Author Topic: Festool 494340 LR 32 Guide Plate  (Read 1297 times)
Offline DjTommyboypro
« on: November 10, 2019, 11:38 AM »
Does anyone know if the Festool guide plate will fit on the makita 2301 router
Offline RNEMTP
Re: Festool 494340 LR 32 Guide Plate
« Reply #1 on: November 12, 2019, 04:15 PM »
I'm pretty sure the LR 32 guide plate it specific to the OF 1400 and OF 1010 by Festool.
Offline Bob D.
« Reply #2 on: November 12, 2019, 05:22 PM »
Just for kicks I made a prototype using some 5mm plywood for my PC690 router a couple years ago. It worked but I never bought a piece of aluminum to make a permanent one from. I just use the OF1400 but I wanted to see if it would work.
The shim locks the pin up so you can slide along the rail without engaging a hole every 32mm.
« Last Edit: November 12, 2019, 05:25 PM by Bob D. »
