Author Topic: My new old stock Festool 1010 plunge router  (Read 16663 times)
Offline squall_line
Re: My new old stock Festool 1010 plunge router
« Reply #30 on: September 06, 2021, 08:40 AM »
This is better than the owners manual:
There are supplemental manuals for most of Festool's products and tools.  They're linked on their website.
Offline Toolabundant
« Reply #31 on: September 06, 2021, 12:46 PM »
Dust collection works so well router can hold a board mid air with vacuum on
OF1010
CT15
RO90
Offline waho6o9
    • Garage Door Handyman.com
« Reply #32 on: September 06, 2021, 01:08 PM »
That's awesome.  There's another piece to that collector as well.  At least for my 1400 there is, not sure about the 1010 though.
335491-0
« Reply #33 on: September 06, 2021, 03:41 PM »
(Attachment Link)
. Mine has the plastic insert snapped in. My dust port is metal and built in
OF1010
CT15
RO90
Offline Crazyraceguy
« Reply #34 on: September 06, 2021, 04:21 PM »
(Attachment Link)
That is one of the differences of the OF1400. That part is essentially "built-in" to the OF1010.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
« Reply #35 on: September 06, 2021, 11:16 PM »
Since I was working on the NOS Bosch 1611 and 1615 applying liquid graphite lube to the plunge posts I decided to just put a tiny bit of graphite lube on the Festool 1010. posts. Made it even smoother plunging.
OF1010
CT15
RO90
« Reply #36 on: September 10, 2021, 01:32 PM »
Really enjoying the router. Actually looking for things to use it on. I don’t believe there are festfools.  As long as you use something and can afford it buy it. I’m 53. I’ll have that router til I die hopefully in my 90s. Do my philosophy is buy great once cry once. Buy cheap you’ll be crying all the time. And that router is sized to be used a lot.
OF1010
CT15
RO90
« Reply #37 on: September 12, 2021, 08:04 PM »
I ordered these 8mm shank set from Amazon uk. It’s Bosch but black clorored as opposed to blue.  I paid $134. Since my order up to $154. 6 bits were $50. 15 were $99. And the 30 I got was $134.  I really wanted a high quality starter set with maybe 6 bits for same money. Figured I might as well go for the 30 since it’s not like I can gradually build my 8mm shank collection . So now my little Bosch trimmer has a Freud boxed 1/4 set . And the Festool has a 8mm set.  And the Bosch 1611,1615evs, 1617, 1618evs and Milwaukee 5625-20 get the extensive collection of Freud, Cmt, white side and Mlcs. Hope the set is a least decent Bosch Professional 2607017475 30-Piece Set Wood Router Bit Set for 8mm Shank Router https://www.amazon.com/dp/B07ML7K2G8/ref=cm_sw_r_cp_api_glt_fabc_GAMER5ZJX7VSRJ947WB6?_encoding=UTF8&psc=1
OF1010
CT15
RO90
« Reply #38 on: September 13, 2021, 08:02 PM »
[ Specified attachment is not available ]
OF1010
CT15
RO90
« Reply #39 on: September 13, 2021, 08:06 PM »
Pics are of port adapter made on a 3D printer from a guy on eBay. My WAP vacuum rubber port adapter fits perfect . Beats prying the rubber adapter on the oblong Festool dust port.
OF1010
CT15
RO90
Offline waho6o9
« Reply #40 on: September 13, 2021, 09:58 PM »
Nice vacuum adapter.
« Reply #41 on: September 15, 2021, 09:11 PM »
Got my Bosch 8mm shank router bit set today. They are black finish made in China. 8mm definitely is beefier than 1/4. I compared a 8mm Bosch to a 1/4 Freud . Both flush trim bits.
OF1010
CT15
RO90
« Reply #42 on: September 15, 2021, 11:06 PM »
Tested a Bosch 20mm.  Slight burn marks at beginning and end of cut. Slight burn on right hand side where router got off track a little. Used the Festool fence
OF1010
CT15
RO90
« Reply #43 on: September 15, 2021, 11:10 PM »
The fence
OF1010
CT15
RO90
« Reply #44 on: October 21, 2021, 09:25 PM »
Routed a new shelf using a existing shelf as a template . The original mdf shelf was breaking up. OF 1010 was perfect to cut a shelf out of 15/32 plywood. Used the other shelf as a template pin pin nailed to plywood. 8mm shank Bosch top bearing bit used. Now if I was cutting 3/4 plywood I would use one of my midsize routers and a 1/2 shank but. The littie Festool handles so well it’s my go to unless I’m cutting thick stock or using big bits.
OF1010
CT15
RO90
« Reply #45 on: October 21, 2021, 09:51 PM »
The little Festool handles so well it’s my go to unless I’m cutting thick stock or using big bits.
The 1010 is also my go-to Festool router for 70% of what I do. It's just such a pleasure to use. I own every Festool router plus 2 Milwaukee routers and the 1010 still does the lions-share of the work. The only annoying feature is the oval dust port.
Your thoughts on the Tool Curve dust port adapter?
« Reply #46 on: October 22, 2021, 05:06 AM »
Your thoughts on the Tool Curve dust port adapter?   I love it!  Fits nice and snug on the router and the vacuum end fits my WAP vacuum rubber tool adapter and my 27mm Festool hose ends perfect and snug. https://www.ebay.com/itm/Festool-Cleantec-27mm-Locking-Dust-Adapter-for-Festool-OF-1010-Router-/265073864218?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=711-127632-2357-0  Takes about a week to ship. Made on a 3D printer.
OF1010
CT15
RO90
« Reply #47 on: January 13, 2022, 10:52 AM »
Put a dedicated torx screwdriver in the case to attach edge dust hood.
OF1010
CT15
RO90
« Reply #48 on: January 13, 2022, 05:39 PM »
I did the same thing, mostly for swapping the guide bushings.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
