Author Topic: Kapex stalling out  (Read 974 times)
Offline koschak
Kapex stalling out
« on: March 30, 2021, 08:09 AM »
Recently I was cutting mdf crown molding and thought the little bit of smoke I thought was in the air was from the blade binding on the material. I have clean, sharp blade so thought it was funny but carried on and finished my tasks. A couple days later my next cuts were through some 6/4 kiln dried ash and I could barely make the cut without the saw losing all its power. When running the saw wide open and the blade not engaging any material, there is a lot of arc'ing going on in the motor housing. I unplugged the saw and pulled out the brushes and they are barely worn at all, although the contact surface had some scoring in it. I went to spin the blade by hand to inspect the armature and it has a few rough areas on it, and something now clicks inside the motor housing area when the blade is manually spun. Have I lost a bearing on the motor? I bought this saw probably 8-9 years ago but I am only on its second blade and only pull this saw out for detail work. I do not woodwork full time and would consider this saw barely used. I hope I do not have to put hundreds of dollars in to this....
Offline koschak
Re: Kapex stalling out
« Reply #1 on: April 01, 2021, 08:35 AM »
Does anyone know what the problem is or have had this happen?
Offline xedos
« Reply #2 on: April 01, 2021, 09:06 AM »
yep, you've got a kapex with the notorious motor problem that wasn't a problem until it actually was.  Sort of.
Call / email Festool to initiate a repair, with luck they'll replace it out of goodwill.
Offline deepcreek
    • TimberFire Studio
« Reply #3 on: April 01, 2021, 09:51 AM »
The dreaded puff of smoke...
and another one bites the dust.
Festool service covered the labor to repair mine.  I paid for the parts and shipping both ways.
I have read about them doing this for others as well but heard more recently that they were charging the full rate.
Good luck!
Joe Adams
TimberFire Studio
Houston, Texas
Offline Mortiser
« Reply #4 on: April 01, 2021, 10:18 AM »
Depending on what Festool service says, if you're mechanically inclined, on a saw out of warranty, you may want to try this...
https://www.festoolownersgroup.com/festool-tool-problems/fixing-kapex-120-eb-motor-problem/msg607186/#msg607186
Offline ChuckM
« Reply #5 on: April 01, 2021, 12:57 PM »
If it's indeed one of the smoking cases, the consolation is that after the fix (with the new, improved parts), the problem should go away for good.
Those of us having the EB model can only pray and hope.... [sad]
