Author Topic: STM 1800 brackets for worktop  (Read 2735 times)
Offline contendernut
« on: November 24, 2020, 12:30 PM »
Could someone post the part numbers and ordering info for the brackets to attach mfd to the stm1800 please.
Offline cpw
Re: STM 1800 brackets for worktop
« Reply #1 on: November 24, 2020, 03:55 PM »
I haven't gotten mine yet, but you need to call Festool USA.  Part number should be 10293265.
Offline krudawg
« Reply #2 on: November 24, 2020, 10:16 PM »
[/quot
That part number does not work
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum,
Former Marine, Vietnam Vet
Offline TXFIVEO
« Reply #3 on: November 25, 2020, 02:42 PM »
That parts are in back order from Germany and expected to arrive mid December.
Offline jpmarsh
« Reply #4 on: December 03, 2020, 09:38 PM »
I had one delivered recently with some shipping damage and they sent me this to identify the needed replacement parts.  Hopefully this helps to double check PN's.
Offline JimH2
« Reply #5 on: February 24, 2021, 10:53 AM »
Do I have to call to order parts now? I remember at one time, I think, being able to order directly from the site.
« Reply #6 on: February 24, 2021, 01:47 PM »
I called and ordered them. They arrived in 3 days
Offline jarbroen
« Reply #7 on: March 16, 2021, 04:38 PM »
Has anybody tried the add-on jig ideas with 10293275(#9 'Clamp').  The longer wood supports use a couple of those each to attach to the frame
Offline jobsworth
  • Festool Baby.....
« Reply #8 on: March 16, 2021, 11:08 PM »
I tried it worked ok but ILO of a little work support I used 4 brackets and made the STM into  4x7  assy table
Offline jarbroen
« Reply #9 on: March 17, 2021, 12:02 AM »
That’s exactly what I’m thinking of doing - making an assembly top for the STM.
Something that I can leave on my plywood cart when I don’t need it.
The trick would be getting it super flat.  Using 4 brackets sounds like it would work well
Offline rocky100370
« Reply #10 on: March 17, 2021, 06:01 AM »
I didn't know there were brackets to attach a top to this. Does anyone have a pic? TIA
Offline jobsworth
  • Festool Baby.....
« Reply #11 on: March 17, 2021, 10:33 AM »
@jarbroen
I used ultra light weight MDF ripped down the center. The brackets hold it to the STM well and the weight of whatever Im assembling keeps the MDF flat enough .
Mike Goetz ( sorry mike cant remember how to correctly spell your name) suggested using domino connectors to hold the 2 pieces securely together. i dont have the connectors yet but if i did I would use Mikes suggestion. The issue for me is to find a place to set the MDF when not in use. Also I found that 8' is a little to long for the STM so I cut it down to 7' long. I think 6' might be a little better.
Hope this helps
Offline jarbroen
« Reply #12 on: March 17, 2021, 10:58 AM »
@jobsworth  Thanks for the feedback and tips!
I agree on 6' being a good length.  On heavy, full sheets I noticed the end support bars have a tendency to sag a bit.  Don't want any sagging in an assembly table.  I'd probably want just a slight overhang to the square frame structure which would be about that 6' length.
The connectors is a good tip.  You could even use the connectors to attach the top to the wood supports.  Just be careful not to cut the connectors when the assembly top is off. :). That's something I would accidentally do...
Guess I need to make a trip back to my lumber supplier to check out their MDF.  Cool thing about the STM is the weight of assembly top isn't a big deal since the table lifts it!
« Last Edit: March 17, 2021, 11:42 AM by jarbroen »
Offline jobsworth
  • Festool Baby.....
« Reply #13 on: March 17, 2021, 05:58 PM »
@jarbroen
Thats why I recommended 6' though 7' would work. I havent noticed any sagging at the ends. I guess it depends on how you cut the wood pieces that the brackets mount to. I I ripped them screwed them to the brackets and if they were to big or small I cut the big ones to fit , to small just made a couple of more. Lemmy check my shop set up thread, see if i put the size of the pieces when i talked about it.
Heres what I wrote in my setting up shop thread. I have some photos as well its on page 12 of that thread. but heres what i wrote and even got mikes nae spelt right :>D
>>>Ok so I think I solved my problem connecting the assy top to the STM. I ended up using 4 brackets/clips/terminal one on each end of the STM.
I used 2" thick pine I had left over cut to 70mm which is the size of the large wooden piece on the ends of the STM.
I took a festool rabbiting bot that I bought back from the UK and didnt mount my 2200 in my CMS and routed a rabbit to fit the bracket/clip/terminal. Photo of the rabbiting bit its the only bit that FT has that mounts to a arbor (sold seperately of course)
so I posted photos of the rabbited wood and the wood in the brackets. Now to secure the top to the bracket/wood.
Im thinking I might add a couple screws from the top and adjust the top so I can use a through domino from the 700. that should hold it securely
Mike Goetzke suggested that I use connectors to keep the sides together, thats a great Idea. Im gonna use it when I get my hand on some connectors or get the kit.<<<
« Last Edit: March 17, 2021, 06:02 PM by jobsworth »
Offline jarbroen
« Reply #14 on: March 17, 2021, 06:18 PM »
I'll check out the pictures in your other thread.  Sometimes I have to see something to help my little brain understand.
I ran to the closest, non-big box, lumber store at lunch.  Their 3/4" MDF looked like saggy poo, but they had a flat stack of 1" so I grabbed a sheet of the really heavy stuff.  I realize I won't be able to use some accessories if I decide to cut dog holes.  Not a problem though as I already have MFT's for that stuff.
I really appreciated the STM when I could roll it up to my folded down tailgate and slide that ridiculously heavy sheet right on.
Offline jobsworth
  • Festool Baby.....
« Reply #15 on: March 18, 2021, 12:21 PM »
@jarbroen
If ya can use the 3/4 ultra lightweight MDF Its lighter then the 3/4 ply I was using to build my shop cabinets
