Author Topic: Vacuum question.  (Read 726 times)
Offline Lbob131
Vacuum question.
« on: June 06, 2021, 02:01 PM »
I currently have  the CTL 26 E AC  for  some  time  now.
I might   try  the machine  with   cement  board  dust  when  routing.
Can I  retain  the use  of  the  long  life  filter  bag  (the  one  with the plastic strip sealing  the end)  in combination  with  the CT pre-separator CT-VA-20?
Or  will  the fine  dust  not  collected  in  the  pre  collector  still  block  the  bag  leaving  me  with no suction power?
And  a question to those  of you  using  the plastic  liner, do you  empty  it  and  re- use  or  just  chuck  the lot in a  skip?
« Last Edit: June 06, 2021, 02:04 PM by Lbob131 »
Offline guybo
Re: Vacuum question.
« Reply #1 on: June 06, 2021, 03:41 PM »
Hi, I don't see the advantage of the ct va 20 with the ac machines with cement or drywall dust,we use the liners,we for a while were worried about supply,but it was and still is messy same with ctva 20 liners or tubs, good luck guy
