I have the festool DSC-AG 125 that comes ready to use with the festool guides so tomorrow I will check if it fits accurately without any oscillation.
However, in this forum there are many festool users and many complain about bites in the festool anti-splinter piece, the same thing has happened to me with the Mafell MT 55, for me it is proof that sometimes the cut can be twist slightly and that is what produces those irregularities.
I maintain that the Mafell guide has a superior precision and for what I have read and in other posts in this same thread, the majority in this forum supports it, a forum in which it is assumed that there are many more users of Festool tools than of Mafell and yet there is no problem in recognizing superiority and that happens because this superiority is unquestionable.
And what is more, if demanding cuts were made, for example in tropical, hard wood and large widths. This difference in precision would be much more evident because entering the saw in hard material creates greater torsional forces and this is where festool guides have their vulnerable point.
I have both guide systems and say that the Mafell / Bosch guides are far superior to the Festool.
I have more Festool guides than Mafell so I'm not particularly happy to have found this little problem with the Festool guides.
However, I do not know if I explain it well, I am talking about putting a Mafell MT55 saw, the best plunge saw in the world, on a Festool rail, adjust the slide in such a way that it is very rigid and grab the saw from the front and the back and try Turning it with force, the saw oscillates slightly visibly during force so adjustment without movement is impossible. On the Mafell rail, an adjustment is possible without visually appreciating an oscillatory movement.
I will limit myself to saying that with this configuration MT 55 and rail festool it is impossible to achieve a very high precision and it is because the saw does not fit so precisely.
I understand that as a consequence of the design of the festool channel, the tools have a contact surface much greater than that of Mafell, the friction is higher, perhaps the developers of Festool preferred to sacrifice minimally the precision to achieve a better sliding for their rail, this is something that anyone notices from the first moment, extreme precision does not have to be a priority for the majority, it is not something that one can be sure of from the first minute, it requires demanding the machine and the guides.
As this post tries to compare both systems, in the comparison, for design reasons it is very difficult that with this design the festool guides have as precise a guide as the Mafell / Bosch guides
As I said I will check it with a specific tool for festool rails and here I will say it
But as I said in another post, festool guides have the advantage of better grip
