Author Topic: Just Arrived At My Door - SYS-AZ Drawers 500692  (Read 26037 times)
Offline PreferrablyWood
Re: Just Arrived At My Door - SYS-AZ Drawers 500692
« Reply #30 on: September 25, 2014, 04:50 PM »
I think the wait for the Festool tools in the US is also very unfortunate, it would be so great if we all could get on stream at the same time with new tools as the knowledge base would increase exponentially, it' seems there are so many creative people in the US that really stretch the capabilities of the tools and love to tell about it, so yes I have access to the new Festools sooner than the N.Americas but I'm not smug about it no no no...
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Frank-Jan
« Reply #31 on: September 25, 2014, 05:32 PM »
491923 Telescopic Drawer, SYS-PORT/TA/2
Yes, at $125 each USD (ouch!)
There's also an in-between solution: the metal drawer for the tanos tresor: link
Offline Healeyjet
« Reply #32 on: November 06, 2014, 06:51 PM »
Jonny, have you had a chance to install these yet?  Do you have an updated impression?
Ward
Offline jonny round boy
« Reply #33 on: November 07, 2014, 01:44 AM »
I got these drawers with the intention of doing a review, as I had a couple of spare days at the time. Unfortunately something came up & I never got the review done. The drawers are still sitting in the boxes...
Now it's been announced that these will be available in the US on 1st December, I'm going to try and find an opportunity to do a full review before then. I've had a couple of PM's asking for more info too.
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Offline sl_1800
« Reply #34 on: November 08, 2014, 10:05 PM »
Johnny can you tell us the exact dimension of the drawers?  I don't believe what I see on the web sites.
Check out my blog at www.woodshopblog.wordpress.com
Offline GarryMartin
« Reply #35 on: November 09, 2014, 02:31 AM »
The drawers sizes are spot on - 426mm wide x 373mm deep x 57 mm high. The SYSTAINER drops into an approximately 400mm x 300mm "hole". The manual is available online - https://www.festoolusa.com/media/pdf/706994_002_MonAnl_SYS-AZ_Auszug%20.pdf and contains details for building cabinets to house them.
Which measurement did you think was wrong? If it's the depth, it's probably because the 350mm slides extend beyond the outer dimensions of the plastic tray.
Offline sl_1800
« Reply #36 on: November 09, 2014, 12:07 PM »
Thanks Garry, the sites here in the US that have them available for pre-sale state them as 396mm x 396mm.  I knew that had to be wrong.
Offline jonathan-m
« Reply #37 on: November 09, 2014, 12:18 PM »
What I dislike about the drawers, and also the metal sysports, is that the slides don't pull out far enough to fully have the lid of a systainer open.
Festool: 2x MFT/3 // OF-1400 // MFS-400 & 700 // RO-90 // SYS-ROLL // VAC-SYS SET SE1 // CT-ASA CT 26/36/SB // KS 120 EB & UG-L & R //  VECTURO OS 400 EQ-Set  // DSG-AG 125 // DSC-AG 125 // DSC-AG 125 FH // HK 85 EB // HK 55 EB
Protool: 2x VCP 260 LE AC // PDP 20-2 // WCP-32
Mafell: MT55cc // P1cc // DD40P // Erika 85 Ec
Offline Tom Bellemare
  • Inactive Member
« Reply #38 on: November 09, 2014, 12:55 PM »
Mine do.
Classic:
T-Loc
EDIT: Added images
« Last Edit: November 09, 2014, 01:05 PM by Tom Bellemare »
Offline jonathan-m
« Reply #39 on: November 09, 2014, 01:52 PM »
To clarify what I mean is that the lid and or locking knob still "slam" for lack of a better word, against other systainers/sysport. It would've been nicer if they pulled out further for a few more cm so that doesn't happen.
Offline Birdhunter
« Reply #40 on: November 09, 2014, 02:39 PM »
I built a set of pull out drawers into two frames to provide quick access to my most used Festool products. I used 16" over-extension slides I bought from my local Rockler store.
The drawers pull out far enough to have the Systainer tops fully open and even back over 90 degrees so they stay open without me holding them.
I think the load rating on the slides was well over 50 pounds.
The whole thing is mud ugly, but inexpensive and very functional.
Birdhunter
  • Inactive Member
« Reply #41 on: November 09, 2014, 02:56 PM »
I still don't understand the issue you're having, Jonathan. My SYS-Ports work perfectly with either Classic or T-Loc Sytainers. I pull out the drawer, open the lid, and everything stays just as I opened it all day or, sometimes, for days.
I also commonly use a SYS-UNI for screws, etc. and though it's lid stays open fine, the hard plastic content lid won't stay open on its own. I don't consider it a big deal because while I'm fishing for screws, I seem to always have the other hand free if need be to hold that internal lid up.
Incidentally, I consider Antwerp one of the coolest places on Earth.
Offline jonathan-m
« Reply #42 on: November 09, 2014, 03:03 PM »
Thanks Tom :) I do realize it's nitpicking
« Reply #43 on: December 19, 2014, 10:59 AM »
I've now (finally!) done my video review of the drawers! [big grin]
