Author Topic: MFT/3 review  (Read 31685 times)
Offline Dovetail65
Re: MFT/3 review
« Reply #30 on: September 19, 2012, 12:21 AM »
Yes, for sure.
I actually use pucks doubled up(sometimes even tripled) to get some height all the time.
Offline ScotF
Re: MFT/3 review
« Reply #31 on: September 19, 2012, 01:15 AM »
Yes...I use scrap wood or you can make simple I-beams or really anything to gain height.  Plus with the clamping possibilities you can easily clamp boards to allow for overhang when using a jigsaw or router and often clamp material right to the surface.
Scot
Offline fletchtool
Re: MFT/3 review
« Reply #32 on: September 19, 2012, 08:31 PM »
Thanks Scot and Dovetail65. Just to be sure I understand you, So as far as you are concerned I can use the the guides on the MFT just the same as if I was using a TS only I have to raise the material being cut and the guides.
Thanks for your help with this.
Fletchtool.
Offline fritter63
Re: MFT/3 review
« Reply #33 on: September 19, 2012, 11:53 PM »
For the ts55 on my bench I use rigid foam insulation, in small squares that are easy to store. If you cut into it it doesn't matter and there's no resistance. Prob don't want that with a jig saw though.
Offline ScotF
Re: MFT/3 review
« Reply #34 on: September 22, 2012, 03:24 PM »
Fletchtool.
You got it!
Scot
