Author Topic: Review of Festool Workshop Cleaning Set (Product No. 454767)  (Read 34541 times)
Offline ScotF
It is hard to imagine getting excited about a cleaning or cleaning accessories, but as is typical with most Festool purchases, I was thrilled to add this kit to my growing collection of Festool tools.  I bought a CT22 a couple of months ago and realized that to fully take advantage of the awesome functionality of the vacuum, I needed to add some additional cleaning accessories.  I really needed something to pick up all the sawdust and debris off of my floor after a busy day in the shop.  I used to get out the broom and dust pan, but of course this often created clouds of dust that I wanted to avoid.  I also really wanted one of the bigger diameter hoses to use with my TS75 saw and other tools that produce lots of chips and shavings.  Buying one of the cleaning sets that Festool offers is a great way to get a bigger hose with other accessories, making it a better overall value.  I looked at some of the other sets that Festool offered and thought long and hard about which set would make the most sense for my situation.  Since I already had some crevice tools and an upholstery nozzle from a different vacuum that worked fine with the CT22, I decided that I really did not need some of the tools included with the other available sets.  What I was lacking was a good floor nozzle and a suction brush that fit the hoses (the suction brush is not included in the kit, but it is a very inexpensive accessory to add and so I picked one of these up too).
Let's take a look at what is included in the Workshop Cleaning Set:
22887-0
Systainer 4
36 mm Antistatic hose (11.5') length
36 mm Metal curved hand tube
36 mm Metal extension tube (qty 3)
36 mm Metal industrial floor nozzle
22889-1
It comes with an insert in the Systainer that allows for easy storage of various other nozzles, including the brush nozzle, upholstery nozzle and crevice tools (the same insert as the one included with the Tradesman/Installer Cleaning Set).  This is nice since I added some other accessories and I can still fit everything in the Systainer for organized storage.
22891-2
The industrial floor nozzle is a first rate accessory.  The body of the nozzle is metal and it is very rugged and heavy-duty, built to withstand heavy use. The dimensions of it are 14 5/8 inches long x 2 inches wide, making it ideal to clean up sawdust and debris off the floor quickly and efficiently.
22893-3
22895-4
One of the nicest features of the nozzle I think is the ability to quickly and easily replace the brushes and casters since these are really the only parts subject to any wear.  All you do to pop out the worn brushes is unscrew the knob on the back of the unit, flip up the bracket that holds the casters and slide the rear brush out.  There is a small tab that flips up out of the way for the front brush. The casters simply pop out by unscrewing the know and flipping the metal bracket up.
The pictures below show the wheels and the brushes:
22897-5
22899-6
I use this nozzle predominately in the shop on a concrete floor.  However, if I were to take this inside the house or if I were working in a client's house, I might opt to pick up another set or two of casters to keep a clean set for indoor use or for use on wood floors.  While this has not been an issue for me yet, I can see the wheels picking up debris from the concrete floor that could scratch a hardwood floor if you do no take care to wipe them off before using it on the softer wood surface and having a set of clean wheels would prevent this from happening.  The wheels and replacement brushes are a low cost item too (part no. 452 935).
The extension tubes are high quality metal and fit to together smoothly and tightly.  One of the nice things about the way the tubes work with the nozzle is that the angle is just right to use the unit standing up in a natural position.  You do not need to hunch over to position the unit to work correctly.  This certainly helps your back, especially when cleaning up after a long day in the shop.  The tubes also work well with other accessories mounted on the end when you need extra reach.  Put together, the tubes are just over 48 inches long.
22901-7
22903-8
The floor nozzle is very easy to maneuver around the floor and it can get under some tight places:
22905-9
At the risk of sounding like a door-to-door vacuum salesperson ;), I decided to put some sawdust and chips/debris on the carpeted part of my shop to see how well the unit was able to vacuum up the mess.  The unit easily glided over the chips and I cleaned up everything in just a few passes.  It works equally well on the concrete floor.  The after picture was exactly what the floor looked like after taking a couple of passes over the debris.
22907-10
22909-11
22911-12
All in all this cleaning set is a very nice kit and certainly lives up to Festool's reputation of high quality.  I think that it provides good value, especially if you are looking to add a larger hose to your collection and it is certainly rugged and built to last.  My one complaint is that it can be challenging to fit everything back in the Systainer when you are done using it.  Although it comes in a Systainer 4, I think that Festool should consider offering this set in a Systainer 5.  The 36 mm hose takes up a lot of room and if you do not roll it up just right, it keeps trying to pop out of the Systainer.  A larger one would help solve this issue.  It's permanent home is going to be on my CT22 and the last picture is what the assembled unit looks like next to my CT22.
22913-13 [cool]
I hope that this review of the Workshop Cleaning Set was helpful.
Scot
« Last Edit: June 11, 2010, 11:42 PM by ScotF »
Offline Corwin
Re: Review of Festool Workshop Cleaning Set (Product No. 454767)
« Reply #1 on: June 12, 2010, 12:42 AM »
Nice review!  I made this same choice a couple of years ago when I wanted to upgrade to the larger D36 hose.  I certainly have not ever regretted that decision.
"The floor nozzle is very easy to maneuver..." seems like an understatement, as this truly is a very high quality floor sweep that does maneuver very well.
If a Boom Arm is in your future, you will like this set all the more, as the Boom Arm provides a place to store the metal tubes -- when joined together, the tubes will stow alongside the lower pipe of the Boom Arm.
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #2 on: June 12, 2010, 04:27 AM »
v good [thumbs up] [thumbs up] [thumbs up]
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline ScotF
« Reply #3 on: June 12, 2010, 11:14 AM »
Thanks, guys!
Corwin -- I would be curious to see how you store the tubes with the Boom Arm.  I do not have one yet, but this will be in my future.  I looked at the picture on the site but it is hard to see - do you just use some Velcro straps to secure it?  A picture of your setup would be great.  Also, I agree on the maneuverability -- I could not get a good picture, but I was able to get underneath my workbench by the full length of one of the tube sections which is about 12 inches.  This nozzle can turn tight corners too.
Scot
Offline Brice Burrell
  • Remodeling Contractor
« Reply #4 on: June 12, 2010, 11:27 AM »
Thanks, guys!
Corwin -- I would be curious to see how you store the tubes with the Boom Arm.  I do not have one yet, but this will be in my future.  I looked at the picture on the site but it is hard to see - do you just use some Velcro straps to secure it?  A picture of your setup would be great.....
Scot
Scot, I don't have a picture of the tubes stored but I do have one of the back of the handle/boom arm mounted on the my CT. You can stand the tubes in the extra slot on lower section of the mounting bracket.
Offline ScotF
« Reply #5 on: June 12, 2010, 11:45 AM »
Thanks, Brice!  That's exactly what I needed to see and it makes perfect sense.  I can feel myself starting to slide again...
Scot
Offline Corwin
« Reply #6 on: June 12, 2010, 01:12 PM »
Scot
Scot,
Here's a little push.   [blink]
This photo is in my photo gallery.  Note that I have also added another cord wrap with cross support to the handle so that I don't have to bend down so far to wind up the power cord.  These extra parts are not included with the handle or boom arm, so normally you would only have the the lower cross support and cord wraps.  The extension tubes are actually harder to clip on and remove with this additional cross support, but having the additional wrap up higher works fine for me.
Offline ScotF
« Reply #7 on: June 12, 2010, 02:33 PM »
Thanks, Corwin.  Appreciate the information.  Great gallery too...your V27 Incra squaring jig/miter gauge is very interesting.  How has it worked out for you so far?
Scot
Offline Corwin
« Reply #8 on: June 12, 2010, 03:11 PM »
Scot
I did that as a visual aid to demonstrate how Festool might improve their Angle Unit.  While that V27 gizmo does work, I don't use it.
Offline J Voos
« Reply #9 on: July 22, 2010, 02:53 PM »
Corwin,
What is the connection between the wand and the hose that comes with the cleaning set.  36mm or 27mm?  If it is 36 is it a tight fit with the wand?
Offline Allen Akin
« Reply #10 on: July 22, 2010, 04:47 PM »
Good question!  I have the cleaning set, and I've always found that connection annoyingly loose.  Furthermore, the hose-end of the connection is (after several years of use) beginning to split, making the connection even worse.
Allen
Offline Corwin
« Reply #11 on: July 22, 2010, 09:28 PM »
The Reducing Sleeve (tool end) for the D36 hose fits snugly around the outside of the rubber-tipped end of the Curved Stainless Steel Extension Tube -- it certainly is not loose on mine.  The tool-end of the D36 hose will also fit the Curved Polypropylene Extension Tube, but fits snuggly into the inside of the end of the Curved Extension.  If using a D27 hose, the Reducing Sleeve (tool end) of the D27 hose will also fit into either of these Curved Extensions, but not as nicely as the larger tool end of the D36 hose.
« Reply #12 on: July 22, 2010, 11:01 PM »
My D36 tool end is also loosening up like Allen's.  I'd say the tool end is a wear item and you should expect to have to replace it at some point.
Offline NuggyBuggy
« Reply #13 on: July 31, 2010, 10:05 PM »
I just bought the Workshop Cleaning Set and I must say I am very disappointed with how the parts connect.  They are either almost impossibly hard to connect (such that I was unsure if I was possibly doing the right things) or prone to coming apart when pressure is applied at an angle.  It seems like it would be just a matter of time before the flexible sleeves on the various parts would break or tear or loosen up. I don't see any benefit to the flexible sleeves as opposed to hard plastic sleeves found on cheaper vacs, in fact the latter would be a lot easier to work with.
This is maybe the first Festool product I've purchased where I found things just really awkward and unsatisfying to use.
Also, I found the hose to be quite inflexible, liable to kinking, and too short to use with the boom arm.  I guess a hose long enough to use with the boom would be way too large to fit in a Systainer.
“I am on a drug. It’s called Charlie Sheen.”
Offline Corwin
« Reply #14 on: July 31, 2010, 10:47 PM »
I found the hose to be ... too short to use with the boom arm.  I guess a hose long enough to use with the boom would be way too large to fit in a Systainer.
The length of the hose is the same as the D27 hose that comes with the vacuum -- and either hose will work just fine with the Boom Arm.  The Boom Arm does come with a shorter length of D50 hose that needs to be installed to make whatever hose you have long enough for use.  I don't see where you would desire a longer hose on the Boom Arm.  If too much longer, the hose would be on the floor -- getting the hose off the floor was why we purchased these Boom Arms to begin with.  And if you wanted it longer so you wouldn't need to install the D50 hose that came with the Boom Arm, then it would be more cumbersome when you go to remove the upper portion of the Boom Arm with the hose intact -- disconnecting the D50 from your hose at the connection point between the upper and lower portions of the Boom Arm is part of the design and how this works as a system.
« Last Edit: July 31, 2010, 11:07 PM by Corwin »
Offline ScotF
« Reply #15 on: August 01, 2010, 01:04 AM »
My set was a little hard to put the pieces together at first too.  However, after putting the pieces together and taking them apart a few times, they go together much smoother now.  I have not had any problems with them coming apart when pressure is applied -- it sounds like you might not have everything fully seated on the wand.  I have found that twisting and pushing them together at the same time allowed me to seat each tube properly.
Scot
Offline rnt80
    • Agape Wood Design
« Reply #16 on: August 01, 2010, 10:45 AM »
Scot
I'd echo what Scot has said here.  I've never had a problem with the pieces coming apart.  They were a little difficult at first but the twisting action helps.  Actually, this set has become one of those "why didn't I do this sooner" purchases.  It has helped with jobsite cleanup on installs tremendously.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
Offline NuggyBuggy
« Reply #17 on: August 01, 2010, 12:25 PM »
Ah, thanks, this helps some of my issues.  I forgot about several things.  First, I had an extra 5m D27 hose which I was using.  I also have the 3.5m D27 which, you are right is the same length as the D50 I just go with set.  I also forgot about the shorter D50 hose I had... which I also never had to use.
If I use the shorter D50 in addition to the Workshop Cleaning hose, I will indeed get about the same length as I had before.
Now I have to figure out how to get the D50 hose onto the boom arm.  The wider clips I have seem to be too small to close onto either the D50 hose or the D36.  I checked the Festool website and I can't find a manual for the Boom Arm ?  Is there a trick to doing this ?
« Last Edit: August 01, 2010, 12:39 PM by NuggyBuggy »
Offline Corwin
« Reply #18 on: August 01, 2010, 01:56 PM »
First off, the D50 hose doesn't get installed onto the upper portion of the Boom Arm, so it doesn't need to fit into the hose clips.  Instead, the D50 plugs into the CT and is lead up to where the upper and lower portions of the Boom Arm connect.  You should also have a shorter/heavier power cord that gets plugged into the CT and is also lead to this connection point.  So, these shorter lengths of D50 hose and power cord that come with the Boom Arm provide the additional lengths needed, and both are installed at the CT end.
The clips that hold the hose to the upper tube on the Boom Arm will work with either the D27 or D36 hose.  The D27 hose will easily lead into these clips, but the D36 hose is another story.  To install the D36 hose, you will need to loosen the bolts that fasten these two-part hose clips -- these bolts are somewhat short and may actually need to be completely undone before you can get the larger hose installed.  So, once the bolts are either loosened or removed, you can install the D36 hose within the clip and tighten or reinstall the bolts.  It would have been nicer if these bolts were just a tad longer.
Because of this tighter fit, the D36 will not install/uninstall on the Boom Arm as readily as the D27 hose.  And yes, this is a pain if you plan to install/uninstall the D36 hose often.  So, you might plan on either leaving the D36 hose installed on the Boom Arm, if that is an option for you, or you might elect to not install the larger hose into the clips and instead just install the hose onto the Boom Arm using a rubber band at each clip that you would hook around the cord holder on one side of the clip, stretch around the hose and hook onto the cord holder on the other side of the clip.
Offline NuggyBuggy
« Reply #19 on: August 01, 2010, 09:16 PM »
Sorry - I did mean the D36 hose, not the D50.  The D50 wouldn't make it very far along the arm.
If you're referring to the adapter cable I do have this, but not sure if you are.  I wish I could find a parts list for the boom arm.
I did remove one of these clips to try and figure out how to install.  Even with the bolts out, I couldn't see that they would be long enough to grab the other side.  I couldn't get it to work, I gave up pretty quickly and decided to just buy some longer bolts.
Offline Corwin
« Reply #20 on: August 01, 2010, 10:08 PM »
... Instead, the D50 plugs into the CT and is lead up to where the upper and lower portions of the Boom Arm connect.  You should also have a shorter/heavier power cord that gets plugged into the CT and is also lead to this connection point.
The power cord that comes with the Boom Arm is long enough to reach the location where the Boom Arm's upper and lower tubes connect when plugged into the outlet on the CT -- without running to the shop to check, this may be about 1.5 meters +/- in length.
For US models, the part number is 492757.  On the FestoolUSA website, select 'support' on the main menu and then choose 'Electronic Parts System' from the 'Assistance' menu to get to the Parts System.  Once there, select 'Accessories' from the menu on the left side of the page and then select 'Boom arm' and then 'CT boom arm' to get to the page you want.  Good luck.   [smile]
Yes, these really are too short for the job on my Boom Arm also.  But, I was able to loosen these bolts (all the way), install the D36 into the clip and retighten the bolts.  Since you have already purchased longer bolts, this should be much easier to reassemble.  Anyway, you should be able to install the D36 hose onto your Boom Arm.
« Last Edit: August 01, 2010, 10:15 PM by Corwin »
Offline mikeneron
« Reply #21 on: August 03, 2010, 12:19 PM »
Scot
Does the same apply to the hose...does it become a bit more flexible with use?  I do like the extra diameter for cleaning up and for use with my TS55, but the hose is kind of awkward to deal with as it doesn't have much give to it.
Offline ScotF
« Reply #22 on: August 03, 2010, 11:12 PM »
Hi Mikeneron,
Are you referring to the entire hose or just the rubber end?  The rubber end has a little give and fits over the nozzle or on the tools easier after a few uses.  The hose itself has a tendency to wind on itself, but I find that stretching it out removes the twist and kinks and I can keep it pretty straight.  I do not have the Boom Arm (yet), but that would also help tremendously.
Scot
Offline NuggyBuggy
« Reply #23 on: August 12, 2010, 12:11 PM »
[/quote]
Wow.  I don't know where mine went, but I just checked the (Canadian) price for that part - $77.  It's just an extension cord,  that plugs into the front of the CT and provides a female receptacle at the other end, right ? Is there any good reason why I couldn't just use another suitably rated extension in its place ?
« Reply #24 on: August 12, 2010, 12:34 PM »
No reason to spend that kind of money, it's just an extension cord.  Any (preferably short length) heavy gauge extension cord will do.
Offline kcasser
« Reply #25 on: August 27, 2010, 03:20 PM »
Just curious (I'll be making this decision shortly  [unsure]) but is the floor nozzle in this set that much better than the one in the Tradesman/Installer set?  It looks it, but I'm just wondering if it makes sense to spend $30 more to get fewer tools?
Offline JD2720
« Reply #26 on: August 27, 2010, 03:46 PM »
Yes it is much better.
The floor nozzle is what sold me on the Workshop set.
Just to note that the Workshop kit does not include the crevice nozzle, upholstery nozzle or the suction brush that are included in the Tradesman kit.
« Last Edit: August 27, 2010, 03:52 PM by Chris Rosenberger »
« Reply #27 on: August 27, 2010, 04:51 PM »
Chris, I'd love to hear your opinion after using the new floor nozzle for a couple of weeks.  I'm thinking about getting one of these.
Offline Tom Bellemare
  • Inactive Member
« Reply #28 on: August 27, 2010, 06:08 PM »
My observation has been that people, who go to training, tend to buy them.
Offline ScotF
« Reply #29 on: August 27, 2010, 10:26 PM »
Brice,
I am going on a couple of months now and I really, really like this thing...I have no experience with the other floor nozzles Festool offers to compare it with, but this thing is built like a tank.  My shop is all concrete with a small carpet area near the entry door and this makes quick work of cleaning up all of the surfaces.
Scot
Offline JD2720
« Reply #30 on: August 27, 2010, 11:00 PM »
Brice, I am already sold on the new floor nozzle. Like Scot, I have carpeted mats at my shop doors & in my office. It was always a pain to clean those. The other floor nozzles I have used would grab the mats. So I would end up trying to stand on the mats to keep them from moving around. The new nozzle has wheels that allow the brushes too just touch the surface.
It picks up the dust & chips, but not grab the mats. It is also very easy to move over the floor.
« Last Edit: August 28, 2010, 10:59 AM by Chris Rosenberger »
Offline kcasser
« Reply #31 on: August 28, 2010, 09:58 AM »
Sounds terrific!  One other question.  I see they offer a 'retrofit water extraction kit' for the floor nozzle.  Does anyone actually defile their Festool dust extractor by picking up water?  I'd think I would use my $24.99 ShopVac for that.  [scared]
« Reply #32 on: August 28, 2010, 10:55 AM »
Not at all.  Festool recommends that replace the main HEPA filters with their sponge filters so they are ruined.
Offline Alex
« Reply #33 on: August 28, 2010, 11:08 AM »
Yup, I do. I have these special filters for wet use Brice is talking about, and a special bucket (called the dirt trap) you can place inside the CT22. Makes it very easy and is no problem for the vac whatsoever because it is designed for this.
Offline NuggyBuggy
« Reply #34 on: September 03, 2010, 04:16 PM »
Thanks Corwin.  I found my D50 extension hose, as well as the power extension.  A picture here suggests a special tube holder for the D50, but I can't tell from the  boom arm parts list what part I need.   The only thing that looks like it might be the right part is described as  "Pipe clamp (492784)", though this part is described elsewhere as a "support tube bracket".
Also, the parts list shows a "support (492783)" and a "strut (493040)", which I can't see in any pictures of the boom arm.  Can someone tell me what these parts are supposed to do ?
thanks - terry
« Last Edit: September 03, 2010, 04:32 PM by NuggyBuggy »
« Reply #35 on: September 03, 2010, 04:21 PM »
Terry, you link isn't working.  Is this the part you're talking about, Festool Suction Hose Holder
Offline NuggyBuggy
« Reply #36 on: September 03, 2010, 04:31 PM »
Brice,
Thanks for the reply, and sorry for the broken link and the post which was quite unclear.  I wasn't referring to the nifty piece you have, but instead a clamp which appears to hold the initial extension hose up away from the CT and to the lower portion of the boom arm.
The proper link is  http://www.woodshopdemos.com/fes-66.htm . (just can't seem to place links on the forum today).
In the very first picture, the lady is attaching what looks to be the D50 hose to the boom arm, but I seem to be missing that part.  The parts list is visible on the Festool USa website if one clicks on "Support", then "Parts catalog",  "Accessories", "CT Boom Arm" (twice, I think).
I can't tell which part # I am missing.
Also the parts diagram shows two pieces which I don't think I've seen on a CT, Part # 10 "Support (492783) " and Part # 11 ("strut", 493040).  I think I may have the supports, not the struts, but can't figure out where they might go here either.  And to think I almost threw away the struts when I couldn't figure out what they belonged to !
Thanks !
terry
Offline Corwin
« Reply #37 on: September 03, 2010, 04:52 PM »
Hey Terry,
In the link you provided, the first picture shows Andrea attempting to connect the D50 hose to the hose brackets.  She wasn't successful, as you can see in the second picture that D50 hose is not held in place by any bracket.  So, you are not missing a part to connect the D50 hose to the Boom Arm, because there is no such part.
The EKAT page for the Boom Arm is somewhat problematic, as the list of items contains no item numbers to correspond with the diagram.  Most (if not all) other product parts lists in the system include the item numbers so you can identify the parts in the diagram using the list.
Also, note that the Boom Arm page in the EKAT shows the parts that come with the Boom Arm that are needed for the new CT26 and CT36 models.  Items 13,14 and 15 are for these new extractors, and are not included (or needed) with to install the Boom Arm on older CTs.  Of the two drawings of the CT extractors, the lower drawing is of the older CTs which shows the cord wraps and the lower bracket that come with the handle.  The upper drawing of the CT shows the new model and the associated parts.
The suction tube holder that Brice mentioned earlier is not required on the Boom Arm installations, but it does help somewhat to manage the D50 hose.  I have a hard time recommending it simply because of the added cost of the item.  But, it is useful with or without the Boom Arm to hold the hose up.  You can see how it holds the D50 hose in place in the my photo in post #6 in this thread.
On Edit: Parts #10 Support (492783) and #11 Strut (493040) along with part #7 Pipe Clamp (492784) make up the outrigger support for the Boom Arm.  The two support tubes (part #10) are held in place on either side of the handle with two of the pipe clamps (part #7) on each side (four required).  In many of the photos of the Boom Arm you will see these outrigger support tubes installed onto the handle and folded forward (in their stored position) against the sides of the CTs.  Some keep the struts (part #11) in the open end of one of the support tubes.  Once deployed, you can install the struts (an X brace) onto the two support tubes to fix these outrigger support tubes in place.  In earlier discussions on the Boom Arm, many of us noted that we either don't, or seldom use these outriggers to stabilize the Boom Arm.  With the Boom Arm hanging over the body of extractor, you will not need to deploy these outriggers.  However, with the Boom Arm extending out from the handle side you may find that deploying these outriggers is safer and will help to prevent the whole works from tipping over if you were to pull on the hose.
« Last Edit: September 03, 2010, 06:48 PM by Corwin »
Offline bionicus
« Reply #38 on: July 27, 2011, 05:29 PM »
Just thought I'd bump this review to add that the new T-Loc versions of the larger cleaning sets, including this Workshop set (497 701), now come in a Sys 5 instead of the Sys 4. This is indicated in the catalogue and maybe discussed elsewhere on the forum but was still a nice surprise when mine showed up this afternoon from ToolTech. Loading the 36mm hose and everything else is now a piece of pie.
Offline Ken Nagrod
  • Restricted
« Reply #39 on: July 27, 2011, 09:11 PM »
How's the T-Loc lid handling the big snake cause there's nothing holding the corners like the classic models and their latches?
  • Inactive Member
« Reply #40 on: July 27, 2011, 09:15 PM »
Ken:
The SYS 5 holds it well.
Offline Saskataper
« Reply #41 on: February 25, 2013, 10:42 PM »
I stopped in at a janitor/carpet cleaning supply today to see if I could find a cleaning kit similar to the workshop kit for a little better price but it turns out the festool workshop kit is a pretty good deal, they had the same head (wessel-work), almost the same tubes except two came to the same length 37", and a bent handle. Price they gave me was $270, only $23 less than the workshop kit that comes in a systainer with a hose.
Offline ScotF
« Reply #42 on: February 26, 2013, 12:19 AM »
It really is a good value in my opinion and I appreciate it every time I have to clean my floor.  It works very well and it is built to last.
Scot
