« on: November 11, 2012, 09:16 AM »
Hello all,
I have purchased the CMS OF unit and was quite impressed on how easy it was to install and set up. I have a question for anyone who has some experience with the unit. Is the sliding table supposed to be flush with the main table or be slightly higher. If it is supposed to be slightly higher, then, when you apply pressure on the work piece, it does not hit the bit at 90 degrees, it is at a slight angle. Which is the correct set up?
Thank you for your help.
Demetrius
TS55,CT33,OF1400,Domino,RTS400,T15+3,T12+3,HL850E,KAPEX,MFT3,MFT KAPEX,KAPEX extension set,ROTEX 150,OF2200+IMPERIAL SET,CT MIDI,TS75,PARALLEL GUIDE SET,CT26E,MFK700SET,OF1100,ETS150/3,RS2E,EHL65E,C12 & SYSTAINERS GALORE
