« Reply #2 on: November 01, 2012, 04:41 AM »
How deep can the "trenching" go? I need to do about 25 big posts for a deck and would like to trench each post. I need at least 20mm (1inch approx) out for rails to insert into, as well as that I need to cut out a portion of each post at the bottom to bolt to the face of the deck boundary. preferably a good 30-40mm cut out would be good. Can it do this? It a pain doing this with my old circular saw and not as accurate and clean as I would like. (Thats my fault though), and chiselling takes so long on so many. If the kapex can do this I'll be very interested.
thanks
The limit is not the depth but the height, the depth stop is quite accurate but the problem is the limited height. I think you can lift the blade with the stop somewhere around 30-40mm above the cutting surface max. So if your post is like 95mm thick, then you can't take out a 20 or 40mm trench using the depth stop. Maybe there are other ways i haven't been informed of, but so far that is the one negative point of the kapex.
When trenching with the Kapex you also need to put a distancer block of at least 40-50mm wide between the fence and the workpiece because the blade doesn't slide back far enough to clear the back of the trench.
BR10, MFK 700, OS 400, ETS EC 150/3, KA 65-plus,TS55R, CT22E, CTLmini, CTL MIDI, CTM 36 AC HD, Kapex KS120, ETS125, ETS150/5, RO150, RO90, CXS-set, T-15+3 set, DTS400, OF900, OF1010, OF2200 set, Carvex PS420 EBQ set, EHL 65, SSU 200, Centrotec installer set, LR32-sys, FS-800, FS-LR-1400x2, domino 500+domino sys, domino 700 XL, Surfix-sys, Sys-box 1, Syslite, LEV-350, Sys-box,MFTB/1-2-4... MFTC, MFSC
