Author Topic: Very Loose tenons with Domino XL  (Read 2819 times)
Offline Berber5985
« on: December 10, 2020, 01:15 PM »
I’m working on my second project where I’m using my domino and I’m using the Seneca small mortise adapter for the first time and doing 6mm tenons in some rails. I did about 12 total for the project and every single one of my joints is very loose on top and bottom. Like a decent amount of play. The first project I did with the 8mm cutter and tenons was a table with rails and those tenons were tight as heck. I’m not sure it’s user error, the cutter, the adapter, etc. It’s got a fair amount of play in the joint where you can even twist them slightly. I glued them together like that so we shall see if they hold after they dry, but I was kinda deflated. Has anyone experienced this? Could it be user error on every single mortise even though my first project worked out perfectly or potentially another issue? Oversized cutter from the factory, wobble with the Seneca extension, etc?
Online ChuckS
Re: Very Loose tenons with Domino XL
« Reply #1 on: December 10, 2020, 01:53 PM »
Can you check the cutter's size as well as the width (height) of the mortises with a caliper? If they aren't the same, it could be due to the adapter and/or user error.
« Last Edit: December 10, 2020, 05:46 PM by ChuckM »
Offline ear3
« Reply #2 on: December 10, 2020, 04:18 PM »
@Berber5985 Welcome to the FOG! Sorry you're having this problem.  There's a bit of a learning curve with the machine, but given your narrative I would try to rule out the adapter first. So run some tests without the adapter on all the cutters and see if you get tight mortises like you did the first time.  Then repeat with the adapter and the smaller cutters.
The only time I have gotten loose, oversized mortises with the XL was when using the CMT branded 10mm cutter.  Have never had a problem with the OEM Festool cutters.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline Berber5985
« Reply #3 on: December 10, 2020, 07:11 PM »
I’m gonna give that a shot tonight and see if it’s just the 6mm cutter, the adapter, or myself. Just seems odd that it worked great for the first project and then really Loose for the 2nd project and all I changed the was the size of the mortise and the adapter. I glued up the project to see if it held together. Fingers crossed because I really don’t want to remake the whole thing.
Online ChuckS
« Reply #4 on: December 10, 2020, 07:16 PM »
It's hard to tell if the joints will fail as you didn't provide any info. on what they are. If it's edge jointing (panel glue-up), there should be no failure risk. On the other hand, if the joints will be subject to stress/racking, it's a different story. Many joints fail (chairs are good examples) only after a period of prolonged use.
Offline mrtmr
« Reply #5 on: December 12, 2020, 02:04 PM »
I agree with the comment above about the learning curve. I found the surfaces weren't as nicely aligned with some of my first projects. But got better with practice.
I also found a correlation between the wider settings for the mortises and slightly offset joints. My preferred method that has consistently worked well is to mortise one side of the workpiece on the tight tenon setting and using a wider setting on the opposite side. I use this method for the aligning planks for tops, or detailed furniture/door joints. Only problem with this method is the cross stops work best for same width mortises.
Offline tsmi243
« Reply #6 on: December 13, 2020, 07:37 PM »
Maybe you got my old one....
I exchanged it under the return policy, and the new one works just fine.
