Author Topic: Stalling / Intermittent problem on ETS EC sanders  (Read 14993 times)
Offline SRSemenza
« on: March 15, 2021, 10:45 AM »
From Festool USA in blue.
         Please note this is NOT a recall.
Festool is currently investigating a product performance issue that is the result of an electronic fault affecting a small
number of ETS EC model sanders. While this issue does not pose a safety concern, it is important that every user has the
same impeccable experience you expect from Festool. If you are having an issue with your ETS EC model sander, please
submit a repair request by going to the following website and completing the required information.
https://www.festoolusa.com/campaigns/microsites/onlinerepair
Once Festool receives your sander, they will verify if the issue is related to the known component fault. If it is not,
Festool will follow their normal warranty & repair procedures with the goal of getting your tool working and back to you
as soon as possible. However, if it is related to the known fault, Festool will reach out to you specifically to give you an
update on your sander.
All Festool tools are backed by an industry unmatched 3 Year Warranty/Service All-Inclusive program designed to give
customers peace of mind in situations like this. We sincerely apologize for any inconvenience this may cause and thank
you for your confidence and understanding as we work to resolve this issue as soon as possible.
« Last Edit: March 15, 2021, 10:54 AM by SRSemenza »
Offline mino
Re: Stalling / Intermittent problem on ETS EC sanders
« Reply #1 on: March 15, 2021, 11:22 AM »
For those asserting that "Festool should check/test their tools before release."
Things like this usually indicate a manufacturing issue which is not (yet) precisely understood.
E.g. a subcontractor component like a capacitor having a higher variance in its properties in turn causing a higher occurrence of unexpected behavior. E.g. way faster degradation of a random selection capacitor would not be detectable at manufacture time but be able to semi-randomly increase failure rates etc. etc.
The best thing is to send a matching mis-behaving tool to Festool to look into. The more affected tools they can identify, the easier/faster they can find or confirm root cause and come up with a remediation.
If you produce stuff things like this will happen, no matter how much quality control you do. What separates the companies is not if they have issues, but how they are handled vis-a-vis the customers.
Lets hope this gets a root cause soon. I am in line for an EC 150/5 too this year.
 [smile]
Offline serge0n
« Reply #2 on: March 15, 2021, 12:32 PM »
Any specifics on what kind of behavior an impacted sander exhibits? My ETS EC 125 refused to turn on and randomly stopped twice so far, I wonder if it's related. It has not been an issue yet as it only occurred a few times in the past 2 weeks, but I am slightly concerned as previously the sander worked without any issues whatsoever for 2 years of almost daily use.
Offline Alex
« Reply #3 on: March 15, 2021, 01:35 PM »
That is exactly the problem that is looked into. You should contact Festool.
Offline xedos
« Reply #4 on: March 15, 2021, 02:29 PM »
 [smile]
We'll just have to disagree on this.   If a new production batch was sent out 20-100 users for evaluation before going on sale or being distributed; the issue(s) would have been identified in short order.
Is this impractical , time consuming , and expensive ?  Perhaps.  But, Festool has said on this forum that they beta test tools before release.  They also said their wasn't anything wrong with the kapex motors too.
Sure every manufacturing operation has issues.  But this is starting to become a credibility issue.  If these were tested any amount of time in real use, either in house and especially in the field , this issue would have shown up.  These are not inexpensive, high volume consumer tools or from a new venture that doesn't know what they're doing.
Offline mino
« Reply #5 on: March 15, 2021, 07:57 PM »
It is not that simple as that.
You can test even 1000 units. You can even test (by test I mean run a several-years-workload-simulation) a sample from every run of 1000 or so. BUT you will still not be able to catch all possible issues.
All that needs to happen is a scenario like the one I mentioned. A higher-than-normal variance in a capacitor quality from a bad batch by your supplier and you are screwed. Unless you were lucky, your (crazy-expensive sample testing like mentioned above) would STILL not catch many potential issues at all, or not soon-enough before they reach customers.
Today's tools are complex machines and there will always be things you miss or your supplier misses. You catch the problem, root cause it, figure out the scope, issue a remediation (when needed). That is the only way to deal with these in a sustainable way.
Offline binettea
« Reply #6 on: March 15, 2021, 08:02 PM »
My ETS EC 150/5 would do it every time under load (onto a surface), usually within the first 2 minutes of operation. It could momentarily stop a couple of times, then completely stop after 2 minutes.
Offline Wood_Slice
« Reply #7 on: March 15, 2021, 08:50 PM »
It kinda sucks that my very first experience with a Festool power tool is this exact issue. I bought a ETS EC 125/3 sander end end lf 2020 and mine was produced in October 2020. It had both the intermitten shut offs and major wobble from very first use. I dont know what the issue is specifically but at this point i should think they have enough sanders being sent in for same issue to have figured it out by now. Its a small package there are only so many things that can be wrong with them. Mine was in repair for nearly a month and at that point I couldnt wait and wanted a refund instead. I dont want to have a sour feeling from my first power tool use by them. I did re-order it but not available for at least 4 months from now. Shame I have to rely on my big bix store dewalt ros.
DF 500 + Assortments | ETS EC 125/3 EQ | CT MIDI + CT-Fi| MFT3 + Elements| Installer's Set | TS55-REQ |
Offline squall_line
« Reply #8 on: March 15, 2021, 10:47 PM »
I'm sorry that this is your first experience with Festool; I wouldn't have a good taste in my mouth if my first experience went this way either, especially with a premium-priced product.
Just a word of reminder/caution that the posts on this website are not necessarily representative of the overall experience that customers have with the product, nor do they necessarily represent a reasonable sample size.  People who seek out web forums are usually a) experiencing a problem and looking for an answer, b) deeply motivated to learn more about the product, or c) looking for community and camaraderie, or some combination of those three.
I personally view this website as an enthusiast website first and a corporate outreach/customer service website second.  The experiences of people on this site may encompass a wide variety of personalities and use cases, but they certainly are not exhaustive nor statistically representative.  Forgetting this can cause institutional blind spots that manifest themselves in many different ways: corporations ignoring issues as 'not the general experience', corporations blowing issues out of proportion because of a vocal minority, customers feeling that issues are more widespread than they might actually be, customers vociferously defending the corporation against naysayers, etc.
I hope that your issue gets resolved soon and to your satisfaction.  I think there's a lot of good tools in the lineup (they're not all winners), and this seems to be a pretty good group of folk to be around.
Offline serge0n
« Reply #9 on: March 16, 2021, 12:54 AM »
Thank you. I will contact them a bit later, once it becomes a real nuisance.
@mino I agree, it's not that simple at all. Festool got to the root cause and is repairing impacted sanders free of charge if my understanding is correct. I'm out of warranty, so I wonder if they will fix mine for free.
Offline Alex
« Reply #10 on: March 16, 2021, 02:41 AM »
If your machine is out of warranty it is probably too old to be part of the problematic batch that is discussed now, as I understood it is a problem with 2020/2021 machines.
You can send your sander in, but if it is not caused by the current problem, you might be charged for repair.
Offline mino
« Reply #11 on: March 16, 2021, 07:16 AM »
IMO you did the right thing.
Once the issue is identified, it may take a couple weeks for fixed/replacement parts to be produced. Especially if the issue is in the electronics board.
Anyway, your experience would be consistent with Festool trying to figure out the root cause at the time you sent it in. Not wanting to replace a component with another (potentially) faulty one. If you do not know a precise root cause, you also do not know which batches are affected, including your spares stock..
Offline binettea
« Reply #12 on: March 16, 2021, 08:26 AM »
@Wood_Slice interesting that you also mention the wobble in conjunction to the intermittent stopping issue, because my unit also had the severs wobble/vibration. Can't really see how it would be related, but certainly interesting to note that it seems the 2 issues at least at times are appearing together.
Offline WastedP
« Reply #13 on: March 16, 2021, 09:22 AM »
The original ETC EC 125 I sent in (Festool replaced it on the third try) was purchased in Q3 of 2017.  The replacement has been running fine for a year.
Until yesterday.
I'm sending it in this week, and breaking out the "Pro 5" to take it's place, hopefully temporarily.
Offline SRSemenza
« Reply #14 on: March 16, 2021, 10:20 AM »
I don't believe that a time frame of 2020/2021 has been firmly established by anyone. It is mentioned as being the likely time frame in one post that I can find on FOG. And even that is a supposition based only on the relatively few ( in the grand scheme of things) posts on FOG.
I also have not seen anything that indicates that Festool is repairing all of them for free as a blanket concept regardless of warranty.
            I caution people in making assumptions based on anecdotal evidence from forum posts and individual experiences with Festool or dealers.  I am sure those are true and valid, but it is a big leap to say that something is definite or has been established as fact.  That's how rumors get started ...........................................
Offline Wood_Slice
« Reply #15 on: March 16, 2021, 01:59 PM »
I wonder if some odd ball some portion of Rotex parts got stuck in the ETS sanders and they just want to perform Rotex mode lol. I don't have any experience with Rotex but it would be funny.  [big grin]
Offline xedos
« Reply #16 on: March 16, 2021, 10:43 PM »
I just hope this isn't a widespread issue waiting to mushroom like the saw that wasn't a problem - but then turned out to be after all.
Offline binettea
« Reply #17 on: March 17, 2021, 08:10 PM »
Got my replacement ETS EC150/5 on the 30 days, but it also wobbles badly. I'm sending it in for warranty repairs.
Offline Macjacktastic
« Reply #18 on: March 24, 2021, 08:18 PM »
I bought my ETS EC 125/3 in 2018 and it's been exhibiting this problem since shortly after I bought it.  I finally boxed it up and sent it in for repair today and I'm really beginning to regret the purchase.  There's been a lot of speculation on how this problem can innocently crop up, but seriously - it has been around for years and it still exists?  There is something fundamentally wrong with a design process that can allow faulty products to be sent into the field - and a quality program that hasn't solved it in at least three years.
Offline binettea
« Reply #19 on: April 06, 2021, 08:26 PM »
Just wanted to add something to this. For some reason tonight I lowered the speed from 6 to 5 on my ETS EC 150/5, and the intermittent stopping issue seemed to go away. At 6, it was impossible to get any sanding done because it kept stalling and stopping. But on 5, I did quite a bit of sanding and it didn't stall or stop once. Is anybody else also experiencing that?
Offline mino
« Reply #20 on: April 07, 2021, 06:35 AM »
I would expect such behavior if the overcurrent or overheat protection was kicking in when it should not.
That would indicate an electronics or sensor issue. Best you can do is send it in for a repair.
Or if speed 5 is OK and still well in warranty, wait a couple months until Festool has it sorted so you can get your sander back quickly once sent in.
Offline binettea
« Reply #21 on: April 07, 2021, 04:54 PM »
That's what I'm thinking, and I had never read that anywhere yet, so I thought I would share in case it can help others. I'm actually nearing the end of the 30 days return window, and debating if I should keep (and send for repairs) or just return and wait for a new one to be available months down the road. The other problem I face is the vibration (or wiggle/wobble) that is very present, and so bad with a protection pad that I just can't use it that way. I was planning to use the net abrasive, for which I believe a pad saver is recommended, but the vibration is way too severe that way.
Offline Wood_Slice
« Reply #22 on: April 19, 2021, 04:56 PM »
Has anybody heard anything on this issue. I wanted to get the same sander again but I hear July is earliest for getting my hands on one again and that is an guesstimate by some of the dealers no concrete confirmation.
Offline binettea
« Reply #23 on: April 19, 2021, 06:23 PM »
I was wondering the same thing. I'm currently using mine at speed 5 instead of 6, which makes it mostly usable, as I wait to hear that they are ready to perform the repair before I send it to them.
Offline Wood_Slice
« Reply #24 on: April 22, 2021, 06:13 PM »
Saw a status update on a dealers website as of 2 days ago the expected shipping date got pushed to August this year.
Offline WastedP
« Reply #25 on: June 12, 2021, 11:36 AM »
I received my sander this week, after sending it in at the end of March.  The documentation says they replaced a board.  Service swapped out the pad and plug-it cord for new ones.  They also sent a letter that says, "Please find the enclosed gift as a small gesture of our appreciation for your patience while we brought your sander up to Festool standards."  I like the box they delivered the letter in.
« Reply #26 on: June 12, 2021, 11:45 AM »
That's nice on 2 levels, the first being that Festool feels confident that they've identified the problem and they have a solution.
And the 2nd being it was very nice to have them correspond with you at the VP level and send you a small gift...that's very thoughtful.  [big grin]
Offline mino
« Reply #27 on: June 12, 2021, 05:40 PM »
This would indicate they decided to redesign the boards to make sure the "fixed" product is less sensitive to variability of the components.
Definitely was not a case of "we got a bad batch of XYZ" from the wording.
My guesstimate is that about a year ago, they switched some component supplier and the new supplier cannot meet the same parameters consistency the former did. Likely the original supplier was selling "above-spec" parts and when "at-spec" parts were reeled-in, suddenly the variance was to high. May even be the same supplier adjusting the manufacturing line they use to make certain parts etc. etc.
I would expect the fix to be permanent, in the sense that they sure made sure such a problem will not repeat with this tool /or other/ by designing-in a higher performance margin.
I would expect their engineering team got a proper slap for being too optimistic and it will show in follow-up designs being more conservative in optimization than would be otherwise.
Offline JonnyBBravo
  • Amor Fati!
« Reply #28 on: January 25, 2022, 07:32 PM »
[ Attachment Invalid Or Does Not Exist ]
 [smile]
Yea as a proud festool owner. My newly purchased CT 48 AC burned up. An the tool doesn’t have 24 hours of total run time. Truly I’m happy to be owning festool products…… An when it’s not in use I cover it with a moving blanket. But this is what you get when you spend over $1000.00 USD. No kidding. Clearly I’m a proud owner!!!! 🤯 An not to mention going to take more than a week to get it back. As I shipped it out and won’t arrive to them till Friday. An not to mention the lack luster of anything type response when directly reaching out to Festool about the issue.
« Last Edit: January 25, 2022, 07:38 PM by JonnyBBravo »
Offline YASMINSDAD
« Reply #29 on: April 04, 2022, 10:09 PM »
UK here, I do a LOT of sanding, like 1500 discs in one job a lot...
The ETSEC is the most frustrating tool that I have bought from Festool.
I think it is the anti vibration system which is not required on any other of their sanders. One of two things is therefore true, either
1. Festool added the anti vibration feature (like the totally redundant auto no hose shut off which was solved shortly after with their clever bayonet hose end fitting) to show off what can be done with electrically commutated motors for no other reason or...
2. There is a fundamental design problem with such low profile sanders (the Deros and a Chinese copy I bought both are not the smoothest sanders) which necessitated the feature.
What I find is that the feature is worse than useless. Vibration is taken as a time weighted average, so, if you sand floors and the boards move a little the ETS will go down to speed 2, so you get slightly less vibration, but for several times as long meaning your weighted average exposure level isnt much better and your RSI risk is increased with the increased loading time in a prone position.
The sander going up and down in speed constantly is very wearing both physically and mentally.
I have over 10k hrs in hand sanders so I know how to use them. My ETS EC150/5 is very noisy and slow and will be sent back to TTS.
Apart from recent brushes in a 7 year old CTL36 and about a total of 9 sets of cables and a Working light that has probably blown a cap I have never had a Festool tool break, apart from the ETS. (In over 22 years of Festool tool use from the year they started selling tools in the UK)
Seems like a real issue, I wish they would make a way to switch off the anti vibration feature (this is what turns the machine off if the vibration goes over a certain level) a real shame too as ergonomically is is a magnificent sander, apart from the durability and anti vibe issues.
« Last Edit: April 04, 2022, 10:14 PM by YASMINSDAD »
Offline Paul L
« Reply #30 on: April 05, 2022, 10:17 PM »
I found this article to be very useful. I have owned my ETS EC 125 for almost a year and thought some how, it’s refusing to turn on and stalling once was user error. I have filled out the repair paperwork and printed the shipping label. It will be in the post tomorrow.
