Author Topic: HSK 80 x 130 Hand Sanding Block and hoses  (Read 127186 times)
Offline SRSemenza
« on: July 28, 2013, 01:06 AM »
I purchased the HSK 80 x 130 Hand Sanding Block (496962) thinking that a block with DC could be handy even around the shop. I have become so accustomed to not having dust in the air when sanding that I now even notice it from small hand sanding jobs. Even from just cleaning up board edges. The 80 x 130 seemed like the size to get since it is about the size of most traditional blocks. It also uses the same abrasive sheets as the LS130 (which I already had) and the RTS400.
I also got two different hoses to use with it. One Anti - Static (456745) and one Non- AS (495019).
The block is a nice size with a well shaped grip.
In some ways this review is more about the hoses than the sanding block. Suffice to say that the block sands as it should  [smile]
90405-0           90407-1
This picture shows the D27 , D22 AS, and D21.5 (D22) non-AS hoses side by side. The block can be used with any of these.  There is a significant difference in outside diameter of the D27 and the D21.5 as can be seen in these pictures.
90409-2
90413-3          90415-4
The non-AS 21.5 can be attached directly to the sanding block air control fitting as shown in the first picture above.
The D27 and D22 use a rubber downsizing adapter to allow the regular hose connection to fit the block port.  The AS D22 could be attached directly but the fitting is loose  in the hose and would need to be built up with a couple wraps of tape.
90417-5      90419-6
The best hose to use  with the block is the D21.5 non-AS. It is really light weight and super flexible. It hardly was a hindrance at all.  The following two  pictures are to show the flexibility. One thing to note is that this hose does not come with any tool end connector. The connector comes with the sanding block, and has a suction let off built in. I found that it worked well about half way open with the vac (CT33) set to  about 2/3 power. This hose is very light weight and thin walled is obviously intended for use with the sanding blocks.  I would not expect it to hold up well to a lot of abuse such as crushing or being folded into a crease / kink. I am not going to test its durability to the breaking point. It should be fine for its intended use.
90421-7     90423-8
The D27 is OK in a pinch but quite clunky with the regular hose connector, not real flexible  and really too heavy.
90425-9
The D22 AS is just about as clunky and heavy feeling on the block. It is a little more flexible. This is an interesting hose in that at the vac end it starts out as a D27 and gradually tapers to the D22 at the tool end. I actually think this might be a good hose to use with jig saws.
90427-10
Here are a couple in use shots. It was nice to be able to give a light hand sanding between coats of laquer on this piece without  having laquer dust in the air.
90429-11      90431-12
It can also be used very nicely with interface pads for roundovers and such.
90433-13
« Last Edit: July 28, 2013, 01:35 AM by SRSemenza »
Offline Untidy Shop
Re: HSK 80 x 130 Hand Sanding Block and hoses
« Reply #1 on: July 28, 2013, 06:47 AM »
I purchased this mainly for touching up some drywall plaster external angles on our owner build, once the plasterer and I had finished the overall sanding. It has worked well for this, although I agree the larger diameter hose is restrictive.
I have found that the vacuum  should be turned right down and the gate on the connector left open to prevent the pad being sucked too much down on the work.
I am yet to use it on wood, but Seth's review offers new horizons to all who want to sand by hand dust free.
« Last Edit: July 28, 2013, 08:58 AM by Stephen B »
Offline Bikeboy80
    • Drumm Design Remodel
« Reply #2 on: July 28, 2013, 07:35 AM »
I love my hand sanding block [smile] I was using it this week to sand putty marks on new installed baseboard before paint.
You're right it works with the larger hose but it does take a bit of moving around to position the hose.
Where did you pick up the 21.5 hose?
The Green Koolaid sure is sweet...
Kapex w/crown stops, Domino DF 500 Set, Syslites, PS300, RTS400, RO150, OF1010 w/LR32 Kit, TS75, 75" + (2) 55" rails, RO90, ETS125, RAS, Custom abrasive systainer, CTmini, CT36AC w/blastgates, PLANEX w/harness, TI15, T12+3 set, MFT/3 cross cut, Universal Cleaning set, Turbo Suction Brush, 12 drawer Sortainer, Extra Systainers with job specific tool collections
Offline Gone
« Reply #3 on: July 28, 2013, 07:48 AM »
Good review Seth. My son and I have been using the Mirka version of the sanding pad for 2 years now. The son has done a lot of drywall with the block and found it to remove the dust very effectively. I have 2 with different grits that I use all the time in the shop. You would be surprised how well the hoses hold up over time. The vacuum adjustment valve on the Festool block is a nice touch. Might have to buy another block to get the valve.
John
Offline SRSemenza
« Reply #4 on: July 28, 2013, 11:59 AM »
The vac / suction setting I used worked for what I was sanding but I am sure it would have been too much on larger flat surfaces.
Offline polarsea1
« Reply #5 on: July 28, 2013, 11:57 PM »
Thanks for the Review Seth, I didn't even know such a thing existed. Looks ideal for hand sanding primer, clears, etc.
Bill
Offline SRSemenza
« Reply #6 on: July 30, 2013, 10:58 PM »
On second thought the hose is 5 meters long I can spare a few inches to test it to the breaking point.
Folded over tightly and worked back and forth a few times.       ::)        After  .............
90544-0               90546-1
After being ground on the concrete under my work boot heel.   :o
90548-2           90550-3
That's a K-Body as tight as could crank it.    [blink]                       After...........................
Then worked back and forth about 20 times to see if it would crack.
90552-4          90554-5
And  lets get serious.      [eek]                    After ...........................
90556-6         90558-7
A little worse for wear but it never ended up with any holes , and I was able to squeeze it back to round  and use it.  Nothing scientific here but it turns out that the hose can take some abuse after all. [thumbs up]
« Last Edit: July 30, 2013, 11:01 PM by SRSemenza »
Offline Kev
« Reply #7 on: July 31, 2013, 05:51 AM »
Were you tempted to get the kit of four blocks? Works out so much cheaper and they're on special down under.
Offline leakyroof
« Reply #8 on: July 31, 2013, 08:48 AM »
  That 'kit' is how we here in the USA saw the blocks for years when they were NAINA. [sad]
 For my purposes, I don't have a need for the long and narrow sanding blocks that are available and part of that kit. I'm much like Seth in that I bought the smaller block, and I already own that size abrasive for the RTS400 and LS130 sanders.
 I also bought the RS2 sized block for larger work, but fully expect that the small block will be my most used out of the two.
Offline SRSemenza
« Reply #9 on: July 31, 2013, 10:38 AM »
I don't think the kit is available here. I probably would have passed anyway. I don't for see using anything but the small one. I  But I would buy others if the need arises.  Most likely the 115 x 226 would be next. Just depends what you do and how much you like hand sanding.
Offline Tom Bellemare
  • Inactive Member
« Reply #10 on: July 31, 2013, 10:50 AM »
There are four of them sold here but I'm not aware of any kits.
One uses the same paper as the  LS 130 or RTS 400, one uses the same paper as the RS 2, and the two others use special-sized paper. It is 80mm x 400mm with perforations to make it into two sheets that are each 80mm x 200mm.
Offline fdengel
« Reply #11 on: July 31, 2013, 11:18 AM »
Interesting that a search on festoolusa.com using the part number gets no results.
Offline Kev
« Reply #12 on: August 01, 2013, 06:16 AM »
Maybe I should have set "set" instead of "kit". In Oz we can get all four for $AUD350 at the moment.
« Reply #13 on: August 01, 2013, 10:03 AM »
Seth,  great review especially the hose durability test. I'm alittle shocked you haven't made block sander and hose /accessories  fit neatly into systainer. What size sys would it all fit into?
Offline SRSemenza
« Reply #14 on: August 01, 2013, 11:42 AM »
Well hey now, look at that. A Sys- II holds the 5m hose perfectly  [big grin]
I may not keep it in a Systainer. I want this to be handy so it will probably be kept hanging near the vac , ready to use.
90569-0
And the attic  compartments will hold the 80 x 130 abrasives just right  [cool]
90571-1      90573-2
« Last Edit: August 01, 2013, 11:44 AM by SRSemenza »
Offline elimelech12
« Reply #15 on: August 01, 2013, 01:12 PM »
Awesome review...will have to buy a the d21.5 non-a and block...and maybe a sys2...and some ls130 pads....and my wife is hating this forum. [scared]
Sold my tools but kept a few Fes-tools...just in case.
Offline greg mann
« Reply #16 on: August 01, 2013, 02:00 PM »
Seth,
I am still a little concerned about the durability of that D22 hose. Do you suppose you could test it with a blowtorch for me?
Greg Mann
Oakland, Michigan
Offline SRSemenza
« Reply #17 on: August 01, 2013, 05:44 PM »
Seth,
Yah, pretty sure it will melt.    [scratch chin]
 But seriously I am surprised that it took that much abuse without cracking or getting a hole.  Because it is very thin and light weight.
« Last Edit: August 01, 2013, 05:47 PM by SRSemenza »
Offline richk
« Reply #18 on: August 01, 2013, 06:59 PM »
That systainer looks like a SYS 2 with Attic  497852. Is that right?
As best I can tell, that is a discontinued item. Does any vendors have one for sale? Or other info or alternatives?
Rich
Offline SRSemenza
« Reply #19 on: August 01, 2013, 11:11 PM »
Rich
Yes, it is a Sys - II T Loc with attic. Tanos as opposed to Festool. Available here  http://www.leevalley.com/US/wood/page.aspx?p=68750&cat=1,43326,68749
Offline richk
« Reply #20 on: August 14, 2013, 08:45 PM »
thnx for the idea and the link
RichK
Offline EdL
« Reply #21 on: August 30, 2013, 10:43 AM »
Great review Seth. My sanding block & hose just arrived.  ;D
What trick did you use to push the adaptor into the hose? It'll only go in halfway by hand.
Ed
Offline SRSemenza
« Reply #22 on: August 30, 2013, 10:54 AM »
Ed
No trick. The one I have just pushed in hard.  Maybe warm the hose up a bit?
  • Inactive Member
« Reply #23 on: August 30, 2013, 11:09 AM »
Wet the fitting with saliva and "screw" it into the hose?
Offline EdL
« Reply #24 on: August 30, 2013, 11:41 AM »
Got it, a little heat from the blow dryer softened the hose....don't think I'll have to worry about it coming apart.
Thanks.
Ed
Offline F3STOOLVIKING
« Reply #25 on: August 30, 2013, 12:43 PM »
Hi Seth
Is it possible to use the profile pads for the LS130 with the hand sanding block? Have you tried it? Might be handy for sanding edges.
Festoolviking
Festoolviking
  • Inactive Member
« Reply #26 on: August 30, 2013, 12:45 PM »
Hi Seth
Festoolviking
I'm not Seth but... Those pads for the LS 130 have a special mount. These HSK's have a hook & loop face.
Offline SRSemenza
« Reply #27 on: September 01, 2013, 03:02 PM »
Hi Seth
Festoolviking
No, but this is an intriguing  idea  [scratch chin]
Offline elimelech12
« Reply #28 on: September 03, 2013, 05:53 PM »
Just got my hose and sander today. It is awesome. I used it to sand down a little heart my wife and I made.
Ahh, I love dustless sanding!
Offline Brev
« Reply #29 on: September 17, 2013, 06:34 PM »
How well do you think these would work for sanding small drywall sections? Do you think the Mirka abranet paper and vacuum would minimize dust and clogging?
Offline leakyroof
« Reply #30 on: September 17, 2013, 07:12 PM »
I think Granat and Brilliant 2 work well for this application . Abranet may get some clogging, but with the coarse to medium grits, it's not as likely as using their 320 and higher grits.
Offline Brev
« Reply #31 on: September 17, 2013, 08:47 PM »
Interested in this combination, I only deal with plaster when I need to patch a hole from an install or fix a dent but the drywall dust drives my crazy.
Offline SRSemenza
« Reply #32 on: September 18, 2013, 12:45 AM »
It should collect the dust quite well. As far as the abrasives go I have  never used any of them on drywall.
Offline Untidy Shop
« Reply #33 on: September 18, 2013, 08:12 AM »
See reply #1 on this thread.
 [smile]
Offline leakyroof
« Reply #34 on: September 18, 2013, 09:54 AM »
OK, have to ask with THAT reply. Do you get to avoid drywall as a whole, or do something different than sanding? [blink]
Offline SRSemenza
« Reply #35 on: September 18, 2013, 11:01 AM »
Basically no drywall.  The couple of patches I have done for myself were pre- Festool and I just  sponged them smooth. Other than that I did a bunch of drywall in my parents house 25+ years ago.
Offline leakyroof
« Reply #36 on: September 18, 2013, 01:23 PM »
  You may now go play the lottery, as you are a very lucky person........ [big grin]
Offline SRSemenza
« Reply #37 on: September 18, 2013, 11:34 PM »
EXCELLENT !  [thanks]
Offline Kodi Crescent
« Reply #38 on: November 12, 2013, 07:49 PM »
Ooh!  I can answer this one (albeit a bit late).  It works great!  I used 220 Granat.  Turn the vac down all the way, and open up the air port all way and have at it!
Offline andreasg
« Reply #39 on: August 07, 2014, 02:41 PM »
Great review! Would all the LS130 equipment fit, like the one for corners?
Offline SRSemenza
« Reply #40 on: August 07, 2014, 04:43 PM »
Hi, Welcome to the forum!  [smile]
None of the LS130 profiles, or attachments fit. It just uses the same size abrasive sheets and the interface pads also work. That would be nice if they did fit though.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #41 on: August 07, 2014, 04:57 PM »
Hi Seth
I wish that kit like this was easier to find on the various Festool web sites. It is almost as though you need to know a bit about a product in order to be able to find it. Try going to the sanding section of any Festool web site and see if you can spot these items - they are not there.
I have been using the Mirka/Abranet equivalent and now want to try this.
Many thanks for doing so many test on the hoses - I think that it was a good part of the system to focus on as I have damaged small hoses like this from other manufacturers which then ruins the investment.
« Reply #42 on: August 10, 2014, 08:29 PM »
I bought this for drywall.  I found that if I sand in a circular motion I can get a really nice finish.  I use the 150/5 on the first coat, and this on the subsequent coats.
Offline Walk On Wood
    • Walk On Wood
« Reply #43 on: August 10, 2014, 08:41 PM »
Regarding the 21.5mm hose, is there a tool end that will fit on so that it can be used with the Festool powered sanders? I've been thinking for awhile that I would like the increased flexibility this hose offers when I am sanding staircases and handrails with my rotexes/ets's/LS
The Green Kool-Aid is good!
Offline SRSemenza
« Reply #44 on: August 10, 2014, 09:14 PM »
No regular tool end for the gray 21.5. But maybe you could cobble one together. However it would not be anti-static.
    • Walk On Wood
« Reply #45 on: August 10, 2014, 09:18 PM »
Thanks Seth
Offline Pyotr
  • woodworking rookie
diameter of hose connector?
« Reply #46 on: August 22, 2014, 05:58 PM »
Seth, could you measure the diameter of the connector (the plug that goes into the dust extractor) for the 21.5mm hose?
I have a Protool VC171 dust extractor (discontinued), and I think it has the same size dust port als the Festools, but better to be sure before ordering  ;)
MFT/3 - TS55 - RTS400 - OF1010 - RO150 - C12 (NiCd) - DF500
Offline Alex
Re: diameter of hose connector?
« Reply #47 on: August 22, 2014, 07:08 PM »
They are the same diameter. Protool and Festool hoses are exactly the same.
Offline Pyotr
« Reply #48 on: August 23, 2014, 08:18 AM »
Thanks Alex!
Offline Brent Taylor
« Reply #49 on: September 18, 2014, 07:50 AM »
John
I have had my Mirka block sander for about a year and it has a valve on it near the hose attachment point. Mine may be different model, but you may want to check. Brent
Offline polarsea1
« Reply #50 on: September 20, 2014, 03:31 PM »
John
My Mirka block has it too, a rotating sleeve on the back of the block opens or closes a port.
Offline jobsworth
  • Festool Baby.....
« Reply #51 on: September 21, 2014, 07:20 AM »
You guys must get a kick out of me spending my $$$$$
 [thanks]
Offline leakyroof
« Reply #52 on: September 22, 2014, 04:13 PM »
 [thanks]
   Yup, that's what we live for..... [wink]
Offline wow
  • Inactive Member
« Reply #53 on: September 22, 2014, 07:32 PM »
 [thanks]
It's a dirty job, but somebody's gotta do it!
 [big grin]
Offline Gone
« Reply #54 on: September 22, 2014, 08:06 PM »
John
Thanx guys my latest Mirka has the rotating sleeve, I have 3 now, the original sander was given to by a Mirka rep, along with hose and a roll of paper. Totally impressed me. Can't beat the price either. Sorry Festool.
John
Offline polarsea1
« Reply #55 on: September 22, 2014, 08:24 PM »
I like the Mirka much better than the HSK, mostly because the hose is so small and manageable. I will say that I would prefer the Festool if they had a small hose because I have a lot of that paper on hand.
AAAbrasives.com has Abranet for prices comparable to the Festool abrasives.
  • Inactive Member
« Reply #56 on: September 22, 2014, 10:05 PM »
Which Festool hoses are you using for comparison? There are two that are specifically recommended for the hand sanders...
The most popular by far, in my experience, is a 21.5mm x 5m hose that is pretty flexible and friendly. It is non-antistatic but I don't think that's a big issue for most climates with hand sanding.
The other option offered by Festool is a 22mm x 3.5m antistatic hose. It will be significantly stiffer but depending on your climate, you may like the antistatic properties enough to prefer it. These antistatic hoses are currently limited edition items because they were discontinued in North America...
Kind regards,
« Last Edit: September 23, 2014, 01:57 AM by Tom Bellemare »
Offline SRSemenza
« Reply #57 on: September 23, 2014, 01:14 AM »
The most popular by far in my experience is a 21.5mm x 5m hose that is pretty flexible and friendly. It is non-antistatic but I don't think that's a big issue for most climates with hand sanding.
Kind regards,
That is the gray one in the review. It is extremely light weight.  And very flexible as can be seen in the pictures.
Offline polarsea1
« Reply #58 on: September 23, 2014, 04:56 PM »
Kind regards,
Hi Tom,
The Mirka hose is 3/4" vs. 27mm for the Festool.
If Festool offered a comparable hose or a whip I'd buy it.
    • Walk On Wood
« Reply #59 on: September 23, 2014, 06:43 PM »
Kind regards,
Hi Tom,
Polarsea- Festool makes a 21.5mm hose for hand sanding.  Here ya go: http://www.festoolproducts.com/Festool-495019-Hose-HSK-D21-5-5m-p/495019.htm
Offline polarsea1
« Reply #60 on: September 24, 2014, 01:43 AM »
I most humbly apologize - thought the only option was using the 27mm hose and I didn't read Tom's post closely.
Thanks for setting me straight.
Bill
Offline PreferrablyWood
« Reply #61 on: October 18, 2014, 05:40 AM »
Thanks Seth for the write up on HSK 80 x 130, hand sanding can be just as dusty and hazadous to your health as using a power sander so this is really on my list. I'll be getting the 21.5 hose as well. Too bad i don't have a sander with a 80 x 130 pad though, means I'll have to buy paper especielly for this application.. or else make a template and cut my own..
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
« Reply #62 on: October 18, 2014, 10:03 AM »
This block sander is the small Mirka sander rebagded  in Festool trims, so the Mirka products work and fit the Festool sander. I have had mine for sometime now and could not be without it. Both will interchange pieces and parts and papers. Peter Parfitt has a wonderful piece on his site, check out his sanding dust in the workshop, quite inlighting and should be seen by anyone who is near a woodworking shop, by that I mean loved one who maybe breathing the air in the home with a shop even near it. I have brought dust and other dangerous thing into my home without thinking and harmed my wife. Once was enough to teach me to change my ways when it come to dusts, my wife has a breathing condition that is harmful to her. So think about where the dust is going and where it is landing, and get good DC products like the Festool and Mirka. B
Offline Scott Burt
  • painter/writer/educator
    • Prep to Finish
« Reply #63 on: October 18, 2014, 01:52 PM »
Funny you should mention this piece, Seth.
We just broke it out this week and stuck synthetic steel wool on it for a super fine scrub down prior to our final satin coat on the cherry table we are finishing.
Gotta love a tool that is equally useful and wood and drywall.
Offline Saskataper
« Reply #64 on: October 18, 2014, 05:59 PM »
Although the Mirka and Festool vac sanding blocks look very similar they are a couple differences that make the Festool far superior in my opinion. Having used both for drywall the Festool has a built in interface pad and accepts the RTS paper meaning you can also use the interface pads for the RTS on the block. Also the base of the block has tapered edges that don't rub against adjacent walls if your sanding a corner. I didn't like the abranet at all for drywall as it leaves linear scratches in the drywall because of the waffle pattern. I do use the Mirka hose though as it I already had it but it looks pretty much the same as the grey Festool hose.
Offline andreasg
« Reply #65 on: May 22, 2015, 06:24 AM »
I have the Mirka one, BUT has anyone tried Festool with the CTL SYS yet? Since the suction can not be adjusted, the CTL is struggling like as if I blocked the airflow. Would gladly change to the HSK Sanding block and hose (since it is slightly wider in diameter). Let me know if anyone knows.
Offline SRSemenza
« Reply #66 on: May 22, 2015, 09:45 AM »
Does the hose you are using have the suction let off at the end? That would help. Though I find that I often use both the let off and turn down the suction.
« Last Edit: May 22, 2015, 09:49 AM by SRSemenza »
« Reply #67 on: May 22, 2015, 10:20 AM »
The Festool version comes with this little valve shown below. You can adjust the suction as you see fit. However, using a CT 22 on max vacuum and with the valve opened fully, there is still enough vacuum to adhere the HSK to a vertical sheetrock wall. Not by much, but it will stick lightly to the wall. That's the reason I turn down the suction on the CT 22 and then use the in-line valve to "fine tune" the amount of suction.
221434-0
221436-1
Offline andreasg
« Reply #68 on: May 22, 2015, 10:29 AM »
Well, i might help, but it's an issue even with just the hose. Without the sandingblock. Probably cutting off some length would help. I will test taking off 1 meter/40 inches.
Or how about they just upgrade this product with a possibility to adjust:)
A little on the fence on wether I return a Festool product for the first time or not. Need to try with a couple of electric sanders too. I never use full suction with those and my Midi either.
« Reply #69 on: May 22, 2015, 12:12 PM »
For anyone using the Dust Hub or something similar of their own, you can have a bit of extra air going in by opening an unused blast gate by a small fraction until you are happy with the noise from the CT or the suction obtained.
I have used this method with my Abranet hose and pad.
Offline rst
« Reply #70 on: May 22, 2015, 01:24 PM »
Just  for information's sake, Bosch has a hose that works as well.  I don't know the # as I have had them for years.
Offline andreasg
« Reply #71 on: June 03, 2015, 05:28 AM »
Thank you for your answers and suggestion. I´ve decided to return the CTL Sys. Not an easy thing to do, love the concept!!!!
But this is ment for small jobs, and the lack suction-adjustment is too big of a drawback for me.
If this issue will be solved by Festool I will for sure run back and get the updated version!
Offline Marcel71
« Reply #72 on: August 07, 2015, 04:08 PM »
Can the valve be removed from the sanding block and being used for the ctl sys and f.e a rts 400 to have suction control?
Offline SRSemenza
« Reply #73 on: August 07, 2015, 05:41 PM »
   The valve section only fits the 21.5mm hose. So , no, not with out some sort of home made adapter.
« Last Edit: August 10, 2015, 05:40 PM by SRSemenza »
Offline Marcel71
« Reply #74 on: August 08, 2015, 03:46 PM »
Seth, thanks for your reply.
Sounds good for me
So the adapter is removable and fits a 22mm hose.
So if i'm right and buy the sanding block and can use the adapter in a 22mm hose and connect to my sanders.
That sanding block is on my wishlist for a while  [big grin]
Offline SRSemenza
« Reply #75 on: August 08, 2015, 05:08 PM »
Sounds good for me
So if i'm right and buy the sanding block and can use the adapter in a 21.5mm hose and connect to my sanders.
@Marcel71   No.  The sanders have a fitting for the 27mm hose not the 21.5mm. You would need to make something to make the valve from the 21.5mm sanding block hose work on the 27mm power sander fitting.
« Last Edit: August 10, 2015, 05:41 PM by SRSemenza »
Offline Marcel71
« Reply #76 on: August 09, 2015, 12:00 PM »
Ok thanks, i'm gonna figure something. I'm gonna buy the sandingblock anyway 8)
Maybe ,when I got my sys ctl, I open it and take a look if I can build in an electronic speedcontrol myself.
Offline Holmz
« Reply #77 on: August 09, 2015, 05:45 PM »
I thought they were both made by Mirka...
Offline leakyroof
« Reply #78 on: August 10, 2015, 02:58 PM »
You're not alone with those thoughts.
I thought the same thing.. [cool]
Offline Holmz
« Reply #79 on: August 10, 2015, 04:45 PM »
It is like saying, "I would never want a VW when I could have a car designed by Ferdinand Porsche".
Offline Saskataper
« Reply #80 on: August 10, 2015, 04:53 PM »
Seth it's the really small hose 20mm? That doesn't have the fitting, 22 and 27 are the same fittings
Offline SRSemenza
« Reply #81 on: August 10, 2015, 05:38 PM »
Right I meant the 21.5mm gray sanding block hose in the posts above (changed them). But the valve won't fit the power sanders. Pretty sure it comes with the sanding block not with the hose.
« Last Edit: August 10, 2015, 05:43 PM by SRSemenza »
« Reply #82 on: August 10, 2015, 05:58 PM »
@SRSemenza
You are El Correcto...it's physically attached to the sanding block.
Offline Holz-Her
« Reply #83 on: September 01, 2015, 04:35 PM »
Where are the Mirka sanding blocks made ?
Offline leakyroof
« Reply #84 on: September 01, 2015, 04:51 PM »
@SRSemenza
  I moved the valve to my grey hand sanding Festool hose , works well that way, all that's left on either my Mirka or Festool hand Sanding blocks is the plastic port which connects to the valve/hose assembly.  The valve always stays on the hose too, doesn't work off when you remove the hose from a sanding block, which I think is pretty cool.
Offline jobsworth
  • Festool Baby.....
« Reply #85 on: September 07, 2015, 04:54 AM »
Has anyone used the valve on a reg Festool sander like the RTS400 or RO 90'etc, I wonder if it will eliminate swirl marks better then just lowering the suction
Offline Holmz
« Reply #86 on: September 07, 2015, 05:47 AM »
Well Mirka is either Finnish or Norwegian, but they could be make in China and maybe the FT ones are also from there... I dunno.
If you already have FT media then FT is probably best.
However I ordered a Mirka one over the weekend and I already have some of the abraidenet.
I was using the abraidnet on a 1/2 sheet sander and was surpised that there were swirl marks on the wood.  [eek]
I think that the Mrs had put on a 120 gr screen.
I chucked on a 240 and it was BB smooth. [cool]
Offline andreasg
« Reply #87 on: October 18, 2015, 04:55 PM »
Anyone tried this lightweight hose for electric sanders? We´re told to turn down suction to halv anyway. Just curiuos, since often the weight of the hose "messes up" the balance of some of the tools. And just got a reminder of this issue since I´m gonna give my ceilings a small "rub" with a sander before painting. Don´t have the 150 ec ets yet, but it´s probably next:) It´s a light one, but up on a chair with 8 feet of hose in the air, that changes a little.
Kind regards,
Offline Magpal
« Reply #88 on: October 19, 2015, 05:34 AM »
Has anyone tried to modify the HSK for use with LS130 pads? Would it be possible to get the pads working by attaching the "489504  base plate" spare part from LS130 on the HSK (using glue or another creative solution :) )? Does the LS130 base plate dust extraction holes line up with the HSK holes? Anyone with both LS130 and HSK would probably see if this is possible by looking at the base of the LS130.
Online neeleman
« Reply #89 on: October 19, 2015, 05:44 AM »
Yes the holes will line up with, because they both use the same sandpaper.
But you'll also need the spring load mechanism of the LS130 base plate (490302).
« Last Edit: October 19, 2015, 01:11 PM by neeleman »
Festoolian since 1998.
FESTOOL:
ISC 240 | OF1010R | AGC18 | TPC18/4 | TID18 | OSC18 | RTSC400 | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
CHP26 | VCP260 | DSC-AGP125 | DSC-AGP230 | DSG-AGP125 | DRP16
Offline andreasg
« Reply #90 on: October 19, 2015, 01:06 PM »
Not sure what I did wrong with my last post, but my comment was "hidden" inside the quote. Here it is:
Offline Magpal
« Reply #91 on: October 20, 2015, 04:24 AM »
(Attachment Link)
Thanks for the picture! The modification looks plausible, but it may not be worth it price wice compared to just buying the LS130 (okay, it is way more expensive, but at least you then get a proper tool).
Offline SRSemenza
« Reply #92 on: October 21, 2015, 12:26 AM »
      If thinking of using the gray hose ( super light) with power sanders remember that it is not anti-static.  Might be  an issue / might not.
Offline leakyroof
« Reply #93 on: October 21, 2015, 08:38 PM »
. Good point... [cool]
« Reply #94 on: October 28, 2015, 04:37 PM »
I'm thinking of making my own HSK 93 X 175 using a stick fix pad for the RS 300 EQ, my abrasives are all for this sander and I'm not interested in getting the 80 x130 size. I would make the bulbous top piece out of wood, and the suction section out of some suitable plastic material. The only thing missing would be the valve for controlling airflow.. that wouldn't be hard to rig up..
So I'd just need to buy the Stickfix pad, 21.5mm hose some wood for the "handle" material for the suction section and the valve. It won't be cheaper to make than buying the Festool block but will save me a bundle in abrasives..
Offline mike_aa
« Reply #95 on: April 10, 2016, 09:40 PM »
@SRSemenza
Resurrecting this old thread.  Based on your earlier review I finally pulled the trigger on the 21.5 hose and the HSK sanding block to go with it.  Seth, I was wondering if you are still finding yours useful and if you have any new insights.
Thanks, Mike A.
Offline tjbnwi
« Reply #96 on: April 10, 2016, 09:44 PM »
Not Seth---but I love my HSK and 21.5 hose.
Offline SRSemenza
« Reply #97 on: April 11, 2016, 10:11 AM »
Yes, I still use it. In my usage I would call it an occasional tool. But just the right thing for some jobs. Nothing new to add though.
Offline JimS_1984
« Reply #98 on: April 11, 2016, 09:27 PM »
Used mine today to knock down filler I had put in plywood voids I filled during the machine sanding phase.  All tools were put away and I was ready to start priming , and then saw these patches.  It was so easy to grab the HSK, with the long flexible hose and take care them.  Dust extraction is not perfect, but much better than old school.  Hobbyist here.  No regrets.
TS55, DF500, OF1010, Carvex, Vecturo, C15, CXS, ETC EC 125, RO90, CT 26
Offline BMAC
  • BMAC Construction & Consulting Ltd.
« Reply #99 on: April 12, 2016, 12:34 AM »
I use mine on flood repair projects and did so today to sand down the drydex (sparkle) filler I used to fill/smooth out new MDF casings mitre joints, after I glued the mitre joints with 2P10 adhesive.
Makes for quick work and minimizes dust contamination to the work area (not 100% and that's okay as flooring has been disposed of)
Bruce
Support services for the Fire and Flood Restoration Industry. Specializing in custom cabinetry restoration and millwork.
Offline mike_aa
« Reply #100 on: April 12, 2016, 11:57 AM »
Thanks to Seth and all of you who answered my question.  I plan on trying it instead of the RTS400 to sand a few small drywall ceiling patches to see how well that works.  It looks like I'll be finding lots of other uses for it down the road.
Mike A.
Offline Duck76
« Reply #101 on: April 16, 2016, 12:34 PM »
I grabbed one to sand some drywall touch ups while repainting our bedroom. Kept everything nice and tidy. Even the wife thought it was great!
Offline RKA
« Reply #102 on: April 16, 2016, 01:07 PM »
I added the interface pad for blending patches into the surrounding wall.  The set up works great for the smaller stuff.  Most of the mess is either contained or falls straight down rather than floating across the house. Love the small hose Seth recommended too, very light and flexible with more than enough length to allow me to work my way around a bedroom without having to reposition the extractor.
-Raj
Offline JimD
« Reply #103 on: April 23, 2016, 08:03 PM »
Instead of a smaller hose, I like to use a router speed control on my rigid shop vac when using my little Festool hand sander.  Works great.  My dust deputy gets most of the dust but the key thing is the dust doesn't go all over.
Offline w802h
« Reply #104 on: April 23, 2016, 08:19 PM »
In a pinch a 6 inch disk and a hole punch will cover almost all the bottom.  Sometimes there's a grit that I want that's "outside the box"
Offline Magpal
« Reply #105 on: April 24, 2016, 02:23 PM »
(Attachment Link)
(Attachment Link)       (Attachment Link)
Do you think it would be possible to use a SYS-I for the hose or would that be way to tight?
Offline JimS_1984
« Reply #106 on: April 26, 2016, 10:20 AM »
SYS-1 will be too tight.  I tried putting the 21.5mm hose and HSK-80-130 sanding block in a SYS-1, but had to move up to SYS-2.
Have a picture to illustrate, but the attachment is failing.
Offline JimS_1984
« Reply #107 on: April 26, 2016, 10:27 AM »
Once more...with feeling:
HSK 80-130 with 21.5mm hose in a SYS-1.
So yes, it's too tight.  SYS-2, on the other hand, will hold it comfortably,and is easy to pack-up.
« Last Edit: April 26, 2016, 10:33 AM by JimSpence »
Offline Magpal
« Reply #108 on: April 26, 2016, 01:18 PM »
Great, thanks for trying it out @JimSpence[smile] I will probably go for the SYS-II with lid compartments then.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #109 on: June 19, 2016, 01:05 AM »
I ended up putting my 21.5mm hose, and both my 80mm-130mm and 115mm-226mm hand sanding blocks into my empty SYS-3, that my 3.5m sleeved hose came in.  Still room for a small supply of abrasives as well.
Thank you Seth for starting this incredibly helpful thread on the Festool hand sanding system.   As of today, this thread has 42,249 views, and counting!
« Last Edit: June 19, 2016, 01:10 AM by McNally Family »
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline nycwoodworker
« Reply #110 on: January 04, 2018, 11:03 PM »
Reviving this old thread as it's incredibly useful for what I'm looking at!  The main reason I'm looking to use this is to keep dust from sanding between Primer/Paint coats (SW KA+).
For those who used it, I have a couple questions
1) Do you think that I'll still need to go over this with a microfiber cloth if I use the vaccum attached hand sander or would that be enough?
2) Would the suction, turned all way down on Midi and port open on this cause too much suction for a sanding between paint coats?
3) Is this as helpful on normal woodworking projects or mostly other uses?
Thanks everyone!!!
Offline SRSemenza
« Reply #111 on: January 04, 2018, 11:29 PM »
Thanks everyone!!!
I don't know specifically on that paint. But the suction as you describe should be fine. I do think you will still need to vacuum or otherwise go over the piece again to be sure you get as much  dust as possible off the surface.
« Reply #112 on: January 04, 2018, 11:38 PM »
Thanks everyone!!!
After using the hand sanding blocks, I go over the sanded piece with this:
https://festools-online.com/498527-festool-nozzle-universal-brush-ct.html
I also think it could not hurt to use your microfiber cloth just to make sure you get all the dust.
Offline rst
« Reply #113 on: January 05, 2018, 07:21 AM »
I use the vac sanding block, brush and then always use a tack cloth.
Offline CBRacerX
« Reply #114 on: June 23, 2018, 08:22 PM »
Thanks for this useful thread. I just got two HSK blocks and ordered the light and easy hose. Let the occasional drywall sanding begin!
« Reply #115 on: June 25, 2018, 09:48 AM »
I use this exclusively for drywall; it's indispensable for sanding drywall.  When I speak to others about drywall repair, I forget how much I take these tools for granted.
Offline Moneta007
« Reply #116 on: May 30, 2020, 02:25 PM »
Hello,
I am planning on getting the HSK 80 x 130 with the D21.5 hose to sand multicoats of water soluble varnish with grits from 240 to 600. Festool only sells the abrasives in packets of 50 which is far too many. Has anyone used the Mirka Abranet 80 x 130 abrasives with the Festool hand sand block?  Which abrasives are preferable?
Offline leakyroof
« Reply #117 on: June 03, 2020, 12:51 PM »
Hello,
  Yes, before I could buy the Festool Sanding Blocks, Mirka had theirs for sale here in the US, so as long as the size is right for Velcro Abrasives between the two brands, it all works.  I've used the net type/mesh type abrasives from both Mirka and Festool for 'between coat' sanding on Film Finishes. I typically don't go above 320 grit so the next coat has something to 'key into' versus being too smooth from sanding to adhere easily.
 Both Regular and Heavy Duty work fine for that type application, it would come down more to what price you want to spend and how large of a box you want to work with.  As an aside, some Festool dealers are willing to break down a full box of abrasives to a certain number, say like a 10 pack,  for Customers-  Ask, you won't know until you try... [cool]
Offline squall_line
« Reply #118 on: February 26, 2021, 06:04 PM »
Re-reviving this thread, I picked up the block and 21.5 mm hose thanks to this thread.
Since I didn't pick it up until a week ago, now the new Systainer3s are out, and we know that they're sized differently.
Not knowing how much spare room was in the SYS-II TLoc, I took a risk and ordered a Sys3 M 137 to see if things would fit.
To my pleasure, they fit like a glove in a Sys3 M - 137.
328325-0
328327-1
328329-2
328331-3
If you need more room, the 187 is the next size up, and slightly larger than the old SYS-II TLoc.  It should be more than enough room for the block, hose, and I don't know what else.
Also, I didn't think the non-AS hose would be that big of a deal until I walked over and bumped into the washing machine after sanding.  Yikes!  Still worth it for the ease of use of the setup.
Offline woodferret
« Reply #119 on: February 26, 2021, 06:22 PM »
Thanks for the SYS3 update.  I've gotta find a home for mine too.
« Reply #120 on: February 26, 2022, 01:47 PM »
Ya that kind of gets your attention.  [smile]
Offline Geblaat
« Reply #121 on: May 07, 2022, 05:39 PM »
I'm struggling getting this HSK 80 x 130 connected to the hose of the CTL MIDI-I which has should be the Ø 27/32 x 3,5 m-AS/CTR hose, the converters that came with the HSK 80x130 itself are too small and the rubber ring around it does not fit the MIDI hose.
Is there any connector/converter that I'm missing or should I try to get that D21,5 hose somewhere? Prefer to have a converter/connector though.
Offline SRSemenza
« Reply #122 on: May 08, 2022, 10:14 AM »
    I just tried it with the new style 27 connector. I got it to go on the reducing ring. But it is an extremely tight fit. It is tight on the old style but even more so on the new.
    I did a quick internet search and the 495019 hose is still available. If you plan to use the sanding block much at all, then you will  appreciate  the much lighter hose.
« Reply #123 on: May 08, 2022, 12:06 PM »
I'd echo what Seth suggested especially if you're using it vertically or over your head. The weight of the heavier hose wants to constantly pull it down. I managed to attach my HSK 80 directly to the older style AS green hose and the operation was clunky on vertical surfaces.
The only drawback is that the 21.5 hose is non antistatic,  [sad]  so if you bump up against something that's grounded, well, you'll be subtly reminded.
Offline afish
« Reply #124 on: May 08, 2022, 04:17 PM »
I dont know why but none of my hoses are anti static and I have never gotten one shock plus I have about 50' of pvc.  I live in very high humidity location so not sure if thats why but it seems odd while others have issues.
« Reply #125 on: May 08, 2022, 05:06 PM »
High humidity is your friend.  [smile]
Offline ironchefboyardee
« Reply #126 on: June 15, 2022, 11:23 AM »
I just received this sanding block, and the vent is extremely difficult to turn. I was able to turn it with a lot of effort and time but I don't think I'd try it again without gloves. I remember a review mentioning it moved too easily, so I'm wondering if Festool over compensated. Regardless, should I keep it anyway because I won't need to adjust it very often if at all?
Is the vent necessary if you can adjust the suction at the DC?
« Reply #127 on: June 15, 2022, 12:12 PM »
My valve stiffens up considerably after it hasn't been used in a while, so when I need to grab a pliers to turn it, I instead lightly lubricate it with DynaGlide and that's all it takes.
I still use the vent even though I'm using a MINI, MIDI or CT 22 because the vent is on the tool and I don't have to walk 15 feet to adjust the suction of the vac.
« Reply #128 on: June 15, 2022, 03:11 PM »
Good to know. I just removed the valve from the block (required vice grips) and now the green collar will turn. I'll try lubing it and reinstalling.
Edit: I applied a drop of oil, and I can rotate it by hand now. Thanks for the suggestion.
« Last Edit: June 15, 2022, 03:19 PM by ironchefboyardee »
Offline SRSemenza
« Reply #129 on: June 15, 2022, 03:58 PM »
I haven't used mine in a while so I can't confirm the setting up over time. But Initially I found it was way too loose. Kept accidentally closing it. I ended up taping mine open. I have never wanted it closed at all even with vac suction turned down.
Offline NiteWalkerGR
« Reply #130 on: July 31, 2022, 03:56 PM »
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
Thanks for this. I just bought the HSK block and the 21.5mm hose for some small drywall patches I need to do around the house and wasn't sure which sys3 would work best. I was between the 137 and 187 but I'm glad to see the 137 fits everything nicely.
And thanks Seth for the review!
« Last Edit: July 31, 2022, 03:58 PM by NiteWalkerGR »
Offline derekcohen
    • In The Woodshop
« Reply #131 on: August 02, 2022, 08:04 PM »
I have had the slightly smaller Mirka version of this hand sander for a few years, and use it with Abranet mesh.
Originally, it was used with the 27mm Festool hose, but I found this to be too bulky and heavy. I purchased the 22mm Mirka antistatic hose, and this is night-and-day different .. and so much better. It fits perfectly into my CT 26e vacuum cleaner.
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline leakyroof
« Reply #132 on: August 10, 2022, 12:02 PM »
Yes, having a skinnier, lighter hose really makes the hand held sanding blocks a delight!
Offline woodferret
« Reply #133 on: October 03, 2022, 01:43 PM »
I've been looking for the Mirka version but all I see are the 70x125 versions.  Did they redo the sizes or are people sticking the 80x130 and abranet 3x5 pads on it regardless?
Offline smorgasbord
« Reply #134 on: October 25, 2022, 02:48 PM »
I have a new LS 130 that I still need to fire up. Should I add this hand pad since it uses the same papers?
How hard/soft is the pad on the HSK? I hope it's pretty hard, as one can always add interface pads to soften it.
Right now I use a dense cork sanding block, to which I've added some hook backing to try out. Cork blocks are great for hand sanding, except for dust.
Offline SRSemenza
« Reply #135 on: October 25, 2022, 07:21 PM »
It is what I would call medium hard.  It has a bit of squishiness but is also thin so starts to compress against the hard plastic block with out much compression.  Compared to a Festool power sander pads I would say it falls right in between hard and medium.
