Hello my name is R.B. and I'm addicted to expensive German power tools. I'm a residential homebuilder and use tools at work occasionally but my job mostly involves project management opposed to the hands on stuff. I mostly use my Festool power tools on personal remodeling projects and weekend woodworking builds. I began my Festool journey about 2 years ago with a Ro 125 and CT 26 and my collection has grown considerably since then. I have since added a TS 55 with two guide rails, C12 Drill (old model), RS400, OF 1010, CXS, and plenty of accessories along the way.
Over the past two months I've added the RO 90 dx, Syslite, and Trion barrel grip jigsaw to my collection. I've used them here and there at work but I had a chance to use all of these tools on a weekend outdoor chair build last weekend. These new tools were actually essential to the construction of the outdoor chair with narrow curved pieces. Here's a quick breakdown on my impressions on each tools, what they allowed me to accomplish, and what I've found to be faults in the tools.
Trion Jigsaw
Some love it, some hate it. Everyone seems to agree it has faults. This tool has been around for awhile and has had many reviews but I will throw in my two cents. I do not have any true stationary tools as my work either takes place on a jobsite or a functioning home garage. I have never been able to purchase a bandsaw due to this. I did not want to buy a portable benchtop model i would not be happy with. In the past I have used a Dewalt and Bosch jigsaw and the blade seemed to drift on both. Not with the Trion, once adjusted properly it can cut perfectly square, really! It would be silly for me to say this tool is as accurate as a bandsaw, but it does allow me to cut more precise curves in thin and thick stock. The blade stays so true that you can even take a blades width off or even less from a board if using a straight edge! For a Jigsaw, this amazed me.
Dust collection was a positive and a negative for me. One of the reasons for buying this saw along with other Festools is the dust collection. It works great on this saw and kept my garage clean while cutting out curved chair legs from thick stock. Now the negatives, the dust collection as covered before severely limits visibility and makes it hard to see blade. When you throw on the zero clearance piece, forget about being able to see the thing at all! I have found a way to help deal with this and will explain later. The dust collection also makes the jigsaw very difficult to maneuver when attached to an extractor. I found myself constantly fighting the house. I think it would very wise if festool invented some type of adjustable or even 90 degree angle attachment for the house to tool connection. Overall I love the dust collection and will look past its flaws because it does such a great job!
RO 90 DX
Great tool. Everything said about its capabilities is true. It excels at hogging off material, detail sanding, and even fine sanding. This sander was the only one I used on the curved chair project from shaping and cleaning up legs to finish sanding. The ro 90 tackled it all. It was perfect for all the narrow components using the hard pad. When used with the interface pad it provided great results following the contours of the curves on the piece.
The negative on this tool is the ergonomics are horrendous, especially when trying to finish sand a narrow piece. It is very hard to keep the pad at a right angle to the piece one handed while holding the piece with the other. I will have to find some sort of fast clamping option to help with this. It seems like Festools designers just built all the functions into the unit and then tried to worry about ergonomics. The ro 125 is also very poor in this regard but the ro 90's problems are amplified due to the narrow pad.
Overall I am very pleased with this sander and find myself using it as my go to for narrow pieces.
Syslite
I love my new Syslite. Use it at work to illuminate attics, crawlspaces, and other poorly lit areas. I also use it as a tool to help inspect drywall and paint jobs. During this weekend project I found it was perfect to hang from my overhead door track and provide extra light wherever I need it while working on a woodworking project. I keep it plugged in pointed down on my work bench the majority of the time, when I move to my table/miter saw, I simply twist the light in the direction I am working. One of the most useful things I use this light for is to help illuminate the hard to see blade on my Trion Jigsaw. I simply place the light on my work bench facing me and the way I am cutting and it helps, a little (that blade is just not easy to track when cutting curves with the dust attachment!). I have not used it with my C12 batteries but I am glad I have that option.
The only negative I could find on this light is it is not bright enough to illuminate a large area from a distance. The light is very intense within a couple yards but anything over that the light is not very bright. I wish it had an option to go brighter possibly only once attached to a wall outlet. Another suggestion that makes since to me is to have the hook on the unit lock into different angles so you can better point the light down on your work surface.
Overall this is one of my favorite Festool products purchased. It will help out with task lighting at work and I plan on using it every time I work in my garage after dark for supplementary light. I just hope the LED's and battery can handle the constant use.
In Review
I love my new Festools and would not regret buying any of them. Also if anyone is interested in purchasing a barely used, year old Bosch Barrel handle jigsaw with added dust collection attachment PM me. Can email pictures. Its yours for $100 shipping included (US Only)
