Frank, one of the best tool reviews I have ever read. Impartial, likes and dislikes for all 3 saws. One request for a further test, cut a corbel from the thickest material possible for your blades.
I am overwhelmed by your praise. Thanks, it really means a lot to me.
I decided to break the Corbel Cutting into two different tasks:
(1) Cut a corbel in 5cm thick MDF using a S 75/4 fast scrolling blade
(2) Cut a corbel in 12 cm thick MDF using a S 145/4 FSG blade
Here is the corbel pattern:
Task 1: This was done with all four saws.
With the Bosch, I used the splinter guard, the light and the blower:
With both Carvex saws, I used the splinter guard, the light and dust collection. Here is the corded Carvex in action:
With the Trion I used the splinter guard and dust collection.
The results were just about the same with the Bosch and with both Carvex saws. I managed to follow the line perfectly except right in the two interior corners and the angle of the cut was a perfect 90 degrees throughout. I needed to clean up the interior corners a bit with a file and sandpaper and, after I did this everything looked good. Here are a couple of photos of the edge of the Corbel cut with the corded Carvex
(before cleanup) :
Because of the lack of a built-in light, I did not follow the line perfectly with the Trion and I messed up one interior curve a little bit. Again the cut was a perfect 90 degrees.
Task 2: This was only done with the corded Carvex.
Here is the saw and blade:
The cut was surprisingly good in spite of the fact that the blade is thicker, wider, and has larger teeth. Again the angle of the cut was a perfect 90 degrees throughout. Here is photo:
