Author Topic: CARVEX PS vs PSC  (Read 2961 times)
Offline nj_five
CARVEX PS vs PSC
« on: September 12, 2021, 10:40 AM »
Found a few threads discussing cordless vs corded on the jigsaw but not ergonomics. Anyone else find that the corded version has a better grip/control than the cordless?
Seems, at least for me, that the position of the battery makes it hard to get a good grip on the back of the tool.
Offline Bert Vanderveen
Re: CARVEX PS vs PSC
« Reply #1 on: September 12, 2021, 11:59 AM »
I mostly read/hear that the battery affects the balance, not in a positive way. But I do not have first hand experience. : )
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Gj12
« Reply #2 on: September 12, 2021, 12:15 PM »
I found the corded version more comfortable, but not having the cord was worth it for my work flow.
Offline Birdhunter
« Reply #3 on: September 12, 2021, 12:33 PM »
I’ve got both. I always pull out the battery version. Not ergonomics, just more convenient. My favorite is the Bosch jigsaw.
Birdhunter
Offline MrToolJunkie
« Reply #4 on: September 12, 2021, 11:58 PM »
I have found the cordless has better control than the corded. I never got quality cuts with the corded saw because it bounced around too much. The cordless has always performed well for me. I sold the corded saw.
Offline leakyroof
« Reply #5 on: October 07, 2021, 03:27 PM »
  Really.... interesting.... I would have thought the power source would not have affected the drivetrain if you will of the saw that much.... Hmm...Your complaint of the Bouncing Around is something I can def relate to with my own Carvex.... [scratch chin] [scratch chin]
Offline mino
« Reply #6 on: October 07, 2021, 06:18 PM »
The battery is heavy and far from the cut - it takes a significant momentum to move the saw with the battery weight, making the tool more stable.
When I need stability, I use my PSC with the heavy 5.2 battery.
When I want agility/work on ceiling etc., I use it with a 1,5 Ah 12V battery from my C12 which is 1/3 the weight or so.
Is almost like having two different saws in one.
« Reply #7 on: October 07, 2021, 07:25 PM »
Agreed! Swapping for smaller batteries is a plus.
Offline Coen
« Reply #8 on: October 14, 2021, 04:54 PM »
And then you work on the ceiling without dust extraction? Okay.
Although having said that... I spend a bunch of time this weekend on a folding stairs / ladder / whatever is the correct English word for the A-shaped steps, with a battery powered vacuum with shoulder strap and a cordless drill in the other  [tongue]
So the weight issue... I guess I can just keep my Trion, that one is heavier than the Carvex. I was never really bothered by the weight. The hose was the bigger issue and in some houses the 3.5m hose really cuts it tight.
