One cut with the KS 18 LTX 57 and then I threw it in the garbage. I’ve never seen an arbor wobble so much. I’m not alone. Do a look-see on another certain forum for a brand that uses Metabo batteries and a track system that Bosch shares. We discussed how horrible of a product the Metabo saw is. It can’t cut straight to save it’s life. As for the Dewalt, I can’t speak on it. Ridge Carbide makes a couple of $110 blades for it that have a thick plate, kerf and more carbide than you could dream of. You mentioned Trend blades so I’m presuming you’re either in the UK or whereabouts? I just ordered what appears to be Leitz blades (Mafell/Festool OEM) branded as Bayerwald. Dewalt tracksaw is 165x20, correct? They have a 24, 36 and 48. May be worth checking out?
Devils advocate: If you’re familiar with Bosch Expert thin kerf blades from Italy, imagine the amount of steel and carbide removed to get them sold here as Diablo for $6 a pop. They bend by blowing on them. Never heard of someone having an issue. I used to think the Diablos were ridiculously thin but then I met Makita. Here they sell what I thought was the thinnest circular saw blade I’d seen. However, in Japan, many brands offer 1.0 kerf blades for their 125mm circular saws. It’s insane. I’ve not used them enough to comment. Anyway, I was on the thicker plate bandwagon (was super anti thin kerf), and yes, the plates on the Mafell (and the HK) are not at all unsubstantial for their kerf. But, at the same time, I’ve been using the cheapies (Diablo) at work and I’ve noted that the results go against my prejudice.
For the Dewalt, try some thicker blades, who knows? For the Metabo, you have at least one person on the inter webs telling you that on their own specific unit…it was the saws fault.
