Author Topic: Trackin' past the table saw  (Read 5134 times)
Offline Bullhorn
« on: April 08, 2018, 07:10 PM »
As a relative Fesnoob, I haven't yet developed the reflex of reaching for my stack of handsome green boxes. There are just too many ways of using familiar, somewhat cruder tools that fall solidly within my comfort zone that I have to pause and remember that I often have a better way now.
In particular, I haven't automatized the behavior of connecting my CT36 and setting up in "green mode" for familiar operations. However, as it seems my doc is moving from a diagnosis of COPD toward one of constrictive bronchiolitis, excellent dust collection is increasingly important to my comfort (and remaining years of activity) in the shop.
So I do try to be religious about it, to the point where I'm considering another CT (the little guy) to park semi-permanently under my chopsaw bench.
But back to better ways: I have what I consider quite a nice tablesaw parked in the shop, a SawStop Pro with 36" rails, between which one finds a cast iron router table extension with a lift. Life for my crunchy spine has gotten easier without constantly crouching under to raise or lower the router... Anyway, this whole setup is a pretty regular go-to for me. There's just so much that's easy and quick to do at the TS that I automatically head that direction for most quick, linear cuts. Also, it's already hooked up to a dust collector, which collects pretty well from under the blade hood, and has a remote switch. Easier than thinking, right?
So there I was, getting ready to cut out templates for the ends and sides of a cradle (stealth grandchild announcement goes <here>), standing there with a fenced miter gauge in my hand, puzzling over how to reliably match the angled markouts to my big, fancy saw and push plywood across the blade when I looked up and noticed the end of a saw track hanging out of the "dimensional and scraps" loft over the garage door.
Well, duh! Out came the TS-75 and the CT-36, with one o' them fancy hose goobers and a pair of quick clamps for my old-as-rocks, gray steel Workmate. All four end cuts, with two different angles, got nipped out faster than it would have taken to set up the first one on a stationary tool. As a bonus, the whole op produced less airborne dust than I'd have made with a Japanese handsaw -- and none of it got thrown straight at my face!
Might be time to upgrade the Workmate to an MFT. Otherwise, I'm feeling ridiculously spoiled right now. Time to finish up that cradle, so my daughter (and imminent granddaughter -- did I mention my granddaughter? 'Cause I'm having a GRANDDAUGHTER!) can feel spoiled, too.
Offline Peter Halle
Re: Trackin' past the table saw
« Reply #1 on: April 08, 2018, 07:24 PM »
Wonderful!
Tracksaws aren't for everything and having a big tablessaw handy is a wonderful thing.  But there are and aren't times that they are interchangeable.  Personally I find that sometimes slowing down to think about how to use a trackssaw in a particular situation is smile generating.
Congrats on becoming a Grandfather!
Offline ProCarpenterRVA
« Reply #2 on: April 08, 2018, 07:51 PM »
You're on the right track. I'm always cringing when I see a current YouTube video and someone is merrily sanding away without source point dust control. My advice is to use it as much as possible,chop saws, Kapex, router tables, table saw and other large sawdust producers, really benefit from using a larger cyclone type collection system with necked down fittings and hose, if necessary.
You can't turn off or reverse the damage that microfine particulate matter can cause to your lungs. I can't tell you how bad my shops have looked over the years before I got serious about cleaning up my act. Hopefully I can survive all the crud I breathed in.
Sent from my Pixel XL using Tapatalk
« Last Edit: April 08, 2018, 07:53 PM by ProCarpenterRVA »
Offline RKA
« Reply #3 on: April 08, 2018, 08:16 PM »
I thought I saw a mention of a grand daughter?  If I got that right, congratulations!
The track saw was my first and favorite.  I recently had a chance to poison a friend with green, trimming down and installing 15 interior doors.  Now he’s borrowing a Kapex for the trim and he’s ecstatic with the dust collection and precision.  Every so often we would forget to turn on the extractor or move the hose to the active tool.  That’s a quick reminder how good the dust collection is!
Welcome to the FOG!
-Raj
Offline Birdhunter
« Reply #4 on: April 08, 2018, 08:28 PM »
I had a similar experience.
 I have a Sawstop Industrial table saw and was trying to cut a large 45 degree right triangle. I just wasn’t comfortable with the safety of any of the solutions I thought of.
Then, four Qwas dogs into the MFT, drop the rail, TS55 through the cut, and perfect triangle.
Having multiple attacks on a problem is great.
Birdhunter
