Peter,
Nice review as usual. I really like the vibration-dampening front section - I didn't even realise it did this!
Just wanted to make a couple of points:
Firstly, I have the vac attachment thingy that sucks to the wall - it's awesome! But, in your video you put the 27mm hose end into the angled adapter. You don't need that - you can actually remove it by rotating it round to the back and it slides out, and the 27mm hose end fits perfectly. The adapter is (presumably) to accommodate different hose end diameters. Taking the adapter off makes it hold even better too, as the hose is at a more natural downward angle.
Secondly, and I must admit I haven't watched the video in full yet (just skimmed through it) but I didn't see you mention the lack of a chisel function (rotary stop, hammer only) on the drill.
This, in my opinion, is the biggest ****-up Festool could possibly have made with this machine. How could they release a machine this good, but completely ignore a vital function like this? I mentioned this (back when the release was first delayed) to a Festool rep, and was given the company line of "well, we've done extensive research, and found it's not necessary on a battery powered SDS". That's complete bull, and the look on the guy's face as he said it told me he knew it too.
The 'research' that they did showed that a battery powered SDS wasn't the correct tool for demolition work, and that a heavier, mains powered drill should be used for this. If you're demolishing brick walls every day then yes, that's true. But, as a kitchen and bathroom fitter, one of the main 'demolition' jobs I come across is removing tile - and a lightweight, battery powered chiselling tool is the perfect tool for this! There are also loads of other light demo jobs that you could do with an 18V machine. Having said that, another fitter & I did take down a brick chimney breast in a kitchen with nothing more than an old 24v Makita. It was really a bit too big a job for that tool, but it did it!
They can't even say that it's not possible to put a rotary stop on this machine either - the gearbox used on this drill is lifted directly from an older Protool model, and they also did a version of that drill with rotary stop. So they could easily have done it, but chose not to! Utter madness!!!
I can in all honesty say that if it had that function, I'd own one already. I know a couple of people who are of the same opinion as me, and who would have bought them. Instead, they both own Makita 18V SDS drills that do have rotary stop. At the moment, I still use my mains SDS, as I really don't want to buy a battery tool that's not compatible with the Festool 18V system, but I can't justify buying the BHC18 as it is.
I'm desperately hoping Festool realise the mistake they've made and bring out another version with the rotary stop, but I'm not holding my breath.
![Sad [sad]](https://www.festoolownersgroup.com/Smileys/default/sadsmiley.gif)
