Author Topic: Sawstop Compact Saw  (Read 3804 times)
Offline MarcV
Sawstop Compact Saw
« on: September 16, 2022, 11:29 PM »
I just picked up the sawstop compact saw. Its basically the size of the dewalt saw with a rack and pinion also. The stand was good quality but I opted to put it on the dewalt rolling stand. For my needs this is the perfect saw. It has enough power for my needs, very accurate with the rack and pinion, and it is small enough that it can be easily put in and out of the back of my truck. I previously had the sawstop Jobsite Pro and although i think its a good saw, I didn't like the fence over the rack and pinion and It was just big enough to be a pain to move in and out of my truck. As a bonus its compact enough that it fits under a table in my garage.
Offline luvmytoolz
Re: Sawstop Compact Saw
« Reply #1 on: September 16, 2022, 11:46 PM »
I'm really curious on this one, how noisy is it as it's a brushed motor, and is the top cast iron or aluminium?
I also wonder if it is as accurate long term as a standard table saw.
Offline MarcV
« Reply #2 on: September 16, 2022, 11:56 PM »
Its about the same DB as the dewalt saw. It didn't bother me but im used to the noise of little saws with universal motors. If I was coming from a induction motor it might seem noisy. The top is aluminum. Due to the rack and pinion I am very happy with the accuracy and I sure it will stay that for a very long time. a benefit of sawstops is that they make it very easy to order parts if needed. I already order a front rail and rear rail for about $50. The rails are aluminum extrusion so with a connection piece I can make the rails longer when needed and make the saw capable of cutting up to 36" or longer, which is awesome for something so portable.
« Last Edit: September 17, 2022, 12:15 AM by MarcV »
Offline luvmytoolz
« Reply #3 on: September 17, 2022, 01:02 AM »
Man I wish they'd have released this or one like with an induction motor. They really spoil you for universal motors.
I like that the top is aluminium, from what I can tell this is sort of like a beefed up contractors saw that almost bridges the gap between that and a cabinet saw.
I'm after something exactly like this that has a small footprint, but would be accurate and repeatable enough long term like a cabinet saw to use with a sled for box making. The motor kind of kills me for it though, wouldn't be fun to use hours on end I think.
Offline Packard
« Reply #4 on: September 17, 2022, 09:45 AM »
My most used table saw accessory is a Magswitch feather board.  I use it for virtually all my rip cuts.  Before I got the Magswitch unit, I rarely used my miter slot based feather board.
An aluminum surface would be a deal killer for me.
Offline Vondawg
« Reply #5 on: September 17, 2022, 10:39 AM »
How many portable TS’s have cast iron tops ? This saw is going to be a very nice fit for many who need a compact/portable TS with the finger saving safety feature
Offline mattgam
« Reply #6 on: September 17, 2022, 01:57 PM »
@MarkV Could you explain this more?  I've got one of these on order and had no idea you could expand capacity?  Also, any chance you have the part numbers you ordered?
Offline MarcV
« Reply #7 on: September 17, 2022, 03:05 PM »
I got the idea from a instagram video I saw of someone that did this to their Dewalt tablesaw. If you look at the end of the rails you will see two opening. One of them I'm going to cut down some wood to stick in that will actually hold the weight of the rail. Then using the connector piece with screws I will connect the rails together so that they move together as one. Then you put in the screws for the fence to sit on. It should be easily removable. I will use it for making cabinets and when having a 34" rip capacity is needed. When I get everything and verify that it works I will post pictures. The connector piece might not fit but it was cheap to purchase and try. If it doesn't fit I'll figure out what does.
« Last Edit: September 17, 2022, 03:14 PM by MarcV »
Offline bobtskutter
« Reply #8 on: September 17, 2022, 03:15 PM »
I wish this was available in the UK.   [sad]
Bob
Offline Birdhunter
« Reply #9 on: September 17, 2022, 06:12 PM »
We had massive water damage to our house. The contractor did a fantastic job of rebuilding the damaged part of the house and replacing a 20’ by 8’ window. Their saw was a DeWalt contractor saw. No safety features and no dust collection. They also used a DeWalt skill saw and a DeWalt vibratory saw. Amazing skill.
Birdhunter
Offline MarcV
« Reply #10 on: September 17, 2022, 07:26 PM »
Yeah they are amazing saws. The rack and pinion keeps everything very accurate.
Offline rst
« Reply #11 on: September 17, 2022, 08:48 PM »
I have the Metabo HPT 36v table saw, it has a brushless motor and can run on batteries or the transformer that plugs.  It has a fence virtually identical to the De Walt and has the larges table and cross cutting capacity (35") of all the portables.  I put mine on the DeWalt rolling stand also.
« Reply #12 on: September 18, 2022, 09:59 AM »
I was planning on purchasing this a few days before the Sawstop CTS was announced. I’ve had great luck with my Metabo HPT tools and loved that this had the rack and pinion fence, and cordless/AC Adapter options. Unfortunately sawstop tech wins out over cordless for me.
Offline Bencan
« Reply #13 on: September 18, 2022, 07:28 PM »
How do you find the power compared to the jobsite pro? I was looking at the weight difference isn’t actually that much? I am going to buy one or the other, I’m on the tools everyday. Will the compact saw rip through 2x material easily? I’m 17 years in and the older I get the more underrated I think safety is. Maybe just getting a bit smarter as I get older maybe just more reckless with my money instead of my body
Offline ironchefboyardee
« Reply #14 on: September 19, 2022, 06:23 AM »
This is promising feedback. I had a preorder but cancelled it so I could see some reviews before buying.
Are you using the blade that came with it or something else? I would assume a thin-kerf blade is a given for this size of saw.
« Last Edit: September 19, 2022, 07:06 AM by ironchefboyardee »
Offline mattgam
« Reply #15 on: September 25, 2022, 06:58 PM »
@MarkV did you drill 4 holes in the legs to mount it to the dewalt stand?
« Reply #16 on: September 26, 2022, 06:36 PM »
@ironchefboyardee it comes with a ripping blade. I replaced mine immediately with a thin kerf Freud general purpose blade because I cut lots of plywood. Been a good saw so far, I need to build an outfeed table.
Offline jobsworth
  • Festool Baby.....
« Reply #17 on: October 02, 2022, 08:21 PM »
how is the quality of cut?
Thats a issue Ive had with small portable saws
Offline ChuckS
« Reply #18 on: October 02, 2022, 08:38 PM »
One recent review:
Online DynaGlide
« Reply #19 on: Yesterday at 10:51 AM »
I saw one at Woodcraft over the weekend. I'm not too worried about the flesh saving tech I have a very healthy fear of table saws which leads me to plan out each cut with an abundance of safety. But what did catch my eye is the sawstop has a very nice amount of infeed before the blade. It looked quite a bit longer than my Dewalt 745. Not sure if that was mentioned already.
Instagram @matts.garage
Offline woodferret
« Reply #20 on: Yesterday at 01:38 PM »
I've been waiting for someone to note that.  Thank you.  The 745's infeed is what stopped me from going for that one.  This sounds promising.
« Reply #21 on: Yesterday at 01:42 PM »
I have the Freud thin kerf general purpose blade on the SawStop CTS and cut seems as good as any jobsite saw I’ve used, it’s definitely not a cabinet saw, but it has had no issues cutting plywood, WindsorOne 3/4 trim or some 3/4 white oak I’ve cut. Mine seems equivalent to a perfectly set up perfect condition Dewalt jobsite tablesaw.
Offline JimH2
« Reply #22 on: Yesterday at 02:46 PM »
That's what everyone thinks until there is an accident.
Online DynaGlide
« Reply #23 on: Yesterday at 03:11 PM »
I had to run out to Rockler to get some things and while I was there I had them measure the table distance to blade on the new saw: 7.5".
Offline ChuckS
« Reply #24 on: Yesterday at 06:40 PM »
Snip.
And table saw accidents/injuries can happen to both newbie and seasoned woodworkers as well as younger folks and elderly folks as statistics after statistics have proven it. One fellow woodworker I know cut his fingers on the table saw a few years ago while in his late 70s -- his first ever table saw finger cut after close to 50 years of woodworking. The nerve pain persisted for over half a year. He has since replaced his table saw with a track saw system.
