Author Topic: Festool clamps  (Read 24079 times)
Re: Festool clamps
« Reply #30 on: July 26, 2014, 12:03 PM »
I don't think there is one solution for clamping on the MFT. I have several different types of clamps and dogs, including Festool clamps and holding clamps, and have found that I use different methods of holding wood in place, depending on what I'm doing or working with. I still am learning about the versatility of the MFT. It just works in so many ways.
I had the same problem with screw clamps.  Had them several years and had no problems.  Then they came loose and caused me to ruin a part I was laminating.  I thought it was a fluke, but then I notices they would come loose all by themselves after a few minutes even in clamping situations where the part didn't need clamping unless you were working on it.
I lightly scrubbed the L shapped part of the clamps with green Scotchbrite and the problem hasn't reoccurred yet.  It has been about 5 months since I did that.
I have never got any finish or lubricants on these clamps.  The only thing I can think of is that maybe the surface layer on the zinc plating get's powdering or slick after awhile and scruffing it removed the unstable layer..
I scr
Offline Peter Parfitt
  • Magazine/Blog Author
Re: Festool clamps
« Reply #31 on: July 26, 2014, 01:15 PM »
Quite the accomplishment to set a quick clamp with just one hand. I haven't mastered it yet. My next trip to the place I buy Festools will include some screw clamps, I think. There are just some things that need to be secured more firmly.
I am really arthritic, especially my wrists, and find screw clamps a real pain. I can do quick clamps one handed with either hand as I am sure can be seen on some of my videos.
Offline Cealan
Re: Festool clamps
« Reply #32 on: October 20, 2014, 09:25 AM »
For me i love these clamps i use them a lot but they both do the same job and the screw clamps €38 for a set & the rachet lever ones are €48 each. I think €96 for 2 clamps is crazy so im happy to use the screw clamps
Own TSC track saw, REQ track saw, BHC drill, 1010 router, 850 planer, sander, mft,guide rails& clamps
Offline promark747
Re: Festool clamps
« Reply #33 on: October 20, 2014, 10:12 AM »
For the screw clamps, does anyone put anything on the handles to make them grippier?  That's my only complaint with them...I was thinking about adding hockey tape or maybe dipping them in that plasti-dip (?) coating.
Offline Kevin D.
Re: Festool clamps
« Reply #34 on: October 20, 2014, 12:52 PM »
Been in love with High Friction Silicone tape for years now and this is one of the areas it shines in use.  Even used it to regrip my wheelbarrow handles about five years which is left year round outside and they are still there.  Tough stuff and gives a nice rubbery grip and allows you to remove one day and have no sticky residue.
http://www.leevalley.com/en/wood/page.aspx?p=67792&cat=1,110,43466
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline #Tee
Re: Festool clamps
« Reply #35 on: October 21, 2014, 07:01 AM »
i dropped mine and chipped some paint off one of the handle edge....i felt sick and wanted to throw up. :P
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline Brent Taylor
Re: Festool clamps
« Reply #36 on: October 21, 2014, 08:44 AM »
I have to agree with John H. for real world work the DeWalt clamps and tracks work the best for me. I also like the Makita short clamps, because of there handles are larger and easier to grip, for the same reason Peter Parfitt stated in an earlier reply . I am older and still have to work in the field, so anything that can make my work better and easier, that is what I use. (Know matter the color, I just don't have the time to paint the stuff between my naps and Dr. appts. Oh and work. [big grin]) B
Re: Festool clamps
« Reply #37 on: October 21, 2014, 09:05 AM »
 [wink]Being old, I forgot to add that having all of the Festool clamps and I love them for most uses, but other clamp options that I love are Bessey's Klik clamps and there welding screw clamps, they are a great addition, for non=track use. (" it must suck being brainless Scarecrow." said Dorothy. And who is the heartless one thought the Tin Man.) B
Offline EV
  • Reception Desk Installed in Riyadh, Saudi Arabia.
Re: Festool clamps
« Reply #38 on: October 26, 2014, 11:47 AM »
I actually prefer the screw ones. The quick-grip ones are good when using them to clamp the rail down (as in your pic) but for anything where they're being used the other way up I find I need to use two hands to operate them (one to hold the 'L' up to the underside of the work, and one to squeeze the handle).
Also I've found that, due to the cam action, the quick-clamps can move the piece you're trying to clamp in position. Maybe it's user error... [embarassed]
Ive had same problem with panels moving while trying to clamp them down. Then I thought I must be doing something wrong!
First thing was that like possibly many other i have been trying to squeeze living day lights out of them, where it is totally unnecessary. 2-3 clicks (mostly 2) is more than enough to hold panels tight to the bench without creeping.
Second thing is to prevent creeping I now use technic I use when laminating say table leg using your ordinary "F" clamps. I would using first clamp to just gently squeeze two or more parts together following by alternating orientation of each consecutive clamp in same manner of application and pressure. Once all clamps installed, I then go back and forward a number of times and tightnening each clamp ever so slightly more until reaching clamping pressure I am happy with. So with Festool quick clamps, I do same thing. I apply gentle pressure to the clamping element while pulling up on a clamping bar, then squeeze the lever with two clicks and repeat same thing on the other clamp while squeezing lever 2-3 clicks and go back to a first clamp and give a extra one squeeze.
I own 4 of these clamps, 4 of the screw type, 2 300mm screw type and a rapid clamp, which has it's own reason to be in my collection. They all great but I tend to use 2 screw type clamps mostly as they are alway at hand in my SYS - HWZ  toolbox Systainer.the rest live in my FS - BAG - VL.
Hope this helps folks.
Best regards
EV
--------------- " If you need to borrow a tool, means you need it, if you need it, go and BUY IT!!! " ---------------
