« Reply #23 on: October 09, 2012, 06:08 PM »
If you watch (3.09) in to the video you see the carvex goes out of sink just like mine does. If Peter had at that time turned the Carvex OFF he would not of been able to remove the blade as it would of most likely of stopped in the downwards position.
If you keep watching (3.17) you can see the carvex gets its self back into sink and if Peter had finished his cut and turned the jigsaw off at that time it will stop in the upwards position. As the video goes on you can see it moves up and down slightly but not enough to drop it out of sink but almost like it wants to but on mine this happens often leaving me unable to remove the blade on a regular basis unless I use my fingers to flip the level no big deal
Just thought I would mention it as I have been asked and Pip mentioned it in another topic and Peters video shows it well.
If you look you can see a ghost affect of the blade dropping and then rising back up.
JMB
I noticed the shadow as well as was about to mention it and was happy to see you had picked up on it. Its not major but it is annoying and I have got used to such high standards with Festool that this point doesn't shine like the rest of their kit.
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, OF 2200, T15+3, CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400/2, FS 1400/2 LR32 FS2 3000, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sortainers, Sys Cart, Syslite
