Author Topic: CXS or TSX?  (Read 7635 times)
Offline rp127777
CXS or TSX?
« on: December 17, 2017, 11:55 AM »
Which would you buy first and why?
Offline ben_r_
Re: CXS or TSX?
« Reply #1 on: December 17, 2017, 12:07 PM »
First? Are you intending to buy both anyway?
Offline petersd
Re: CXS or TSX?
« Reply #2 on: December 17, 2017, 12:11 PM »
I looked at both. Ended up with the CXS and am very happy with it. A great little drill.
Offline rp127777
Re: CXS or TSX?
« Reply #3 on: December 17, 2017, 04:01 PM »
Eventually I may buy both, but will only buy one now and then before the second one, I will buy other tools.
Offline ScotF
Re: CXS or TSX?
« Reply #4 on: December 17, 2017, 04:13 PM »
I would suggest trying them both out at a store. I really liked the TXS and thought it was an extension of my hand and the CXS not as much. Both are nice drills, though. Great balance, ergonomics and handy.
Offline Runhard
Re: CXS or TSX?
« Reply #5 on: December 17, 2017, 04:17 PM »
I have both and really like both of them. I bought the CXS a few years before the TXS was available. I also have a T18+3 (my fist Festool drill), three Milwaukee’s, and two DeWalts.
I would still buy the CXS first if I had to do it over again.
« Last Edit: December 17, 2017, 07:14 PM by Runhard »
Daniel
Offline Knight Woodworks
Re: CXS or TSX?
« Reply #6 on: December 17, 2017, 05:19 PM »
I own both. Got the CXS first, then the TXS. Initially I liked the T handle more, after a couple of years I've decided the prefer the CXS. As others have suggested, if possible, try them both before you buy.
John
Offline Birdhunter
Re: CXS or TSX?
« Reply #7 on: December 17, 2017, 06:05 PM »
Like Runhard, I bought the CSX before the TSX was out. I did later buy the TSX and ended up preferring it. The CSX seems to get into tight spots better than the CSX. The TSX feels better in my hand better than the CSX. Both are great drills. If possible, handle both before buying.
Birdhunter
Offline jeffm13
Re: CXS or TSX?
« Reply #8 on: January 09, 2019, 09:13 PM »
I tried the CXS and the TXS.  The TXS fit my hand better--the CXS felt a little cramped to me.  So I chose the TSX.  And the T18...  Definitely try them both before you choose.
Festool: TS75, DF500, DF700, OF1400, LR32, ETS EC 150/5, DTS400, RS2E, T18, TXS, CT36, PS420, FS1400 (2), FS1400/2-LR 32, FS 2424/2-LR 32, Tradesman/Installer Cleaning Set; TSO: MTR-18, GRS-16 PE, TDS-10, TPG-20/30; UJK: Parf Dogs, Super Dogs, Parf Guide System MkII, Seneca: Parallel Guides, Domiplate, Domishim; Makita: 3000mm Guide Rail; Jessem: Mast-R-Lift w/metric conversion kit, Pow-R-Tec Router, Mast-R-Fence, Mit-R-Slide, ClearCut Stock Guides; Grizzly: G0441 Cyclone, G0691 Table Saw; Laguna: 18BX Bandsaw; Robland: X31 Combination Machine; Incra: MagnaLock Cleansweep; Woodpecker: 1281-300mm, 600mm T-Square, 1200mm Ruler, 1200mm Story Stick Pro; Bosch: GCM12SD Glide Miter Saw
Offline jarbroen
Re: CXS or TSX?
« Reply #9 on: January 17, 2019, 11:52 AM »
Flip a coin... lol
I have the CXS.  I tested both at a store and really liked the ergonomics of the CXS.  It also is handy to have more bit storage on the handle.
In the bigger drills I didn't like the C and ended up with a T18 which seems like it has better balance.
The CXS feels to me like an extension of my hand.  Makes it so easy to use.
Offline Birdhunter
Re: CXS or TSX?
« Reply #10 on: January 17, 2019, 03:04 PM »
Have both. Prefer TSX due to ergonomics. Purely a “feel” thing.
Birdhunter
