Author Topic: Stuck Router bit and collett in my OF 1400 router  (Read 2025 times)
Offline Jstew1
« on: November 21, 2020, 07:25 AM »
I have loosened the collett on my router but can not get the collett and router bit out of my router
Offline AstroKeith
« Reply #1 on: November 21, 2020, 09:02 AM »
You say 'loosened', have you completely undone the nut?
Retired engineer/scientist
Offline Alex
« Reply #2 on: November 21, 2020, 09:32 AM »
WD40.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #3 on: November 21, 2020, 09:32 AM »
What Keith means is that there are two stages to undoing Festool collets (and most others). The first stage loosens the nut from its grip on the collet and the second part is when the continued loosening causes the collet to release from the bit. In between the two stages the nut is free to move with your fingers.
Offline Bugsysiegals
« Reply #4 on: November 21, 2020, 09:40 AM »
I just watched Festool Live yesterday about OF 1010 and Sedge said this happens from inserting the bit all the way. I guess as it heats up it can get bound up so he suggested to bottom the bit and then pull it back just a bit to avoid this. He said you’d need a puller to remove the bit but I’m not sure what kind of puller he’s referring to...
Offline Mike Goetzke
« Reply #5 on: November 21, 2020, 10:24 AM »
I think it was from a Sommerfeld video I placed a small o-ring in the bottom of the collet.
Online rst
« Reply #6 on: November 21, 2020, 10:44 AM »
I learned the o ring in the bottom of the collet years ago from an article in Fine Woodworking, I now just pull the bit up a bit after inserting.
« Reply #7 on: November 21, 2020, 10:49 AM »
What shape cutter is it?
Offline Jstew1
Re: Stuck Router bit and collett in my OF 1400 router
« Reply #8 on: November 27, 2020, 05:26 PM »
Sprayed some PB Blaster on it and let it sit over night.  Bought a $12 puller at Harbor Freight and it popped off.  Thanks for the inputs
Offline Stan Tillinghast
« Reply #9 on: November 28, 2020, 01:23 AM »
I had this happen years ago the first time I used my new Elu router. This was way before the internet, so no help was to be had. I finally worked out that removing the nut entirely was the key; and somehow found out not to let the bit bottom out in the collet.
Für uns...ist das Beste gerade gut genug!
Offline Crazyraceguy
« Reply #10 on: December 06, 2020, 11:03 AM »
A simple tap on the side of the collet with the wrench will pop it free.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
