Author Topic: RO 150 bs RAS 115  (Read 6528 times)
Offline Matty04
RO 150 bs RAS 115
« on: February 06, 2018, 02:47 PM »
Any thoughts on comparing the Rotex 150 and the RAS 115 for heavy to medium paint removal?
Thanks Mike
Offline Alex
Re: RO 150 bs RAS 115
« Reply #1 on: February 06, 2018, 03:10 PM »
I have both, the RAS blows the RO150 out of the water with heavy paint removal. Like 4 or 5 times as fast. It does leave a rough surface which you have to clean up again with another, finer sander, like the RO150, but overall you're done much quicker.
The RO150 itself isn't bad either, it's just that the RAS, as a slowed down angle grinder, has a lot more speed. 650 vs 3800 RPM.
Dust collection with the RAS isn't that good though.
Offline live4ever
« Reply #2 on: February 06, 2018, 03:17 PM »
The RAS is a mean nasty paint-eater.  If you need fast and are ready to finesse with other methods, that’s the ticket.
Offline Peter Halle
« Reply #3 on: February 06, 2018, 04:02 PM »
Ras wins hands down for removal but you may need to follow up with another sander for smoothing.
Offline Matty04
« Reply #4 on: February 06, 2018, 06:29 PM »
Thanks guys I’m sold.
Mike
Offline Ajax
« Reply #5 on: February 07, 2018, 01:38 AM »
RAS
Best paint remover I’ve used.
Kapex KS120, MFT/3, TS55 REQ, LS130, RTS400, RO90 DX FEQ, D90 Assortment, RO150 REQ, ETS 150/3, PRO5, D150 Assortment, DF 500, Domino 4/5/8/10 Assortment, DF700 XL, Domino 12/14 Assortment,  CT Midi, MFT/3, Kapex MFT, 2 x SysRoll
Offline ear3
« Reply #6 on: February 07, 2018, 05:58 PM »
Agree with all the above, but what's your specific application?  Keep in mind that you always want to be cautious using the RAS, due to the higher probability of dishing the surface.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
« Reply #7 on: April 15, 2018, 07:23 AM »
I realize now that I haven't used my Rotex 150 once since I got the RAS115 a few years back. Ok, maybe one or two times for small tasks because the other sanders were elsewhere/out of reach.
I do need to sand down my living room floor so I am thinking the Rotex might be the ticket for that. The RAS is a bit aggressive but if they tag team I know the Rotex will leave me with a finish ready end result. After I am done I might sell off the Rotex.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
