Hi there, as a FOG newbie, i have bought the CT VA 20 and the CTL SYS, I also have a Bosch GAS50M on my CNC router with a ‘ahem’ homemade cyclone separator. The CTVA20 works wel with the CTL SYS, and all needed atachments come with it. I did sell my CTL SYS though and bought a CTL MINI because: I used the CTL SYS on a trolley 90% of the time anyway, there is no electronic sucktion control on the SYS, and most importantly, the CTL SYS would go in a sort of hose blocked mode very often with the cyclone in between. The CTL MIDI solved that all. It’s not that much bigger if you compare it with the SYS on a trolley. Now as for efficiency (separation effectiveness divided by cost), the home made cyclone actually separates better. It is a lot bigger and not mobile at all. In it’s corner on top of the huge Bosch it performs outstandingly. Why then pay so much more for the Festool? It still separates very well, it is portable, everything fits perfectly together, it’s way smaller and it is 10 times more professional when you are at a customer. The system approach and portability make it worth the money for me already. And once you have used the separator, it is hard to understand why not everybody uses them. I never, ever buy new bag. Once a year I clean the filters. The stationary setup dumps the exhaust outside through a heat exchanger the mobile Festool is occasionally with a disposable bag on site without the separator.
