Hi all, looking to help from the collective wisdom of the group to try to troubleshoot an issue I’m experiencing with my TS 55 when making bevel (45*) cuts.
What is happening is that the saw doesn’t cut to the splinter guard at the beginning and end of the cut. I get a curved cut where the curve is more pronounced at the end of the cut.
I’m the attached pics, I made a pencil lone using an inexpensive carpenters square, aligned the splinter guard on my track to the line and made the cut.
Despite the fact that my carpenters square isn’t top quality, the splinter guard of my track aligns well with the pencil line.
I then make the cut in the conventional way: saw overhanging the material, motor up to speed before plunging, fingers on the base to prevent tipping, etc.
As you can see in the photos below, the cut line drifts from my pencil line/splinter guard at both the front and back of the cut.
-I’m using the standard blade that comes with the TS 55
-I’m cutting my 18mm BB ply over ~21”
-I’m tightening the rear angle-adjust knob prior tightening the front knob
-I’ve tried this with two different tracks (both 55”)
-I don’t see the same behavior when making 90* cuts (the saw cuts to the splinter guard along the entire length of the cut).
Any idea as to what might be causing this?
