Author Topic: FESTOOL RS 2E  (Read 5606 times)
Offline TXFIVEO
FESTOOL RS 2E
« on: January 28, 2020, 11:05 PM »
Got this sander yesterday...boy I wish I would have gotten it sooner.  What a beast!! Half sheet size cuts the time in half for me and the ability to make my own sand sheets and to use 40 grit and up makes flattening a breeze!
Offline Alanbach
Re: FESTOOL RS 2E
« Reply #1 on: January 28, 2020, 11:59 PM »
Agreed! It can cover some serious ground. I bought mine used and very reasonably. He just wasn’t using it, he had so many others. I too, have quite a few so I don’t use it all the time but when the right application comes along it is a beast.
Offline ScotF
Re: FESTOOL RS 2E
« Reply #2 on: January 29, 2020, 12:41 AM »
It is one of Festool's hidden gems. A great sander...
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #3 on: January 30, 2020, 10:14 AM »
Yes, I definitely agree.  For sure my favorite FESTOOL sander of the three that I have.  I mainly build 8’-10’ tall doors and 3’-5’ wide, so lots of real estate to sand.  With this beast it’s cutting my sanding time in half.  GAME CHANGER.
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #4 on: February 05, 2020, 10:31 AM »
Flattened this white oak door in no time with the RS 2E...did three doors just like this one in probably 1/3 of the time it would have taken me with the ROTEX 125.
Offline NL-mikkla
  • www.m144h.com
Re: FESTOOL RS 2E
« Reply #5 on: February 06, 2020, 04:53 AM »
Unbelievable, I don't have the RS2E and that's probably because it looks so outdated and it's ancient design-ish look.
But this post clearly states otherwise...
Offline Jim Kirkpatrick
    • My Instagram
Re: FESTOOL RS 2E
« Reply #6 on: February 06, 2020, 06:48 AM »
I have this sander and like it a lot for flattening face frames.  One downside to be aware of though, is no plug-it cord.  I got around it by installing a plug-it pigtail that I sourced from the U.K.
Offline NL-mikkla
  • www.m144h.com
Re: FESTOOL RS 2E
« Reply #7 on: February 06, 2020, 07:37 AM »
Thank you @Jim Kirkpatrick I think my wishlist has grown a little longer  [big grin]
I'm familiar with the plug-it pigtail conversion (which is available here in the Netherlands) I have used this to my satisfaction on the BS105
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #8 on: February 07, 2020, 08:04 AM »
I actually prefer the power plug on the RS 2E...no worrying about making sure the cord is turned all the way on, etc.
Offline Alex
Re: FESTOOL RS 2E
« Reply #9 on: February 07, 2020, 08:25 AM »
But not needed here in Holland as we have the updated RS200 with Plug-It cord.
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #10 on: February 07, 2020, 09:49 AM »
Sander works the same...the no plug it cord is not an issue at all for me.  Have never had an issue with any of my tools power cord.
Online Cheese
Re: FESTOOL RS 2E
« Reply #11 on: February 07, 2020, 10:14 AM »
(Attachment Link)
Interesting Alex, I never knew they offered a separate dust bag for the RS 2.
Offline PreferrablyWood
Re: FESTOOL RS 2E
« Reply #12 on: February 08, 2020, 07:18 PM »
Thats an interesting sander for sure I have a smaller version RS 300 EQ og the Same form factor and it's a beast. I'll put this on my list perhaps ahead of the beltsander.. I'm thinking of getting.
« Last Edit: February 08, 2020, 07:21 PM by PreferrablyWood »
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline ear3
Re: FESTOOL RS 2E
« Reply #13 on: February 17, 2020, 05:26 PM »
Those considering this sander should keep in mind that it still has a very small sanding stroke for it's size (2.5mm/3/32").  So while it might have a speed advantage over the 125, it definitely still lags well behind the 150s.  That said, for large panel work it is fantastic for keeping everything flat and leaves no dishing that you sometimes get on the edges using the round ROS sanders.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #14 on: February 19, 2020, 03:21 PM »
While it is considered a “fine finish” type sander, with some aggressive sandpaper it can do some leveling.  For tabletops and doors, I’ll take this over my RO150 ANYDAY.
« Last Edit: February 19, 2020, 03:29 PM by TXFIVEO »
Offline PaulMarcel
    • Voilà, my blog
Re: FESTOOL RS 2E
« Reply #15 on: February 19, 2020, 04:06 PM »
I love it for large flat surfaces. I added the Plug-It conversion kit, but that isn't a show-stopper at all. I also often use it upside-down in a vice for sanding small items quickly.
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #16 on: February 19, 2020, 05:06 PM »
That’s a smart idea...might have to try that one!
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
Heads Up FESTOOL RS 2E discontinued in US market
« Reply #17 on: February 26, 2020, 08:55 AM »
    So, as of February 18th, this sander has been discontinued by Festool USA (even though it still appears on the Festool USA webpage). If you want one, I'd suggest contacting the online Festool dealers to see if they have any in stock. It might end up like the RAS 115, with fairly deep discounts to get rid of existing stock. I am not certain if the RS 200 that's available in European markets will ever make it over here in one of the new Systainer3s but if you want one of these, start looking now. At TXFIVE0's recommendation, I am going to get one as well.
Festool Specialist at Woodcraft, Chattanooga, TN
Offline Knight Woodworks
Re: FESTOOL RS 2E
« Reply #18 on: February 26, 2020, 06:51 PM »
Thanks for the heads up. Will be ordering one soon.
John
Offline Alanbach
Re: FESTOOL RS 2E
« Reply #19 on: February 26, 2020, 08:06 PM »
@TXFIVEO - Now that you have discovered the merits of this sander they immediately discontinued it. Now you might need to go buy a spare before they are gone.
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #20 on: February 27, 2020, 07:45 AM »
Not showing discontinued for me on FESTOOL USA’s site...called FESTOOL yesterday was informed it wasn’t being discontinued. Weird...
Offline Alanbach
Re: FESTOOL RS 2E
« Reply #21 on: February 27, 2020, 10:46 AM »
That is weird. I was going by jcrowe1950’s post from yesterday morning on this thread.
Offline TXFIVEO
Re: FESTOOL RS 2E
« Reply #22 on: May 03, 2020, 07:15 PM »
Looks like they indeed are phasing this beast out...just ordered another one!
Offline ScotF
Re: FESTOOL RS 2E
« Reply #23 on: May 03, 2020, 07:45 PM »
Too bad...another great sander gone. I am on my second one - the first one died after 4-5 years. I suppose I could send it in for repair  - I tried to take it a part but was not successful and had to buy another for the project I was in the middle of. I checked several sites and it does not appear to be available from anyone any longer.
Online Cheese
Re: FESTOOL RS 2E is Discontinued
« Reply #24 on: May 04, 2020, 09:45 AM »
Unbelievable...all the major retailers are sold out on this item already.
Amazon, Woodcraft, ToolNut, Acme, Highland Woodworking, Lee Valley, everywhere the cupboards are bare.
Maybe the newer Euro version with the Plug-It will make it here in a Systainer³ ?
Offline rst
Re: FESTOOL RS 2E
« Reply #25 on: May 04, 2020, 10:52 AM »
Glad I bought mine off Ebag a while ago at a great price.  I planned on replacing my Makita which I still have.
Offline box185
Re: FESTOOL RS 2E
« Reply #26 on: May 04, 2020, 11:25 AM »
festoolsales.com show it as available as of this morning.
Offline JimH2
Re: FESTOOL RS 2E
« Reply #27 on: May 04, 2020, 12:05 PM »
It is a great sand for sheet goods. This is quite a loss unless a replacement is due. Plug it makes no sense on these just as it makes no sense on the OF2200.
Offline Koamolly
« Reply #28 on: May 04, 2020, 12:40 PM »
Looks like Hartville has them.
https://www.hartvilletool.com/product/17434/festool-sanders-and-polishers
Online Cheese
« Reply #29 on: May 04, 2020, 01:06 PM »
Ya it seems they’re the only major retailer that does.
I’ve had my RS 2 E for the last 4-5 years and love it. A Plug-It would be nice but it’s certainly not a necessity.  [smile]
