Sorry your having trouble so far mine is perfect.
That is actually what is so troubling about this. Some of the machines seem to be perfectly fine, and that is how I like mine to be as well.
My PS300 for instance is perfect so luckily I can exclude my handling/adjustment as being the cause of this.
Same wood, same sawblade changed over from PS300 to PS420. Conclusion: my PS420 does have a problem.
Since there are both good and bad PS420s out there, there must be some fluctuation in the manufacturing process.
For instance, I can imagine that a slight misallignment between the saw blade holder of the saw blade and the guide would cause this.
Such a misallignment would put an asymmetrical bias on the blade which initially, when you start, doesn't affect the
squareness but gradually makes the blade go sideways. Or maybe when inserting the blade by turning the blade
doesn't end up dead-on straight because the end of the turning action is not so well defined as the clamp of the PS300.
Mine seems to always deviate relative to square to the same side.
Maybe my PS300/your PS420 happens to be well alligned and the blade can go up and down without stress,
thus staying nice and square throughout the cut.
That would mean that trying several PS420s in the shop would make a lot of sense, so you pick
the one where the factory managed to allign things perfectly. The shop can then either sell the slightly less perfect
PS400/PS420 to people who don't care about cutting square or return them to Festool.
You have only just joined the FOG and you did this especially to tell us about the problems with the Carvex. Well done. If you have the 300 and the 400 why did you buy the 420? If you have had problems with the 400 why did you not ask for your money back? What was the name of the dealer in Germany and what was the name of the sales person at the shop?
Hi Peter,
I was a lurker for a long time on this forum, reading and learning.
I'm posting because I hope to contribute to a solution to the problem.
By shutting up and returning the PS420 nothing is gained.
Thank you for your interest in where I bought the PS420. The shop is Scheins in Aachen (in business since 1880 or so)
and I have been buying my tools there for the last 35 years and trust them more than anybody when it comes to tools.
All my woodworking tools are Festool and I have been buying Festool since 1995.
Maybe you missed my first message: I bought the PS420,because I don't like the PS400 and assumed that Festool fixed them in the new and improved PS420.
Blade holder didn't always retract so you couldn't eject the blade, blade would jump out of the lower guide, cutting not square, etc.
During the first 30 days I had no application PS400 where it had to cut more than 18mm plywood. Bummer.
Until the PS400 everything I bought worked as expected, no, let me correct that: better than expected.
So when I finally started using it seriously, I found out that it sucked. Too late to get your money back. Bummer.
I send it in, no improvement. Bummer.
Let's just say that with the PS400 I learned my lesson.
I didn't post back then because, given the excellence of the other Festool tools, I considered it a hick-up by Festool.
I bought one of the first PS400 available in Germany so maybe it was just that. It can happen.
Now that the PS420 is being advertised (and discussed here) as being an improved PS400 I figured I try it and this time round do the tests right away.
And now that, for the second time, they don't seem to get it right, I feel that it is time to post my opinion.
I assume that everybody on this forum (like me) is honest when stating their opinion.
It is consequentially inexplicable why the PS420s are so different.
Are the positive people just trying to promote the PS420? I assume not. I'm happy with most of my Festool so I understand that other people are as well.
Are the negative people trying to talk the PS420 down? I'm certainly not. I just have a bad saw. For me it is understandable that others may well have the same PS420 problems.
Peter, maybe we should just exchange our PS420s?
