Author Topic: Mafelll vs Festool ( and others!)  (Read 75515 times)
Offline Geo
« on: November 30, 2015, 02:09 AM »
Regarding Festool vs Mafell 55 plunge / track saws... I have both, ( and the Makita) and can give you the straight dope...
For system integration and convenience, plus wide availability and service, Festool wins.
If you want "the best", then Mafell has substantial advantages in features and quality.
Here's WHY I say that:
My Mafell MT55 has a completely enclosed blade guard, which improves dust collection. Sure, Festool's dust collection is great too. Mafell is just better at catching the last bit of fine dust that escapes from the hole on the festool saws.
Blade changes are faster on the Mafell. Search online for videos to see it for yourself. I consider that an advantage when I am carrying only ONE saw to do several things, therefore fast blade-changes are helpful. My entire travel kit fits in the back of a Honda Civic, partly because of the Mafell Track saw and Mafell jigsaw. ( the Mafell jigsaw is head and shoulders above any other jigsaw, including Festool. yes, I have both.)
The pivot-locking is faster on Mafell---one knob instead of two. It still locks at both ends like Festool’s, but a steel rod connects both ends so only one knob is needed.
Depth of cut and angle settings are more robust, secure, fast and easy.
When you pick up the Mafell, you'll know. Just looking at it in photos doesn't help you see and FEEL the difference in weight, strength, general engineering. The tracks and track connections are VASTLY better, much more rigid and heavy duty... made of thick wide STEEL, not thin soft aluminum.
There is only ONE feature about the MT55 that SOME users MAY need, but can't get---
the riving knife.
Apparently, it's very difficult to get permission in Germany ( or the EU) to even make a saw WITHOUT a riving knife... but Mafell jumped through those legal hoops to make it happen. WHY? Because they know the riving knife on a small circular saw is USUALLY superfluous. The only time we really need that riving knife is when we rip solid timber, especially if it is not properly dried.
You'll note that ALL the BIG timber-framing saws Mafell makes DO have riving knives for that reason.
The Makita also has no riving knife. Since I use that at home for plywood or KD only, I have only had one instance of kickback, and that was because the tracks were dusty and I didn’t use the clamps. Keep clean tracks and use clamps, you’ll never have a kickback with plywood or engineered lumber. So long as we are cutting sheet goods or good dry solid lumber, you don't need a riving knife. As soon as we start cutting BIG TIMBERS, or wet wood, then that riving knife is a good thing!
Therefore, If I was doing timber framing anymore, I'd go with the Festool TS75 ( at the bare minimum) or one of the other Mafell LARGE saws with riving knives.
Convenience and accessories...
Festool certainly has the edge in convenience and system integration. Their tools fit their power and vac connections. So long as you stick with Festool, you're good to go! Their vacuums fit all their tools. That’s true if you go ALL Mafell too, but then you’re in another echelon of cost.
I consider Festool’s system integration an advantage simply because I don't have to think about it. Just go Festool all the way, and your thinking is done for you. You pay a premium for accessories, but consider the value of your time. If you are fed up worrying about it, just go Festool. It's plenty good enough and has most of the features you could want, certainly all the features you need.
Problems arise when you need another section of track, or want to use another brand of router, jigsaw, etc.
The instant you need to bodge Festool stuff together with another brand, you're out of luck. Mafell saws CAN use Festool, Makita and Bosch tracks. You can't get Festool to work with Mafell tracks. Likewise, the DeWalt track-saw has a unique track with the guide-rail in the middle. I like that because there are TWO zero-clearance strips. But again, you can’t use their tracks with any other saw and vice-versa.
Mafell has great vaccums too, but frankly, I prefer the square top design of Festool vacs. Yes, you can use Mafell saws and hoses with Festool vacuums interchangeably. I just like the little Festool vacs for portability and convenient tool-holding.
Service... Festool is well known for its service. I have only had one problem with Festool stuff (the older jigsaw) and they took care of it fast, without any grousing.
Conversely, I have NEVER had any issues with Mafell, despite using Mafell saws since 1978. Those timber framing crews that introduced me to Mafell back then didn't just use Mafell saws... they used the ever lovin' $H1T out of 'em! For the really heavy duty stuff, Mafell is the way to go. It should be considering Mafell is far more expensive. Mafell is the German analog to Northfield Machinery of heavy duty portable equipment. It’s expensive and worth it.
Now that Mafell is finally becoming recognized in the states, Timberwolf Tools has relocated their main warehouse to Chicago. That dramatically improves shipping and turnaround times should you ever have a problem. I know from experience that Timberwolf stands behind every product they sell, 100%
Jeffery Powel (8008694169) is the guy I talk to there for advice, and you will probably need some advice when buying Mafell. Reason: Mafell is NO WHERE NEAR as clever at marketing and promotion. You have to dig through online catalogs and learn their peculiar teutonic protocols to even understand the catalog listings. Even with some experience navigating their website, I STILL call Jeff before placing an order.
One thing is certain... Timberwolf ships FAST! So far, everything I got from them was delivered the next day. Super packaging. No problems with shipping damage, even with the awkward long tracks and little parts ( clamps, edge guide, angle guide / protractors etc.) And BTW... don't believe the prices are written in stone. Sure, like Festool, Mafell has MAP pricing by contract, but there are ways around that. If you do enough business with Timberwolf, they'll work with you as much as they can. Because I’m tool-crazy, I might just spring for a mafell Bandsaw and one of those Erika table saws... but NOT before I talk to Jeff!
Most Festool dealers are good since they all can get Festool training. Festool works with their dealers to insure they know the products. I buy Festool stuff locally since we have a dealer here.
I made the mistake of buying some Festool stuff from CPO Festool. Never again.
In general, all the CPO services are junk and they only care about making more sales. Call them and ask a few questions to see for yourself.
Although Amazon has a good return policy, there is no one there to give buying advice or answers to user questions.. other than some users... and some of them are shills.
You’re better off not buying tools from huge outlets or Amazon no matter which brand you choose. Find your nearest dealer... or if you don’t have one nearby, talk to a reliable dealer: Lee Valley in Canada; Highland, Rockler or Woodcraft in the USA. There are other good dealers I’m sure. It’s just that I know from long experience you can trust those resources.
So, My advice? If you need the BEST dust collection, the most features ( minus riving knife for the small saws)  or just want the Supreme BEST heavy duty tools... get Mafell.
Their Jigsaw is BY FAR the BEST. Likewise, the Mafell MT55 has some advantages over Festool in that size range.
However, if you plan to work with solid wood ( instead of plywood or other engineered panels) you'll want the riving knife. Festool’s small saw (TS55) and their big saw (TS75) both have ‘em.
Now, this last part is subjective and depends on what kind of work you do...
If you want to save time building cabinets, then the TS75's depth-of-cut is an advantage over any 55mm saw. With that, you can stack two to four sheets of plywood to make matching cuts on opposing carcass faces. You CAN gang TWO sheets with the 55’s, but you’ll unlikely gang FOUR like you can with bigger saws.
Gang-cutting speeds production and guarantees equal sized parts. That gang-cutting approach is a time saver for other applications too: making internal components for torsion boxes, cutting many small interior drawers at once, ripping many thin strips for boat building or fancy laminated furniture.
If I built those kinds of things more, then I'd go with Festool TS75.
If I was young enough to do timber framing anymore, I'd definitely go Mafell, all the way. But there, we're not talking about the little MT55... we're talking the ultra skookum BIG BOY saws! (WAY over the thousand dollar range) Those saws run on 220, so you either need an industrial power drop or a BIG PRO generator to run them. For installers, cabinet makers and us old fart retirees, Festool is the easy way out and PLENTY good enough.
BTW: the new Mafell MT55 plus a track, roller edge guide, angle guide, xero-clearance inserts and stuff cost me $1375. You can get the small Festool saw AND a vac for that. But then, I’m crazy and bought both.
As it is, I have both brands to cover any situation. At home INSIDE, I prefer Festool.
For outside stuff at home, I use the Makita. When I need ONE SAW for every job, I bring the Mafell, a few blades and some accessories.
 People talk about festool stuff for pros or “spendy” hobbyists, but they never really mention WHY Festool’s system approach is so popular in Europe.
European homes are not nearly as big as American homes. The REAL reason you might want Festool’s whole system approach is to save space. If you don’t have much room and still want pro-level accuracy, Festool shines. You can get an entire workshop in a small van or bedroom, and set it up in minutes. If you work at home, Festool’s dust collection is good enough to keep your wife from divorcing you.
When I do volunteer work, I want to travel light yet remain versatile.That's when the Mafell fast blade changes really shines. But then again, I have my own custom made rolling rig with a panel saw jig. I can switch from rip to cross cut faster than most guys can move stuff to a miter saw. The Mafell angle guide is fast and perfect. I can also slow the saw down, (just like Festool) and use a metal cutting blade. No need to have a different saw. However, If I know I must have two saws, the festool and Mafell boxes fit together perfectly. Festool has speed control too, but Mafell motors are stronger and I’ve never had one “thermal out” on me. I have had the TS75 quit when cutting wet wood or sheet metal. Conversely, I have cut 3/8ths stainless sheets with my little Mafell.
BTW, Festool has a spark arrestor attachment for their Vacs... highly recommended if you are cutting BOTH wood AND metal using the same vacuum!
So, the bottom line is simple... if you work mostly with solid timber or plan to do production cabinet making, get the Festool TS75. You'll pay for it and never have to think about it again.
If you justadmire fine tools, or need the speed and flexibility, get the Mafell. If you want to get ONE THING by Mafell, the choose their Jigsaw. Make everything else Festool and you’re golden.
I recognize that some people "just want the best." Perhaps they are hobbyists who don't want to be clever inventing their own jigs, tracks, dust collection rigs. They just want to have the most fun with the least hassle. Then, either festool of mafell is great. Festool costs less and is more widely available from reputable dealers. Timberwolf is reputable, but you have no other options.
I also recognize that some people ( especially pros) want convenience and don't want to waste time mulling over every detail choosing tools.
If you are a pro, you don't care much what the tools cost up front, since you can deduct depreciation. If a thing costs more, you get larger deductions. Make your darn accountant do his job and by April 15th you won’t care about price. After five years, it’s all a wash no matter which brand you choose.
So the real problem is, can you get everything you want within ONE brand? Yeah... Festool can give you almost everything you'll need.
My personal perspective is peculiar, since I both LOVE fine tools (and can afford them) and yet, I HATE fussing over details. Now retired, woodworking is mostly a hobby for fun, home-repair DIY, or volunteer work to help others. I don’t have time to fuss over niggling details of every tool purchase. Far too many times, trying to “find the best deal” has ended up costing me more time and money. Now, I'd rather just buy the darn thing and see how it works. If I like, I keep it. If I hate it, I send it back. Simple.
BOTH Mafell and Festool have sufficient time windows for customer satisfaction trial. Both companies stand behind their tools. I just prefer to buy fabulous engineering ( like the Mafell) but also enjoy the simple system approach Festool brings.
If your time is valuable... just go Festool and get it over with.
If you are doing heavy duty timber framing or just want the most rugged precise saws with the best features... go Mafell.
I still like my little Makita track saw too. For $350, it’s great. If money is the main issue, go Makita.
If you need a supreme jigsaw, Get the Mafell no matter what brand of other tools you choose. Honestly, it cuts BETTER than my two 10 inch bandsaws... no exaggeration!
Therefore, assuming only quality and features are important (not cost) here is the 2015 / 2016 list:
If I had to choose ONE track saw? I’d get the festool TS75. It’s BIG enough to do gang cutting, has the riving knife in case I need it AND it fits with other Festool stuff I like.
If I had to choose ONE sander? Rotex 150. One sander does three different jobs. Carry less. Do more.
One joinery system? The small festool Domino... no contest. I still use my biscuit joiner for many things, but for sheer strength, NOTHING beats a tenon and NOTHING is faster or easier than the Domino.
One worm-drive framing saw? Makita magnesium Hypoid. I don’t do ANY framing anymore. Too old. But I still bought one of those because they’re Skookum.
One sidewinder “do everything” Circ saw? DeWalt 364 or 384. The DW360’s are unique because of the parallel adjustment feature and the front depth adjustment. If you need to make a homemade table saw with a sidewinder, THAT is by far the best saw to get. It also does everything else a sidewinder should do, VERY well. Strong. Good design. No dust collection to speak of.
One jigsaw? Mafell... no contest. Again just today, I had to cut fancy curves to mount some garden tools to the garage wall. I already had the bandsaw set up, so I tried that first. Too slow and the cuts were jagged. Got out the Mafell jigsaw, clamped it in the workmate and went to town. Perfect beautiful cuts in half the time. No kidding.
One miter saw? Bosch or Makita. Bosch for compound sliding; Makita for chop saw.
If factory installed dust control is crucial, the bite the bullet, get the Festool miter saw.
If you know how to modify your tools, the others are just as accurate and CAN provide good dust collection.
Vaccums? Festool... any size. I have two. Mini and the 26.
For more chip collection ( as opposed to fine dust) I got the best results with a ridgid 5 gallon attached to a Rockler DustRight separator for the thickness planer. Haven’t changed a bag in two years!
Based of decades of mistakes and luck, If I had to pick mostly ONE brand (and I obviously don’t) I’d choose Festool for system-integration, convenience, versatility and overall dust collection. It all plenty good and I don’t have to fuss over buying decisions. Just buy it and be done, then get on with the fun.
For BIG NASTY CHIP sucking and other gross jobs too mean for expensive German tools, Ridgid vacs are an awesome value.
No matter what, I’d STILL get that darn Mafell jigsaw. It’s in an entirely different dimension.
That’s my honest opinion based on real experience. I sincerely hope that helps because I am tired of typing now. ;-)
Offline arso_bg
Re: Mafelll vs Festool ( and others!)
« Reply #1 on: November 30, 2015, 04:15 AM »
Do you know whether the Mafell MT55CC will fit (or can be used with) the Festool CMS module?
Regards
Offline Throwback7r
« Reply #2 on: November 30, 2015, 07:26 AM »
I have ordered from CPO Festool a few times. They were great, I clicked 4-6 times and in a few days stuff showed up. Also, my local dealer knowing what they are talking about is just laughable. The best customer service was from Bob Marino, super nice guy and knew his stuff.
Timberwolf tools website is how shall I say.. not good. So you either call and get to talk to someone or click and pray.
The large issue with me on the Mafell stuff is service, if that 735$ jig saw needs to be repaired or you would like an accessory, off it goes for who knows how long. " Anyone in the US that sent something Mafell for repair please comment."
I use my tools for work and having down time is a huge concern that is why I went Festool for everything.
One more thing, on the Kapex I bought it because of how small it folds down. look at the other systems and you will see something that is MUCH larger and Heavier, and all you have to do is run it up 2 flights of stairs just to see where I am coming from.
Offline Dane
« Reply #3 on: November 30, 2015, 11:23 AM »
Great summary, thanks!  Always valuable to hear from an experienced end user.-  I'd be really interested in seeing some details of your cross-cutting rig if you are inclined to share.
Online Cheese
« Reply #4 on: November 30, 2015, 11:55 AM »
@Geo
A very interesting first post and...
 [welcome] to the FOG.
Curious what blade you used to cut the 3/8" stainless sheet?
« Last Edit: December 01, 2015, 09:11 AM by Cheese »
Offline Tom Gensmer
« Reply #5 on: November 30, 2015, 12:20 PM »
Fantastic first post, and welcome!!
We seem to be set up similarly. All of my routers, planers and sanders are Festool (CMS-OF, OF-1400, MFK-700, RO-150, RO-90, LS-130, EHL-65) whereas, with the exception of my Kapex, I have gone to an all-Mafell saw lineup (Erika 70, MT-55cc, KSS-400, P1cc). I've found it supremely easy to adapt the Mafell tracks to the MFT/3 table using Qwas dogs, if you're into that sort of thing.
Glad to see another tradesman who isn't afraid to embrace the best from multiple manufacturers.
« Last Edit: November 30, 2015, 12:24 PM by Tom Gensmer »
CT-MIDI, C-18, RO-150, RO-90, OF-1010, OF-1400, MFK-700, MFK-700EQ/B, EHL-65, DTS-400, LS-130, MFT/3 (x4), MFT/Kapex (x3), KA 65 Conturo, endless Systainers
Offline leakyroof
« Reply #6 on: November 30, 2015, 02:04 PM »
  I've worked with Stainless steel as a day job in the past[ 80s]  I'd REALLY like to know this as well........Cold Cutting saw with a liquid feed over the blade, check.  Nice way to do it and no dust
 Abrasive saw with afterwork of getting rid of the burn marks on what you're cutting, also check.  Lots of dust...
 3/8" thick stock cut with small hand held saw????  [eek] [eek] [huh] [huh] [huh]
 Maybe they meant 1/8"..... [embarassed] [embarassed] [embarassed]
Offline glass1
« Reply #7 on: November 30, 2015, 10:38 PM »
What a mouthful. In my personal experience. I have not used the mafell  I think the makita is better than the festool.  It's light got a little more power and capacity and it's got the scoring function and bevel rail lock. Blade change is easy enough. It's only weakness is fewer blade options.
Offline Lbob131
« Reply #8 on: December 02, 2015, 02:24 PM »
Hopefully  the Mafell   jigsaw  design will be copied  soon  by other reputable manufacturers  and the cost will be brought down.
Fein  used to  have a monopoly  on the multimaster  but now  the machines    and blades  are made by multiple manufacturers  which has left them a lot cheaper.
Offline jobsworth
  • Festool Baby.....
« Reply #9 on: December 02, 2015, 02:30 PM »
1st post?????
Gives the phone number of the new dealer in the US?
Me thinks this is more then a unbiased review
Offline Wuffles
« Reply #10 on: December 02, 2015, 02:58 PM »
1st post?????
Well, there's only one dealer in the US isn't there?
Tool list updated to reflect knowledge :: hammer, screwdriver, one pozi bit, and another bigger hammer.
Offline Holmz
« Reply #11 on: December 02, 2015, 03:54 PM »
1st post?????
Looked pretty unbiased.
It is hard not to be biased towards the tools once you use them.
Offline teocaf
« Reply #12 on: December 02, 2015, 09:34 PM »
I'm of the opinion that the word "soon" above is just wishful thinking. If Mafell did indeed redesign the jigsaw and won some kind of product of the year in 2011, there are probably some patents that will hold for quite a while.  I'm just speculating--I don't have any inside info.  I have used a Fein Supercut for many years before the 'knockoffs' came to market, and I know of one instance where the cheaper version of another brand is toast while mine is still going strong even after rigorous use.  Not exactly conclusive evidence, but the point I'm trying to make is that if you feel you need a premium tool, try to get it as soon as you're able rather than wasting all that time just waiting around.  After all, the cost of the tool is only one component of its value.
Offline teocaf
« Reply #13 on: December 02, 2015, 09:49 PM »
1st post?????
Everything is biased in some way or another, but I would give the guy the benefit of the doubt based on what I read in that novel of his.  If anything, he's guilty of sloppy editing; there's a lot of repetition of the same points.  Maybe he has an exuberant nature about these tools (or perhaps some kind of 'forum tourettes'), who knows.  Or maybe he's trying to be the James Joyce or the William Faulkner of the forum world...
I think that all the info/opinions that he provides have already been stated in similar threads by others.  Except for that claim about the stainless cutting;  I would also like to see if he responds and clarifies that a bit more. @Geo
« Last Edit: December 02, 2015, 09:51 PM by teocaf »
Online Cheese
« Reply #14 on: December 03, 2015, 12:05 AM »
@teocaf & @Wuffles
You two characters are my favorite on-line humour.
@leakyroof
I use a Milwaukee 14" 6190-20 cold cut saw to cut stainless bar stock with an Evolution stainless blade that turns at 1500 rpm. The Evolution blade outlasts Milwaukee's stainless blade by a factor of 2:1.
I also use a Milwaukee 8" 6370-21 saw to cut 3/4" thick aluminum at 3700 rpm. I'm still interested in finding out at what speed and with what blade the OP cuts 3/8" stainless. That's a tough row to hoe. [tongue]
 Time's on my side...[popcorn] [popcorn] [popcorn]
Offline jobsworth
  • Festool Baby.....
« Reply #15 on: December 13, 2015, 04:59 AM »
Notice the OP hasn't posted anything else.......
I rest my case
Offline Wuffles
« Reply #16 on: December 13, 2015, 05:07 AM »
I rest my case
Probably got banned.
Offline Holmz
« Reply #17 on: December 13, 2015, 05:50 AM »
I was using the red tools on the MFT today.
Just like XMAS with the red-n-green.
Offline Peter Halle
« Reply #18 on: December 13, 2015, 06:10 AM »
I rest my case
Nope on the ban.  Joined on the 29th, spent 5 minutes on the 30th posting in this topic (which would seem to me that it was composed separately and then pasted) and then hasn't spent more time logged in to the forum.
That doesn't mean that he doesn't read the info here; just means that he hasn't logged in.
Offline GhostFist
« Reply #19 on: December 13, 2015, 07:09 AM »
It's a conspiracy!
Offline Wuffles
« Reply #20 on: December 13, 2015, 07:21 AM »
Offline jobsworth
  • Festool Baby.....
« Reply #21 on: December 13, 2015, 01:57 PM »
 [2cents]
« Last Edit: December 13, 2015, 01:59 PM by jobsworth »
Online Cheese
« Reply #22 on: December 13, 2015, 02:35 PM »
 5 minutes to post...[jawdrop]...it took me 2 Diet Cokes just to finish reading it.
Off topic...Peter is that a new puppy?
« Last Edit: December 13, 2015, 05:49 PM by Cheese »
Offline Peter Halle
« Reply #23 on: December 13, 2015, 03:47 PM »
Regarding the avatar, unfortunately no.  That was my baby girl Goldie Hawn who left the earth yesterday after 12 years and so many devoted hours of love and guarding me thru tougher times.  Rather unexpected.  However, on Tuesday night there will hopefully be picts of a new family member.  Mac always loved the camera - maybe ?????? will also.  We thoroughly expected Goldie to help mentor and coach the new pup and it had been in the works for about 6 weeks.
Offline Wuffles
« Reply #24 on: December 13, 2015, 05:31 PM »
Sorry to hear that. Genuinely Peter. Great name too.
We're going to have a litter from my Wife's Golden Retriever next year, if I can stomach the stud costs.
Offline Knight Woodworks
« Reply #25 on: December 13, 2015, 05:35 PM »
Peter,
Sorry to hear of the loss of Goldie. Hope the new pup brings a smile.
John
Online Cheese
« Reply #26 on: December 13, 2015, 05:53 PM »
So very sorry to hear that Peter [crying] especially when you're not expecting it. [sad]
Anxious to see the new addition. [big grin]  [thumbs up]
Offline jacko9
« Reply #27 on: December 13, 2015, 08:53 PM »
Good post to stimulate discussion but, on a Festool Web Site it's not going to be very popular.
I have a Large Table Saw so as far as ripping solid stock a track saw is not in the equation but, for a track saw to rip sheet goods "only" I like the Mafell MT55cc because of the track connectors and the quality of the Splinter Guard material.  I don't want to mess around with 9' tracks and I need a connector that stays together solidly for multiple cuts.  The Festool Splinter Guard material that I seen at my local Festool dealer looked pretty ragged as far as alignment goes and I'm not a big fan for stick on material.
If I didn't have a shop already set up with Table Saw with a Sliding Table and other tools that are in the Festool System I might be interested in the Total Festool System but I have the shop space to have individual (already purchased) machines.
I might be interested in the Mafell Jig Saw since I'm not totally impressed with my Festool Triton but with a bandsaw I'm not in a hurry to make a replacement decision.
Service and customer support wise, Festool wins hands down in my limited experience (but then again Shane is gone) ;-)
Jack
Offline GhostFist
« Reply #28 on: December 13, 2015, 10:18 PM »
There are a million factors into what makes a purchase best for YOU.  Your reasons for declaring what's best for YOU, is an opinion. Everyone's criteria is slightly different.  There is no final say but your own.  Both festool and Mafell make excellent products wether you choose between either of them, or something else altogether, is your choice alone. opinions of others might interest you, or differ from yours completely. That's what makes us individuals. What unites us on websites like the FOG or MUF, ultimately, is making stuff out of wood. Just keep building, there is no conspiracy.
Offline Holmz
« Reply #29 on: December 14, 2015, 12:57 AM »
There are a million factors into what makes a purchase best for YOU.  Your reasons for declaring what's best for YOU, is an opinion...
Actually the reasoning and the reasons are the most useful part.
It is like reading "I bought a corvette because it accelerates the best."
Or
"I bought the corvette because it stops the best"
Both or neither may be true, but as an example they're completely different justifications that form the reason of what is important.
