« Reply #15 on: February 26, 2019, 01:09 PM »
I’m with Grants05.
![Thumbs Up [thumbs up]](https://www.festoolownersgroup.com/Smileys/default/thumbup.gif)
As a longtime Hobbyist, I don’t do much “production” sanding - So I understand that -
I can’t really appreciate the Tradesmens’ needs or view points on this sander.
My interests/work is mostly furniture, boxes, cutting boards, some cabinets, etc.
For my needs as a Hobbyist - I really like the size, weight, and capabilities -
Of my Festool RO125 FEQ Rotex Sander.
My Rikon 50-120 6inX48in Belt-Disc Sander and Jet JBOS-5 Benchtop Oscillating Spindle Sander - Get regular “workouts”, as well.
But, for “detail” and “finish” sanding -
I wouldn’t trade my Festool -
LS 130 EQ Linear Detail Sander or DX93E Detail Sander.
Their capabilities, versatility, and results - “Get the job done” in my shop.
![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
« Last Edit: February 26, 2019, 01:16 PM by Joe Felchlin »
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIGS: D4R 24 Pro Dovetail Jig, FMT Pro Mortise & Tenon Jig | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
