Author Topic: Domino 700 XL connectors for stair railings  (Read 1390 times)
Offline Motor
  • Owner of Finishing Touch Carpentry
« on: February 22, 2021, 07:36 AM »
I bought the Domino XL connector kit for a recent stair balustrade job. They worked really well. I made a How-to YouTube video on them. Check it out on my channel Scott Earl Smith Finishing Touch Carpentry.
« Last Edit: February 22, 2021, 08:54 AM by Motor »
Offline Mike Goetzke
Re: Domino 700 XL connectors for stair railings
« Reply #1 on: February 22, 2021, 08:28 AM »
Sorry - can't see the video link.
Offline Motor
« Reply #2 on: February 22, 2021, 08:36 AM »
Okay. Not sure how to link it but I will take another look.
Offline Motor
« Reply #3 on: February 22, 2021, 08:54 AM »
Fixed it.  Thanks
Offline Rick Herrick
« Reply #4 on: February 22, 2021, 09:16 AM »
Thanks Motor, I enjoyed this video.  I like your style of presentation.  I have the 500 but still want to do a  couple of beds down the road so always looking for help/tips on using these connectors.  Thanks for sharing.
« Reply #5 on: February 22, 2021, 09:30 AM »
Nice job Motor on both the railing and the mortised balusters.  [thumbs up]
Offline ChuckM
« Reply #6 on: February 22, 2021, 10:23 AM »
Half way through the video, I was about to file a complaint against it...but I realized that it wouldn't be a good idea when I saw its complaint policy..... [eek] ;D
« Last Edit: February 22, 2021, 10:25 AM by ChuckM »
Offline Motor
« Reply #7 on: February 22, 2021, 10:23 AM »
hahaha
Offline Motor
« Reply #8 on: February 22, 2021, 10:24 AM »
Glad you liked it. Thank you
Offline Motor
« Reply #9 on: February 22, 2021, 10:24 AM »
Thank you!
Offline Motor
« Reply #10 on: February 22, 2021, 10:25 AM »
Half way through the video, I was about to file a complaint about it...but I realized that it wouldn't be a good idea when I saw its complaint policy..... [eek] ;D
Haha. good plan!
Offline MikkelF
« Reply #11 on: February 24, 2021, 07:17 AM »
Great videos. Saw all of them and also subscribed to your channel. Looking forward for you to share more videos with us  8)
Offline Motor
« Reply #12 on: February 24, 2021, 07:22 AM »
Thank you so much. More videos coming soon!
Offline Yardbird
« Reply #13 on: February 24, 2021, 09:23 AM »
good video, Motor.   I am a DIYer and built and installed my own finished stairway.  I definitely found out a formal stairs separate the men from the boys!   My railing was "over the newel post" style and had three turns in it before it came to the bottom where it curled over the newel post and four other balusters.  With a over the newel post design, any mistake in cutting follows all the way whereas with a post to post design a problem can be corrected between those posts.  It was "interesting" trying to figure out how to set the newel posts and angle cuts.  I stretched strings in mid-air to try to determine post heights going down the stairs and determine angles. I did not know any tricks and had to come up with my own method. My first cut on the expensive curved drop piece of railing became expensive scrap.  I hit the angle perfectly, but did not adjust for hitting the profile at 90 degrees so the profile was WAY OFF.    Everything was doweled together or the hidden bolt fasteners for the railing. I used expanding gorilla glue which created problems when I discovered I could not clamp it together.  I also recommend buying the profile metal scraper for that exact railing to "sand" the railing pieces to fit together where I could not use a sander.  That worked great and is a must-have.
It was my hardest project to date but came out great.  Doing things myself teaches me great respect for those who do it for a living.  If I did it for a living I would only be worth about a nickel a hour because I was so slow. Anyway, when I walk into a house my eyes search for the stairs and woodwork as a first measurement of the quality of the house.  I highly respect your craftsmanship.
Offline Motor
« Reply #14 on: February 24, 2021, 09:49 AM »
Glad you liked it. Subscribe if you feel inclined. My channel is new and needs support. Don't feel bad about taking a long time. It happens to me as well especially when it comes to curved fittings. I remember cutting into a 250-dollar goose-neck-curved fitting and breaking into a cold sweat and praying before cutting the piece. Not only are they expensive but generally have to be re-ordered and can set your project back quite a bit. I have several other videos on stair and railing work in development. Stairs and railings are probably the most complicated speciality in carpentry so my hats off to you for pulling it off. Cheers Scott
« Reply #15 on: February 24, 2021, 10:02 AM »
Yes, great video! As a hobbyist nice to see the process start to finish. Plus showing us the "tricks of the trade" with the hot glue to make your assembly not only more accurate but also safer to do.
Mike
Offline rmhinden
« Reply #16 on: February 24, 2021, 11:35 AM »
@Motor
Very nice video, I especially liked the temporary jigs to get good alignment with the XL.
One question, you used glue in the connections in the video.  I had thought that the reason for the XL connectors was to allow for later disassembly.    If they are intended to be permanent, why not just use beach dominos?
Bob
Offline Motor
« Reply #17 on: February 24, 2021, 01:57 PM »
@Motor
Bob
Glue was used in the railing in the video as it was actually a different railing job than the one where the customer wanted one section  of railing removable. I have simply used dominos in other railings that will be glued. One advantage of the connectors is that you can get the joint super tight. Sometimes clamps are difficult to use on long pieces of railing too.
Offline Motor
« Reply #18 on: February 24, 2021, 01:59 PM »
Mike
Thank you!
Offline rmhinden
« Reply #19 on: February 24, 2021, 03:09 PM »
Thanks, that makes a lot of sense.
Bob
Offline Motor
« Reply #20 on: February 24, 2021, 03:15 PM »
Bob
... I'm also eager to use the connectors for a table and or bed frame where I can assemble the parts on the job site.
