Author Topic: Kapex KS 120 REB Set-UG GB 240 volt  (Read 4390 times)
Offline Jiggy Joiner
« on: April 24, 2019, 02:45 PM »
Hi all, well after nearly a week of owning the Kapex KS 120 REB, and almost constant use, I thought I’d give my thoughts so far.
As a long time tradesman I’ve had all kinds and makes of mitre saws, from 150mm (6”) to 300mm (12”) saws, mainly from the Elu, Makita and Dewalt’s ranges. I may of been lucky but, have never been disappointed with any of them, in fact quite the opposite.
Up until very recently, I/we didn’t need another mitre saw but, had heard many great reports about the Kapex 120, and unfortunately a good few not so great reports regarding motor issues, smoking and failures.
I found out through meeting other trades that these failures were more than just rumours, and very recently met another unfortunate owner who told me his story but, the fact that he went on to say he was not put off in any way, and would stick with the Kapex spoke volumes for me.
It seems an unfortunate fact that a small percentage of these saws have failed but, a lot more have proved to be very durable. I just hope mine is one of the more durable variety.
Ok, due to various reasons, we found ourselves needing a new bandsaw and mitre saw. The bandsaw was a done deal but, I was still doubtful of what mitre saw to buy?
Then because Festool had released a new Kapex 120, I was again drawn to it, after getting some advice mainly here and in the trade, I decided on the KS 120 REB SET-UG.
As I mentioned the first saw turned up badly damaged, and was quickly collected and replaced.
Since then it’s been constantly used for cutting mainly 4” x 2” and 6” x 2” and 18mm and 12mm plywood. It’s been a revelation to be honest, as other owners know it has some great features and touches that make using a mitre saw, a lot easier.
I calibrated the measures on the side extensions, and they are spot on. The saw was cutting square and true out of the box. The lasers were fine but, I fine tuned them for my way of working.
The UG cart and extensions are very easy to set up and take down, and makes mobile or workshop use very quick, easy and accurate.
I nearly just bought the saw and was going to plant it on a station in the workshop but, I’m so glad I listened to advice and went for the UG set.
The dust extraction at first, even with a 36mm hose wasn’t quite as good as I was expecting if I’m honest but, after reading up on reviews etc, I adapted my old habits to mimic suggestions that I’d read, and saw a marked improvement instantly!
I am now actually very happy with the extraction even with a 27mm hose.
The cuts, both cross cut and mitre, and bevels are superb! As smooth as a baby’s bottom so to speak.
Yesterday, I did lots of trench cuts and was very impressed, so, so easy.
The angle finder is a nice touch that will get a lot of use, as I’m getting older and more lazy.
So, so far, so very good, I am honestly very pleased with it, and have already got a bit possessive with it haha!
The variable speed although not new to me with miter saws is very welcomed. A great range of angles and bevels will cover nearly any situation.
I love the easy to read scaling, and the positive locking of the miter and bevel facility, and the fine tune bevel adjuster is great. Another welcomed surprise is the relatively low weight for this size of saw, very manageable.
The footprint of the saw is more than acceptable to me also, especially when space is limited.
I think it’s reassuring that for the most part, the latest design isn’t too far removed from the previous version. I like the slide out base extensions, these will come in handy when the full stand and extensions aren’t needed, they are easy to slide out and lock, and another nice touch.
I think I’ve briefly covered most points.
No real criticisms but, maybe a work light might of been handy? Not a problem though.
The other thing I can’t get used too is the sound of the motor, especially on lower speeds but, when I removed the blade it was almost gone, so I guess it’s like a speaker effect.
It’s like a grating noise that I’ve noticed in many videos, and figured it wouldn’t sound like that in the flesh but, it does.
However, I have always thought the same about the TS55, they all sound that way too. A characteristic of these type of motors I’m sure.
Anyway, I love the saw and am glad I went for it, and advise anybody considering one, to go for it, you won’t be disappointed, I’m not and I’m known for being fussy.
Today a new work piece clamp arrived from direct Festool to replaced the damaged one, so that’s good and sorted out now.
I did email Festool UK with photos of the delivery damage, six days ago now but, as of yet, have not heard from them? I would like a reply, even just as an acknowledgement. Fingers crossed.
I’ll update my review on the Kapex when it’s seen some more action.
 [thumbs up]
« Last Edit: August 08, 2019, 02:48 AM by Jiggy Joiner »
Offline ChuckM
Re: Kapex KS 120 Set-UG GB 240 volt
« Reply #1 on: April 24, 2019, 03:13 PM »
You didn't cover it, because you have yet to use it: The quick-release hold-down clamp is not only the best in any mitre saw, but is also the one that will actually get used day in and day out. Be honest. Who would use the screw-type clamp on every cut? I use the Kapex clamp 99% of the time. For shorter pieces, use a bridge with the clamp.
Edit: Please do use a clamp whenever possible. I just read elsewhere that someone this week got a finger cut off on the mitre saw and the surgeon was arranging to have part of the finger attached with a toe.
Start the clock: you will have at least three years of worry-free use of the saw (mine is now 4 years old with no issues).
« Last Edit: April 24, 2019, 06:56 PM by ChuckM »
« Reply #2 on: April 24, 2019, 03:19 PM »
Thanks Chuck, to be honest, I was hankering after the clamp. They said to either keep or dispose of the damaged one, I’m going to try and straighten it, and have the luxury of two!  [big grin]
« Reply #3 on: April 24, 2019, 03:26 PM »
Hey Jiggy I purchased an extra clamp so I can have them on both sides. Depending upon what you’re doing it’s nice to flip-flop without removing and replacing clamps.
Glad you made the move... [smile]
Are you running a zero clearance fence or insert?
« Reply #4 on: April 24, 2019, 03:45 PM »
Thank Cheese, I’m going to make a zero tolerance fence, and kerf insert, should be all set then  [thumbs up]
Offline ChuckM
« Reply #5 on: April 24, 2019, 06:13 PM »
ZCI -- I use this product: https://www.fastcap.com/product/zero-clearance-tape
Edit: Fastcap, Amazon, Lee Valley Tools, etc. carry it.
About $1 a piece...after 4 years, I am still using the second one. The tape sits flush with the table. To make a wooden ZCI for yourself, you probably would spend 30 mins to an hour.
« Last Edit: April 24, 2019, 06:25 PM by ChuckM »
« Reply #6 on: April 24, 2019, 06:17 PM »
Thanks Chuck, I hadn’t seen that  [thumbs up]
« Reply #7 on: May 23, 2019, 02:18 PM »
The Kapex has made a lot of cuts and a lot of trenching, and I seem to be getting more attached to it by the day, and even get a bit nervous when somebody else uses it  [mad]
So far so good though, and don’t regret the purchase at all, we’re even considering buying another but the piggy bank needs topping up.
I have now fitted the zero clearance fence, and made a few kerf inserts, which make a noticeable difference to the edge of the cuts.
I love it, and long may it continue
Offline ChuckM
« Reply #8 on: May 23, 2019, 03:15 PM »
Quite a color match, both the fence and insert. By design?
The motto for any Kapex: Use it or lose it!
« Last Edit: May 23, 2019, 08:06 PM by ChuckM »
« Reply #9 on: May 23, 2019, 03:33 PM »
The motto for any Kapex: Use it, or lose it!
Hi Chuck, we had a lot of matt black paint left over from making some exhibition stands, so I thought I’d try it, I think it looks pretty good, what do you reckon?
Offline ChuckM
« Reply #10 on: May 23, 2019, 08:00 PM »
The dark color scheme matches the handle, knobs, etc. well.
I use this product for all my Festool moving parts, on the Kapex rails as well as for the DF500's:
« Reply #11 on: May 24, 2019, 01:44 AM »
Thanks Chuck, I’ll see if I can source some. That’s one of the many things I love about your country and the U.S., you can get just about anything you want over there.  [thumbs up]
« Last Edit: May 24, 2019, 02:20 PM by Jiggy Joiner »
« Reply #12 on: October 15, 2019, 01:10 PM »
Looks Legit! Good to hear that you are happy with your new Kapex.  [smile]
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Re: Kapex KS 120 REB Set-UG GB 240 volt
« Reply #13 on: October 15, 2019, 01:24 PM »
Thanks Henrik.
Offline johnsayen
« Reply #14 on: December 26, 2019, 02:52 PM »
Hello,
Would you mind sharing the suggestions you mimic'd to improve the dust collection? Also a question for everyone: What is the recommended 36mm hose to use, as it looks like the minimum size is 3.5m?
thank you.
Offline nkpearson
« Reply #15 on: January 10, 2020, 06:28 PM »
I just got back from the dealer with my new Kapex KS 120 REB.  Super excited to finally get this new tool in the shop.
Offline Mario Turcot
« Reply #16 on: January 12, 2020, 06:43 PM »
Aren't you worried about binding? Just a question, to me having a clamp on each side is prone to binding. Maybe not  [scared]
Mario
Offline ChuckM
« Reply #17 on: January 12, 2020, 06:52 PM »
Having a clamp on both sides of the fence is convenient, saving the need to remove the clamp especially when it is an angle cut. Yes, only one of them should be used at a time, although I have seen videos in which the operator clamped down the workpiece with both clamps. They just showed that many videos usnig table saws, routers, etc. out there featured inappropriate or unsafe practices.
Offline FestitaMakool
« Reply #18 on: January 12, 2020, 07:08 PM »
I have used these clamps on both sides simultaneously, however I’m careful, and scared of binding too. I do the cut slowly down and let the saw bottom out and release the trigger to let the blade come to a halt before touching any of the pieces.
Using the clamps or not, holding steady and let the blade slow down before lifting the saw is the safest. At least what I have learned to do. It’s at the moment the cut is done when one becomes uncareful, lifting the blade and letting go of the hand that holds the stock is dangerously when the blade spin at almost full speed.
Offline John1102
« Reply #19 on: January 12, 2020, 08:16 PM »
Glad you like the Kapex.  What bandsaw did you end up going with?
