« Reply #214 on: January 29, 2019, 12:50 PM »
Thanks for the reply. I have a TS75 for the heavy stuff. Just been thinking about going to the cordless for framing and punch out work. Would be much faster for trimming off a door or two.
I use the cordless for framing work, it has been excellent. Since I had to do a lot of rip cuts on the recent project I added the corded and I am very glad I did.
That TS75 you have is a very capable saw (owned one many years back). For trimming off a door or two the cordless is "ok" but the corded is clearly better. I run the cordless with the dustbag and the corded hooked up to a vac and I am happy with the workflow with them both, leaves me with the right blade on each saw for most tasks. Also, the corded is much more forgiving with a finer tooth blade for occasional ripping.
Festool: CS 50EB precisio set, Domino DF500, DF XL 700, OFK500 edge router, OF1010 router EHL65 planer, CTL Mini/Midi Vac, CTL 26 vac MFT800+1080 tables
DSC-AG Grinder, RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
