I remember correctly).
Tom is a CMT dealer, I wonder if he can get the 392 router bit and how the price compares to the Festool bit.
Offline hrrb
« Reply #18 on: February 15, 2013, 12:44 AM »
Henrik,
...here's a snapshot from an online catalogue.
82576-0
But I don't know if it's available in NA. Maybe Tom can answer.  ???
Kind regards
Henrik
  • Inactive Member
« Reply #19 on: February 15, 2013, 01:19 PM »
The 392 series bits are NAINA. CMT doesn't offer 8 mm shaft bits here normally.
Offline fritter63
« Reply #20 on: February 15, 2013, 09:01 PM »
James
I showed a pic or two my thread about comparing the 20 mm straight bit with the festool bit. Search for "20mm" may be a space in there). On my iPhone right now.
I didn't think there was much interest in a build thread but I can post one if you want.
« Reply #21 on: February 20, 2013, 08:22 PM »
Thanks All,
I am planning on building one of Ron Paulks work benches. Now that I have this last piece of the puzzle. If the weather holds out I'll start cracking at it.
Eoghan
Offline bwiele
« Reply #22 on: February 20, 2013, 09:05 PM »
Sorry for being naive, but what generally are those box beams used for?
Offline fritter63
« Reply #23 on: February 20, 2013, 10:04 PM »
They're my workbench. Think of it as an MFT/3 that can split in the middle.
Here is another pick of them in use making a 4 foot wide garden gate:
Offline fritter63
« Reply #24 on: February 20, 2013, 10:06 PM »
Better pic:
Offline Wooden Skye
« Reply #25 on: February 20, 2013, 11:09 PM »
Fritter63
Are your beams torsion box?  It is one of the options I am thinking about as an assembly table.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino ETS 150/3, RO 90, CT 26, OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline fritter63
« Reply #26 on: February 20, 2013, 11:17 PM »
Fritter63
Almost. I left the bottom skin off so I can  secure the clamping elements from underneath. They will twist a little if unsupported:
Offline Pizza Steve
« Reply #27 on: December 20, 2014, 09:19 PM »
I realize this thread is a bit old, but I have the same question: as Michael stated above, if the Festool 491072 produces a larger hole (.2mm) than the standard MFT holes, is there an undersized 20mm bit that produces the same MFT-sized holes?
Or is this something only a CNC machine can cut?
Thanks!
Steve
Offline Pizza Steve
« Reply #28 on: December 20, 2014, 09:23 PM »
Also, I don't know if CMT's distribution model has changed in the past 18 months, but the CMT 392.200.11 is now available in NA directly thru Amazon: http://amzn.com/B00EV52X64.
Offline JBird
« Reply #29 on: January 24, 2015, 03:44 PM »
Did you ever find a 20mm bit that drills a more proper 20mm hole? Did you try the CMT you linked to?
