Author Topic: My new old stock Festool 1010 plunge router  (Read 13750 times)
Offline Toolabundant
« on: September 03, 2021, 02:42 PM »
Hi all, I is have 7 routers a single speed Bosch 1617 fixed base/plunge kit, a single speed Bosch 1611 14 amp plunge and Bosch 1615 Evs plunge(1611 and 1615 both NOS bought for a song on eBay) a Bosch d handle 1618evs, a Bosch colt ( the newer one). And a Milwaukee 5625-20 in a bench dog router table. And now a festool plunge. I was going to buy the plunge base for the colt but then spied the 1010 at Paul b Zimmerman hardware . It was a older model that was $420 regular price $485. I wish festool would include edge guide which was a extra $48. 1010 comes with a dust catcher for edge work and a parallel guide for rail systems. I bought the festool for small projects like the box drums pictured. Some pics of my modest shop . downstairs in basement . Pics show where chips jam when no dust collection used. I bought a adapter on eBay to use my wap vac with it. I router some 45 chamfers on my deck with the 1010. The bit wouldn’t even fit the Bosch colt. Only uses 1/4 and 8mm shanks but I bought it for compact handling for small projects. The big 2200 festool doesn’t interest me cause I got big Bosch plungers. The 1400 doesn’t interest me cause I got the Bosch 1617 kit. Wanted to try a festool and I really like using routers. But I’m not drinking the kool aid and going all festool. I do like how lightweight and maneuverable the 1010 is. Plus I like using two hands to router. I m not sure how I feel about palm routing with colt . It was expensive but is a well built balanced tool
« Last Edit: September 03, 2021, 09:36 PM by Toolabundant »
OF1010
CT15
RO90
Re: My new old stock Festool 1010 plunge router
« Reply #1 on: September 03, 2021, 07:14 PM »
I wish the collet was all nut. The Festool collet has just a small hex to wrench on at top and rest of collet is smooth. I like more area to put my wrench on. Not much room to maneuver wrench between plunge posts. Wrench is a high quality wrench. I wish router had a electric brake like the big makita plunge router does. Plunge is very smooth. The twist lock knob to lock plunge in position is nice feature .
OF1010
CT15
RO90
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #2 on: September 03, 2021, 07:22 PM »
You do know there's a shaft lock, right? I love the shaft lock/single wrench bit changes.
« Reply #3 on: September 03, 2021, 07:42 PM »
Yep it’s a hole in the spindle and when you line it up and push button it locks it.
OF1010
CT15
RO90
« Reply #4 on: September 03, 2021, 07:46 PM »
you should see the antiqued spindle lock on those big Bosch plungers(1611,1615)  I have .
OF1010
CT15
RO90
« Reply #5 on: September 03, 2021, 09:57 PM »
Pic
« Last Edit: September 03, 2021, 10:04 PM by Toolabundant »
OF1010
CT15
RO90
« Reply #6 on: September 03, 2021, 10:07 PM »
Pic
OF1010
CT15
RO90
« Reply #7 on: September 03, 2021, 10:16 PM »
Pic of how Freud 45 chamfer fit the Festool but not the Bosch
OF1010
CT15
RO90
« Reply #8 on: September 03, 2021, 10:56 PM »
And to add to my review the Festool ran fairly cool despite making a full profile cut in pressure treated lumber with a fairly large 45 chamfer bit. I had it on speed 4. The top at the vents was pretty warm. The collet wasn’t hot removing bit. The Bosch  colt gets hot just running without a load on it. Collet is hot to the touch after 5 minutes of running.
OF1010
CT15
RO90
Online Cheese
« Reply #9 on: September 03, 2021, 11:36 PM »
The 1010 is my favorite Festool router and I own all 4 of the Festool variants. I also own a couple of Milwaukee routers and the 1010 is still my favorite.
On the latest 1010, Festool moved a few things around so that you have more wrench room.
« Reply #10 on: September 04, 2021, 12:10 AM »
I posted cause I was interested in some discussion on Festool. Is it the best handling router I ever used? Yes. Is it head and shoulders better than a Bosch . No. . It’s not like upgrading from a ski or ryobi to a Bosch . It’s the law of diminishing returns. You get maybe 25% better performance for 3 times plus the price and them to add salt the wound you have to buy your own fence. You have 30 days to try and you can return . I will keep it and enjoy it. Especially since because of its size nimbleness it will be my most used router aside from the big Milwaukee 5625-20 in the table. Plus it’s the least expensive Festool router. I would never buy the big 2200 for $995. I got a brand new USA made Bosch 1615 Evs new old stock for $120 some odd dollars on eBay. Now granted just as much as I think 3/4 ton diesel trucks are neat I’m not buying one. The 2200 is way overkill. The 1010 can and will be used a alot. However, it will probably be my only Festool . A curiosity I’m my arsenal of tools. Always wanted to own at least one Festool.  The  trion jigsaws aren’t exorbitantly priced .  Neither is the multi tool. Who knows maybe I’ll bite the bulleti on another Festool
« Last Edit: September 04, 2021, 12:15 AM by Toolabundant »
OF1010
CT15
RO90
« Reply #11 on: September 04, 2021, 04:50 AM »
. Thanks for your opinion, I was on the fence about buying it cause it only uses 1/4 and 8 mm collets I even have a 1/4 roundover with a 1/2 shank.  I bought a Freud 1/4 inch router bit set for the Bosch colt. Then I figured  I’d try it since I have the 1/4 bits now.  Maybe I should find a nice 8mm set of bits
OF1010
CT15
RO90
« Reply #12 on: September 04, 2021, 09:37 AM »
I want to use this router in my little basement shop where the dust collection and quiet ( compared to other routers) will be beneficial.  I plan on practicing on scrap wood to really get to know the machine. A lot of my older projects I just dove right in which resulted in errors and frustration.
OF1010
CT15
RO90
Online Cheese
« Reply #13 on: September 04, 2021, 10:20 AM »
When all my routers were Milwaukee, I purchased a set of Bosch roundover bits with 1/2" shanks. Even the 1/16" & 1/8" radius bits have 1/2" shanks which can be kind of clunky but if that's all you know you just live with it.
When I picked up the 1010 I also picked up a Festool 1 mm & a 1.5 mm radius roundover bits with a 8 mm shaft. The smaller diameter shafts are really nice to work with.
« Reply #14 on: September 04, 2021, 01:48 PM »
Anxious to try the adapter for the 1010 dust port. It needs made yet. Guy on eBay makes them on 3D printer . Hoping it doesn’t clog. It clogged router deck but then there was no vacuum attached . The Bosch 1617 dust collection with round ports works fine. Here’s a link to the adapter. I can force the round rubber adapter for my WAP vacuum on but then it falls off. https://www.ebay.com/itm/Festool-Cleantec-27mm-Locking-Dust-Adapter-for-Festool-OF-1010-Router-/265073864218?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=711-127632-2357-0
OF1010
CT15
RO90
« Reply #15 on: September 04, 2021, 05:25 PM »
Got my fence via fed ex fro hartville tools in Ohio. Annoyed that dust cup and micro adjuster is separate to buy. But hey I got another set of rods. Fence sits in case nicely .
OF1010
CT15
RO90
Offline Crazyraceguy
« Reply #16 on: September 04, 2021, 07:25 PM »
That is a very good move. I got a few 8mm shank bits when I first got a MFK700, but it is a fairly specialty tool. But when I got my hands on a OF1010, it became a priority for me. In the US, that's not the easiest thing. Unless you have a pretty good woodworking store locally, you're not going to find them in a retail situation. In-line is your friend in this case.
Lee Valley has them for a lot of profiles in the small to medium range, available individually. Bosch also has a nice set, but I have only found it through Amazon UK. Then it shipped from Germany.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
« Reply #17 on: September 04, 2021, 10:46 PM »
Took a scrap piece of cedar and used a 1/4 mortising bit and made a 3/4 inch dado in 2 passes. Dado filled with chips but moved router back over it and vacuum sucked chips out. Rest of passes nothing was left in dado. Then used a 3/8 roundover without chip defector and there was minimal debris .
OF1010
CT15
RO90
« Reply #18 on: September 04, 2021, 10:51 PM »
Mortising bit pics. Plus WAP vac hookup.
« Last Edit: September 04, 2021, 11:01 PM by Toolabundant »
OF1010
CT15
RO90
« Reply #19 on: September 04, 2021, 11:11 PM »
3/8 roundover full depth pass . No chip catcher/deflector on. Minimum debri on router and workmate / table
« Last Edit: September 04, 2021, 11:30 PM by Toolabundant »
OF1010
CT15
RO90
« Reply #20 on: September 04, 2021, 11:34 PM »
I can see why Festool vacuum clamp is a great idea. Work mate good for 2x lumber but with 1x lumber fence with hit orange dogs
OF1010
CT15
RO90
« Reply #21 on: September 04, 2021, 11:43 PM »
Doesn’t take much to scratch baseplate . Unless it’s cedar stain that cleans off
OF1010
CT15
RO90
« Reply #22 on: September 04, 2021, 11:48 PM »
I think Festool should have more depth stops(turret) like Bosch. Those are pretty big depth changes for a 1/4 bit. And I know you can adjust depth rod as well
A depth turret.
OF1010
CT15
RO90
« Reply #23 on: September 04, 2021, 11:55 PM »
The WAP 840A bought on clearance at Sears many moons ago. I sure Festool vacs have even more suction so there would be less debris than with the WAP
OF1010
CT15
RO90
« Reply #24 on: September 05, 2021, 04:23 PM »
[ Specified attachment is not available ]Played around on a old box drum with a trend 45 chamfer and 1/8 whiteside roundover . Had to use dust catcher with full profile of 1/8 round over used. Dust catcher catches when you round the corner . You would have to finish cut on one side then start fresh on other side. That’s probably the right way to do it anyway. I just start at one place and go all the way around. You can rout one handed . Found this out cause sometimes vac hose catches on work and then I hold hose with one hand and rout with the other.
« Last Edit: September 05, 2021, 05:01 PM by Toolabundant »
OF1010
CT15
RO90
« Reply #25 on: September 05, 2021, 05:37 PM »
“ Dado filled with chips but moved router back over it and vacuum sucked chips out.”
Run the router the other direction. When the dust port leads the bit the duct collection is poorer than when the dust port follows the bit.
« Reply #26 on: September 05, 2021, 05:42 PM »
thank you!
OF1010
CT15
RO90
« Reply #27 on: September 05, 2021, 07:44 PM »
A spiral up-cut bit will help with that too. It pulls the chips up and into the vacuum rather than just stirring them around down in the dado/groove.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
« Reply #28 on: September 06, 2021, 03:14 AM »
.  I need to get more of them  I have one a 1/4 shank 1/4 inch Freud
OF1010
CT15
RO90
OF1010
CT15
RO90
