Author Topic: TS75 questions  (Read 5373 times)
Offline spidennis
TS75 questions
« on: October 16, 2016, 03:02 PM »
I have numerous questions on the TS75.
I plan on using this for 3/4" plywood on a cut table I made.
I also want to use it for straightening up an edge on rough lumber up to 14' long, maybe longer later..
What is the max cut depth while on the track?
Will the track for the 75 work with the 55 (later) and routers?
Are there other manufactures for the blade?
I make wood strip canoes (a variation of it anyway) and I think this could do a lot for me.
Offline KescoNY
Re: TS75 questions
« Reply #1 on: October 16, 2016, 03:10 PM »
Simply.....
Cut depth is 2 15/16" on the rail
All the guide rails are the same with the exception of the HK rail.
There are few other blade manufacturers.
Usually not a good idea to switch saws on the same track due to the splinter guard but if you happen to have the TS55 & TS75, you can adjust the blade so they both cut on the exact location on the splinter guard.
Kapex/UG Cart/UG extensions TXS Set CXS Set PDC 18/4+3 BHC18 T18+3 Centrotec Installer's Set TS 75 TS55 TSC 55  Carvex PSC Carvex 420 & Accessory Kit  Domino 500 Set  Domino 700 set OF1010 OF 1400 OF 2200 & Accessory Kit  LR 32 Rotex 90 Rotex 150 Rotex 125  ETS-EC 150 ETS-EC 125 ETS 150 ETS 125 DTS 400 RTS 400  CT Midi CT36AC CT48 w/boom MFT3 CMS GE set with TS75, TS55, OF1400 plate  CMS VL
Offline Holmz
Re: TS75 questions
« Reply #2 on: October 16, 2016, 04:42 PM »
3/4" is about 19-mm
A TS-55 cuts to a depth of 55-mm, and a TS-75 cuts to a depth of 75-mm.
What do you use for the canoes now?
Offline Jeff Zanin
Re: TS75 questions
« Reply #3 on: October 16, 2016, 06:57 PM »
I did the Farm Table class at Gregory Paolini Design a few months ago (highly recommended).
This class included using the TS75 to prepare rough lumber for gluing up the top.  I have the TS-75 but mostly use it with sheet goods, so I thought they were kidding when they said the TS-75 was all that was needed – no jointing or other stock preparation.
It worked remarkably well and I suspect it would be much easier than handling a long piece over a jointer.
Offline RobBob
Re: TS75 questions
« Reply #4 on: October 16, 2016, 07:01 PM »
I have used my TS75 for edge jointing heart pine.  After glue up you cannot tell where the seam is.  No jointer was used.  Worked great.
The blade that comes with the TS75 is a general use blade which will probably be good for ripping.  Do some test cuts to see if it gives the results you are looking for.  You may need a different blade.  Festoolproducts.com sells blades from other manufacturers that will fit the TS75.
« Last Edit: October 16, 2016, 09:05 PM by RobBob »
Offline Kodi Crescent
Re: TS75 questions
« Reply #5 on: October 19, 2016, 08:38 PM »
Simply.....
Have you ever tried this?  What success have you had?  I tried and tried, and eventually gave up as I couldn't get them to match on the same splinter guard.  The TS75 is unused, as I don't want to buy dedicated rails or replace splinter guards between saw uses.
The 55 is a much easier to handle saw, for what it's worth.
Offline KescoNY
Re: TS75 questions
« Reply #6 on: October 19, 2016, 08:45 PM »
Simply.....
I actually spent a day in the shop to get all my saws (2 HKC 55s, TS75, TSC55, TS55) to use all my rails because i got tired of getting rails mixed with saws since i have multi users.
It was a very aggravating task and ruined a couple splinter guards in the process but i was able to get them very close.
If you are the only user and have enough rails, i would leave it alone
Offline bkharman
Re: TS75 questions
« Reply #7 on: October 19, 2016, 10:08 PM »
Simply.....
Or put the 75 into a CMS and move on... IF you are not in NA.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Re: TS75 questions
« Reply #8 on: October 20, 2016, 07:55 AM »
Simply.....
Thanks for that.  I spent days just trying between 2 saws.  I was only able to get it "very close".  For me it wasn't worth the effort.
Offline tjbnwi
  • Cedar Tucky Indiana
Re: TS75 questions
« Reply #9 on: October 20, 2016, 09:48 AM »
Simply.....
I have 4 TS saws, they all match. If I ever get an HK, I'll match it to the other saws.
http://festoolownersgroup.com/festool-how-to/ts-55-req-ts-75-calibration/msg449496/#msg449496
http://festoolownersgroup.com/ask-festool/ts-75-toe-in-tolerance/msg442074/#msg442074
Re: TS75 questions
« Reply #10 on: October 25, 2016, 07:55 AM »
@tjbnwi
Thanks Tom.  You mention the 55R.  Does the older 55 have the same amount of adjustment as the 55R?  I did not use a jig (I wasn't that smart  [sad]).
I'm continually amazed at the innovative things you come up with!
Offline tjbnwi
Re: TS75 questions
« Reply #11 on: October 25, 2016, 10:30 AM »
@tjbnwi
The R model has about 1/2-2/3 the adjustment as the E model (never measured the difference, kinda guessing on this). That is why the R was my baseline.
If I ever get an HK, I'll find out how that adjustment is.
