Author Topic: TS 75 tight arbor nut  (Read 1890 times)
Offline abgoto
« on: October 24, 2014, 07:32 AM »
I recently received a reconditioned TS 75, which, except for the blade, looked practically new. The blade had quite a bit of pitch on and around the teeth, so I thought I would remove the blade to clean it. Despite repeated attempts, I was unable to remove the arbor nut with the supplied hex key. I watched a couple of videos on changing the blade, and did some reading on the forum of similar problems people had with the Kapex.  I used a three foot length of steel pipe as a cheater bar on the hex key, and finally was able to loosen the arbor nut. It was a nerve racking experience as I was concerned that I would snap the hex key, or damage the saw or both.
My suggestion is that the reconditioning process include removal, cleaning, and appropriate retightening of the arbor nut to prevent a similar issue in the future.
Offline ear3
Re: TS 75 tight arbor nut
« Reply #1 on: October 24, 2014, 10:32 PM »
Strange.  My Recon-ed TS55 came with what looked like a brand new blade.  If it wasn't, I couldn't tell the difference.
Offline abgoto
« Reply #2 on: October 24, 2014, 11:20 PM »
I have no issue with having to clean the saw blade.  My assumption is that, at 40% off,  these tools were used for a month and returned. Not being able to remove the blade was my concern.
