Author Topic: Festool Centrotec compatibility with other manufacturers (cordless) drills  (Read 21666 times)
Online six-point socket II
  • formerly @the_black_tie_diyer
Hi everyone,
A question brought up in another forum got me to compose this and I thought it might contain some valuable information also for international Festool users and people in general who might look into Festool Centrotec accessories. So I re-wrote it in english to post here.
This is about usability of Festool Centrotec accessories with other manufacturers machines.
As far as I know there is only one manufacturer, namely Metabo, who's "Quick"-System will accept the Festool Centrotec chuck directly without using any adapter.
So if you want to use the key features of the Festool Centrotec system (better concentricity & easy and fast changing of tools) on another manufacturers (cordless) drill you need an adapter. For now, I'd like to stay away from a discussion about concentricity because there are way to many aspects that play into it - it's something each user, looking at his/her machines has to decide for him-/herself.
So back to the question, can Festool Centrotec accessories be used with other manufacturers machinery?
The answer is yes, as long as the other machine has a keyless/regular chuck that has a capacity/span length of at least 10 mm / 3/8".
What you are going to need are two things: Festool Keyless Chuck Centrotec Adapter - 496450 (Costs 22.00 USD as of 2/9/2017) and Festool Centrotec Chuck - 492135 (Costs 37.00 USD as of 2/9/2017)
Please also understand that the Festool Keyless Chuck Centrotec Adapter's hex portion is significantly wider than the standard 6,4 mm/ 1/4" hex portion of tooling/hex chucks. This will not fit any 6,4 mm/ 1/4" hex (quick change) chucks.
With these two accessories you can use any Festool Centrotec tools with any (cordless) drill that, again, has a chuck with minimum capacity/ span length of at least 10 mm / 3/8".
Pictures speak louder than words ;)
Start - Festool CXS and Bosch GSR 10,8. CXS equipped with Centrotec bitholder, GSR equipped with Wera fast change bitholder.
Now the GSR is equipped with Festool Keyless Chuck Centrotec Adapter and Festool Centrotec Chuck
As said before - now it's compatible with all Festool Centrotec tools.
The Festool Bitholder is compatible with  all 6,4 mm/ 1/4" hex Bits, in this instance Wera bit.
Not pretty, but also doable - putting Festool Centrotec tools directly into a chuck. All Festool Centrotec tools can be placed in any standard 6,4 mm/ 1/4" hex bitholder - but will be held only by friction and/or magnet. The missing notches on the hex part prevent fast change bitholders to lock onto the tool/bit.
Just a comparison shot of both machines with no tools.
_____________________________________________________________________________________________________
My thoughts:
You can use adapters to work with Festool Centrotec accessories on almost any (cordless) drill. If it makes sense for you to do/use/buy that is up to you.
I think if you have a big load of Festool Centrotec accessories it's a great idea to get the adapters so you can easily use and swap tools throughout all of your machines. However, you should consider that adding the adapters will add significantly to the length of your machine. Which might be a disadvantage depending on the task ahead.
One last thing to say, Festool Centrotec accessories, and accessories in general are some of the highest quality tools you can get so it might be a game changer already just being able to use these with your non-Festool (cordless) drill.
I hope you find this information useful and maybe future questions about Centrotec compatibility can be directed to this thread.
Please feel free to add your thoughts and experiences.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Rusty Miller
Where do you get those Wera vex type bits?
Rusty Miller
I'd rather be woodworking!
Kind regards,
Oliver
I have a Mafell A18M and a Metabo LTX and I think they are the (currently) best "cross platform" drills. Strong and flexible. I have the T18+3 and I like it too but the A18M is a better drill in terms of sheer power for drilling in wood and the Impuls mode which is really handy. Since I have loads of Centrotec stuff I run them on the Mafell seating the drill bits deep into the chuck - as intended - and can change over to regular bitholders in an instant - or use the Metabo quick change bit holder/chuck. I am very happy with that.
EDIT: in your image you have the keyless chuck attached to a Bosch drill chuck to fit a regular bit - via the Centrotec chuck.  [eek] Why do that? There is no point. You already have the excellent Wera bitholder. It just makes it clumsy and heavy. I get that if you were using the Centrotec drill bits it would make (more) sense. :)
When attaching the Centrotec bitholder or drills straight into drill chucks I never go over the round part on the shaft as you show in the picture - that causes slippage - so I just insert to the rim of the round part so the chuck jaws grip the
hex part in the end; no slippage. But I very seldom have to do that as my main drills all have Centrotec compatibility.
For hammer drills the SDS adapter makes sense as it allows for the drill chuck to be used. That is good. For bits onto a hammer drill there already exists rock solid locking bitholders. Again, fitting a Centrotec keyless chuck makes no sense in that regard.
I have the Festool keyless chuck in a drawer but think there is no point in having one. A Wiha Centrofix bit holder does it better for regular drills as it positively locks Centrotec bits/drills which means that if you can use it on both a drill with a hex bit holder and one with a drill chuck or in a pinch, straight on to the bit holder on drills with removable chucks. I don't think the Festool drill chuck is good enough to warrant using the keyless chuck to fit it to another drill so for me it is simply redundant. With regular drill chucks I prefer just sticking the Centrotec drill bits right into the chuck.
The Fein ASCM 12 is another fantastic little drill and it (now) comes with a Wiha Centrofix chuck so it will also accept Centrotec - as well as regular hex drills and bits. The Centrotec chuck does not fit the Fein ASCM 12 (the diameter on the bare bit chuck is a hair thicker so it won't fit, neither does Metabo/Mafell on Fein) so drill bits will extend a little further but at least it is a workable solution.
The Fein 18V quick in MAX chuck fits on Metabo with a little work (grinding down the metal base a fraction of a mm to enable the ball detent to lock) and it too has a Centrofix attachment. I run that one as a spare. The Fein 12V quick change chuck arrives tomorrow or possibly monday so I am not sure if ot would fit on Festool but I doubt it though the opening diameter suggests it could I think the ball detent is incompatible.
Fein has Quick IN (60NM) and Quick IN MAX (120NM) rated chucks and accessories and they work "downstream".
« Last Edit: February 10, 2017, 01:47 AM by Henrik R / Pingvinlakrits »
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline Holmz
... As far as I know there is only one manufacturer, namely Metabo, who's "Quick"-System will accept the Festool Centrotec chuck directly without using any adapter.
Correct, the Metabo/Mafell takes the green lipped centrotec better than OJ's glove.
I am not sure if the Mafell 1/4"  'çentrotec' would fit on the Festool, but I would think it would.
that could be a good option for people liking the centrotec concept, but using their 1/4" bits.
I got a few from Ebay or maybe Amazon Eu... so I have the 1 greeny, and the 3 red lipped jobs.
Hi!
Because, as I already stated in my post the question that lead me to compose it was about compatibility & possibility. Not about usability or if certain combinations make sense when other (compatible) solutions are available.
Me neither. It just looks that way because of the angle of the picture - of course I used the hex part to clamp/chuck.
Kind regards,
Oliver
Kind regards,
Oliver
Ok, Oliver, got it. :)
POST HEAVILY EDITED AFTER RETESTING COMPATIBILITY:
Holmz: Metabo/Mafell bitholder does not fit Festool. The throat of the machine side bit socket is a hair too thick.
Fein (18V only) bitholder fits Festool though - so the excellent Centrofix (made by Wiha, I think) can be used on Festool:
So compatibility seems to be (as tested):
FESTOOL Centrotec fits on Festool and Metabo/Mafell.
 - Does not fit Fein ASCM 12 which has a slightly larger outer diameter on the machine fixed bit holder.
FEIN 18V Quick In chuck fits on Fein 18V, Festool and Metabo/Mafell after a minor grind down of the base
 - but DOES NOT fit on the Fein ASCM12 due to the ASCM 12 having a slightly larger outer diameter (despite being lower class NM on bit holder).*)
FEIN 12V Quick In chuck and drill chuck DOES NOT LOCK on any other machines due to ball detents having different placement.
METABO/MAFELL bitholder (made by Wera, I think) only fits on Metabo/Mafell due to smallest inner diameter.
- Not compatible with the others - but Fein 18V and Festool fit Metabo/Mafell. **)
MILWAUKEE has a different machine side bit holder fixing which is partially square so none of the above fits.
BOSCH new 12V Flexi Click is incompatible to all above due to having a locking bit holder on the machine side.
*) Hence the new bitholder for Fein 12V, classed to 60NM. Supposedly fits Quick In and Quick In Max so might also fit the 18V drills but the ball detent suggests it does not.
- it DOES NOT fit Festool or Metabo/Mafell due to placement of ball detents.
**) Festool fits straight away on Metabo/Mafell. Fein had to be ground down a fraction to lock in place on Festool. Did not test the Fein bit chuck on Metabo/Mafell before grinding it down so cannot say if it would fit without mod.
« Last Edit: February 11, 2017, 03:04 PM by Henrik R / Pingvinlakrits »
Hi!
@Henrik R / Pingvinlakrits Thank you very much for the additional input and pictures, much appreciated!!
Kind regards,
Oliver
Kind regards,
Oliver
Oliver: you are welcome. Feel free to proof read and make sure I did not miss anything or got something wrong.
I did a massive edit of the post to clarify a little and added some info. Hope you read the last version. :)
When I get the last piece of the puzzle I can add some more pictures to incorporate all possibilities of the various chucks. I just got the Fein ASCM 12 and the new bitholder is en route and should arrive Monday. The Fein drill is fantastic. It does not have an angle chuck out yet but I have it on good authority that one is ready for production. They might release a kit on the market with all the relevant chucks later on this year so I am keeping my fingers crossed. The Fein ASCM 12 might replace _both_ the T18 and the CXS as my go to drill for kitchen builds and interior work. A pair of them would meet all my requirements in that regard. The precision in driving challenges the T18 and is at least on par. The only thing I have left to wish for when it comes to the Fein drill is Impuls mode. ;)
I won't get rid of the CXS though, it always has a place for me but the T18 is relegated to the work shop for all eternity and the Mafell A18M is my power drill for heavier applications - the latter a no brainer as I can use all my countersink and Centrotec drill bits without fuss. Never thought I'd see the day when I dropped my Festool drills for the competition but so it seems.  [eek]
« Last Edit: February 11, 2017, 03:15 PM by Henrik R / Pingvinlakrits »
Offline leakyroof
I read, then reread this thread. Interesting reading.
 I can add that even in the 'normal' 1/4" quick change bit world outside of Festool/Centrotec, I've encountered bits that won't fit every 1/4" chuck, but are fine with a Wera Chuck or some chuck that accepts what ever slight variant in the Ball detent section of the offending bits that was an issue. So, even with what is supposedly a universal system of the 1/4" QC, you can run into problems.
 Granted, it's a rare thing, but it does happen.   [sad]
I have heard from a local Fein dealer that Fein are refreshing their 18V line so there will be new chucks and bitchucks, which explains why the 12V Fein is not compatible with the current 18V. The new line will be with the same throat diameter as the 12V - which is larger.  I have kept pestering them with the release of the right angle chuck and he has confirmed that one is on the way. He was shown an actual picture of the right angle chuck by the Fein rep.
Not sure when the new 18V line is out but apparently soon. I personally think the current Fein 18V line is way oversized and clumsy. Hoping Fein will bring out something a little more streamlined.
Offline neeleman
The new ones are still not as slim as the latest Makita or Panasonic impacts.
And batteries also look big. Hope these are made in Germany.
Have not seen pictures yet of the new chucks.
ASCD 18 200W4 impact
ASCD 18 300W2 wrench
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Well, they look "better" than the previous line, it is a step in the right direction.
The batteries still look pretty hefty but they might not weigh that much.
They look a generation behind in size though, if the Metabo LiHD and Festool 3,1Ah are a reference to go by.
The batteries are likely to be 5,2/5,5Ah batteries on the images though so maybe Fein has some compact 3-ish Ah batteries up their sleeve.
« Last Edit: April 02, 2017, 12:32 PM by Henrik R / Pingvinlakrits »
Offline Mike Goetzke
I know this is an old thread but I'm looking to get a Parf kit to make a few MFT type slabs. It comes with a Centrotec end on the drill bit. I have Makita power tools and Bosch 1/4" hex drive adapters for my drill chucks.
I see from this post that there are a couple parts needed to make this compatible with Centrotec QD.
If you watch this video starting about 12:18 he takes the drill chuck off his Bosch drill to expose a QD. This seems to work well with the Centrotec.
http://www.youtube.com/watch?time_continue=744&v=Z0QybYFDBoQ
Can a 1/4" hex drive this bit? Or does his Bosch drill have a Centrotec QD under the chuck?
Thanks,
Mike
Offline Jmacpherson
Thanks,
Mike
The parf guide system bit is compatible with festool centrotec, regular jacobs chucks and 1/4 bit holders or the short 1/4 like many quick change drivers have these days.  It was designed to work with anything.
I believe Axminster or Fisch make it and they also have an entire range of drill bits and driver bits that have the same centrotec /regular 1/4 compatible combo shank.
Guys in the UK and Peter Parfit himself will have more info
@Jmacpherson
Thanks for the info..
Mike
Offline Jiggy Joiner
I can see how some would benefit from an adaptor, where as others it might not be so important.
I have a different albeit much more expensive solution to to multi bit issue. Many years ago, I earned good money erecting aluminium structured buildings and roof’s. These systems needed various sized holes to be drilled and various types of fixings, all with different head fittings. We used to spend the whole day chopping and changing drills and driver bits, it was very fiddly and laborious.
So, I invested in more drills and drivers, until eventually we had almost a dedicated drill or driver, for every drill and fixing head.
Obviously initial set up meant getting all the drills and drivers in place and set up but, once done, we used to get the jobs done way quicker, and in a more enjoyable way.
We still have a lot of drills and drivers now, and use a similar method on many jobs. Many comment and ask why so many drills and drivers but, when they see how fast and efficiently we work, they’re impressed.
When I first started out, it was plain slotted screws, or Phillips or Pozi. Now you have Phillips, Pozi, Allen, square drive, Torx drive, security torx drive, Tech screws, Speed screws, self drilling etc, etc.
Anyway, as I say, our method is expensive but, it works for us.
Offline kbwoodworker
I have the Bosch 12v multi-head drill/driver set and just used it to make an MFT top with the parf guide kit.  It worked fine.  If that was what you were referring to, Mike.
Offline Wee Bob
Hi fog,
I would very much appreciate if someone whom uses the fein ascm12 and fein bit holder can accept centrotec drill bits without any modification.
T
Offline wpz
Made an attempt today to make my bosch 12v drill centrotec compatible:
318364-0
318366-1
wpz
Offline wpz
some more pictures:
318368-0
318370-1
318372-2
318374-3
318376-4
318378-5
318380-6
318382-7
318384-8
318386-9
So I guess I have a Centrotexi-Click now (or a Flexi-Clickotec?)
wpz
« Last Edit: July 22, 2020, 10:36 AM by wpz »
Nice built/mod.!
Kind regards,
Oliver
Kind regards,
Oliver
Offline wpz
@Oliver
Thank you Sir for your kind words.
wpz
Offline ScotF
Cool. What did you have to do, if anything?
Offline fuzzy logic
That looks really interesting.  Looks good - made or purchased?
Richard (UK)
Decent people do the right thing - always?
Offline Bob D.
Nice work adapting the CentroTec to fit your Bosch FlexiClic drill/driver. I have that same model and would like to use CentroTec bits with it at times. Can you explain what you did to make it fit.
Offline wpz
First of all, be aware that this mod/hack will void your warranty and may damage your tool, so I do not recommend you do this.
If you choose to do so anyway, it will be at your own risk. Please use common sense!
This is what I did:
I basically cut the bitholder sleeve off the flexiclick bitholder, fitted a copper bushing (press fit and superglue) over said bitholder and ground an indentation in it for the centotec chucks' ball-lock.
Tools used:
- a bosch rotary tool (looks like a dremel) with following attachments: cut-off wheel, sanding drum, grinding bit.
- some sandpaper
- a small hammer
- a piece of copper tubing
- cyanoacrylate glue (superglue)
The centrotec chuck is actually permanently stuck onto the flexiclick bitholder in my case because I chose to machine the copper tubing to a slightly larger diameter than the original centrotec fastfix axle (on my T18) so I would get a press fit there as well and not just rely on the ball-lock. This of course means that I cannot exchange the centrotec chuck for the festool fastfix drill chuck, but I don't consider that a problem as I have the bosch flexiclick drill chuck.
I have no idea if it will work on the long term, as this is basically a prototype to see if it's practical. If it works well, I might go trough the effort of machining an entire new piece in steel to replace the bitholder completely so it has inbuilt centrotec compatibility.
wpz
Offline wpz
The reason I chose to modify the Bosch GFA12-X bitholder is because although the centrotec bits fit in it, it would not hold them tight enough, especially the drills would get stuck in the workpiece and you have to wrench them out.
Then I came across these 2 pictures posted in the German Bosch forum (BOB forum) by higw65:
318503-0
318505-1
and these inspired me to try and make a centrotec version.
(link to the thread in the forum: https://www.bosch-professional.com/de/de/community/category/gsr-12v-35-da-isser-der-kleine/13575765-t/p28#main )
The Bosch drill was already out of warranty and I had already modified it anyway as it originally was a bruschless GSR 10,8V-EC HX model without the flexi-click attachment gearbox, but with a fixed bitholder. I swapped out this gearbox for one of the GSR 12-15FC (which has a brushed motor) gearboxes so that I got a brushless flexiclick drill. This was also a hack from higw65 that I found on the BOB forum. Back then Bosch did not have a brushless flexiclick drill in it's line-up, now they do: the GSR 12V-35 FC.
318507-2
In this picture you can see the steps I took:
- step 1: I cut off the bitholder sleeve with a small grinding wheel on a dremel tool
- step 2: take off the ball-lock (A), the spring (B) and 2 spring steel locking rings (C & D)
- step 3: (optional) I cut off a small piece of length from the bitholder, so the centrotec chuck would sit as close as possible to the flexiclick chuck. You have to measure this carefully, if you cut it too short, the hex hole in the bitholder will not be deep enough to hold and turn your centrotec bit properly! Be aware that there are 2 versions of the GFA12-X: a long one and a short one.
318509-3
318511-4
-step 4: as the bitholder is a bit too small in diameter, you need some kind of bushing to fit over it. I made one out of a piece of 15mm copper pipe. After you put a bit of CA glue and press fit it over the bitholder, you have to grind a groove in it, so the ball-lock of the centrotec chuck can engage.
- step 5: grind the copper bushing down to the right diameter so the centrotec chuck can fit over it. I chose for a really tight fit on purpose, so that it is permanently fixed (press fitted and glued). You could also grind down the copper a bit more so that it is possible to make it detachable like a real centrotec.
Off course, you could also just buy a Festool TXS and avoid all this mess.
The reason I did not do that, is because I had quite a lot of other Bosch 10,8V (12V) tools already and want to stick to only 2 battery platforms: Bosch 12V and Festool 18V.
I hope this helps
wpz
« Last Edit: July 26, 2020, 07:12 AM by wpz »
Offline Bob D.
Thank you for explaining the process. Something to consider when my tool is out of warranty.
