Author Topic: Splinter guard strips on metal tracks repeatedly falling off  (Read 5892 times)
Offline ultane
Almost all of my various tracks have the splinter guard strips falling off, especially in warm weather. I replaced one of them with a new Festool strip. But then others started to fall off. I was told that I could use double sided tape to replace them. But the residue on the strip, and on the metal is contaminated with dust.
I’m a little short on money, and would like to not buy more of the Festool splinter guards, as they don’t hold up, especially in the heat. Does anyone have any ideas on how to clean the sticky glue off the parts without ruining the soft splinter guard, and what kind or brand of double sided tape to use?
I might be wrong… Just ask my X...
Offline Bob Marino
Re: Splinter guard strips on metal tracks repeatedly falling off
« Reply #2 on: June 15, 2018, 02:03 PM »
Here is what I do.
http://festoolownersgroup.com/festool-how-to/rail-splinter-guard-fix/msg527319/#msg527319
 Great idea - I like that. What I have been doing when the guards fall off or need to be re-cut is wipe the rail down with acetone and apply 3M Spray Adhesive, works quite well.
Former Festool  Dealer since 2002; user well before that!
Offline Svar
« Reply #3 on: June 15, 2018, 02:19 PM »
Here is what I do.
Note that my approach only works if peel off starts at the ends. If not, re-gluing is the only option.
Offline Claimdude
« Reply #4 on: June 15, 2018, 03:42 PM »
I have used Makita splinter strips with great success. I take off the loose Festool strip nd replace with the Makita strip (the Makita strips are black like the Festool strips used to be).
Jack
Offline Peter_C
« Reply #5 on: June 15, 2018, 03:53 PM »
As mentioned acetone to clean off. Then Tom offered up this alternative double stick adhesive for the strips. Also a good time to turn the strip around and extend it a tiny bit so it gets cut off again, creating a clean new edge as a cutting guide.
https://www.amazon.com/3M-Indoor-Mounting-Tape-5-Inch-13-8-Yard/dp/B00002N8T6/ref=sr_1_1?s=hi&ie=UTF8&qid=1529092197&sr=1-1&keywords=3M+Indoor+Window+Film+Mounting+Tape.5-Inch+x+13.8-Yard%2C+Clear%2C+1+Roll%2FPack
How you care for your rail is very important. NEVER let the weight of the rail rest on the edge of the splinter strip, especially for storage. I also nip the corners of the splinter strip as they are not used since the saw never cuts at the absolute edge.
Edit: I do have a long rail though and very rarely attach them together.
« Last Edit: June 15, 2018, 03:55 PM by Peter_C »
Offline Corwin
« Reply #6 on: June 15, 2018, 04:32 PM »
All of my guide rails are older with the black splinter strips, and I have yet to have any issue with them -- even after a dozen years. Festool really needs to return to the old strip material.
Offline Peter Halle
« Reply #7 on: June 15, 2018, 06:20 PM »
Festool now has an association with 3M on the body shop end.  Perhaps the knowledge base available to them thru probably the largest manufacturer of tape adhesives can solve this issue.  And yes Fstool it is an issue.  Stop worrying about repositioning - rarely does anyone do that.  They just want the strip to stick.
I have resorted to using contact cement to apply my strips.
Offline morts10n
« Reply #8 on: July 25, 2018, 08:01 PM »
Every time I use any of my 4 different sized tracks, the splinter strips are in a different position than in the previous use. Unreliability of exact cut line is the norm. I think I'll need to use a competitors strips in the future, and wait for a redesign here.
Offline pettyconstruction
« Reply #9 on: July 25, 2018, 09:15 PM »
Plus um 10 on makita splinter strips
Charlie
Offline Hammer7896
« Reply #10 on: July 25, 2018, 10:25 PM »
I have two older Festool rails with the black splinter strips and have no problems with them but,I had the same problem with the clear Festool strips so I changed all mine to the Makita strips.
Mike
Offline Gregor
« Reply #11 on: July 26, 2018, 04:32 AM »
As a different data point: I have three 140mm rails with the transparent ones (all ~4 years old), no problems.
Offline NL-mikkla
  • www.m144h.com
« Reply #12 on: July 26, 2018, 06:27 AM »
Same here, but we get to keep the good stuff here in Euro country.
All the inferior stuff is shipped to the US and sold for top dollar :-)
Offline glass1
« Reply #13 on: July 26, 2018, 06:43 AM »
I tape up the ends with metal tape. They are a pain. Only down side to the makita strips is when you need to change them it’s quite a bit of gunk removal.
Offline hdv
« Reply #14 on: July 26, 2018, 07:56 AM »
I have two of them (1400mm), with the transparent strips. Both are about 2 years old. Haven't had any trouble with the strips at all up to now. Let's hope it stays that way.
Offline Gregor
« Reply #15 on: July 26, 2018, 08:01 AM »
I don't see Festool going through the hazzle of creating an additional (especially willfully inferior) product just for the US market.
Which might exactly be the problem: adhesives are usually formulated for the environmental conditions of a certain area, different environmental conditions might lead to the adhesive failing. Or there might be an issue that the rails havn't been cleaned correctly, thus something sticking to the metal keeps the adhesive from bonding (this could be tested though by removing a strip, cleaning the rail with plenty of acetone and applying a fresh one).
The former though might have a problem similar to what is portrayed in this video:
(Equipment not made for a certain region)
« Last Edit: July 26, 2018, 08:04 AM by Gregor »
Offline Peter Halle
« Reply #16 on: July 26, 2018, 09:05 AM »
As a reader of most posts here, honestly I think that for some weird reason the climates in North America just mess with the adhesives.
Now that the majority of the rails offered in North America are being produced in North America there is an opportunity to stylize the offerings here.
Offline Laminator
« Reply #17 on: July 26, 2018, 10:36 PM »
I wonder how much expansion and contraction of the white plastic has to do with this problem?  I have used a strong carpet tape and cleaned the aluminum completely and still have the ends come loose but only on the 118" rail.   It has held up fine on the shorter rails (after the carpet tape that is).
Offline SRSemenza
« Reply #18 on: July 26, 2018, 10:48 PM »
I know this doesn't help but just as a point of interest related to the problem.................
        Many years ago when the Festool strips were the black ones people complained that the strips and adhesive were too hard to remove when replacing the strip.  Yes, I thought so too. It was a real job to get the old adhesive off. Festool responded with the new clear strips and easier to remove adhesive.  Guess we need something in between the two.  [unsure]
« Reply #19 on: July 28, 2018, 05:14 AM »
With them old strips a bit of rubbing alcohol and a razor blade it was super easy to strip of the gunk. To the point it wasn't really a problem. Just shear it off and with some alcohol as a lubricant it just slices off.
I did dry wipe afterwards as the red alcohol based cleaning agent we use over here leaves a very thin film residue it seems but a quick dry wipe and it is gone.
I don't get along with the new strips, so I got Makita and at one point DeWalt black strips, works well.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline Roadster Man
« Reply #20 on: May 22, 2020, 12:58 PM »
Good tip on taping the ends down. The cut strip repeatedly comes loose on both of my tracks, which is very annoying! One trick I use on my no-skid strips for cleaning them when the get dusty is a simple lint roller. Does a great job cleaning the non-skid strips in a minute or two.
Offline Peter_C
« Reply #21 on: May 22, 2020, 04:28 PM »
I have found rounding the ends to work well. Keeps them from catching on things, and the ends are never used for locating.
Offline Birdhunter
« Reply #22 on: May 25, 2020, 01:27 AM »
I read somewhere that the plastic razor blades worked well for removing the adhesive left when replacing the splinter strips. I bought some expecting to replace the strips on one of my rails. Turned out I didn’t have to replace the strip (just pressed it back on). I did use the plastic razors to remove some stubborn blue masking tape On a recent project. They worked great. Got the tape off and didn’t scratch the wood.
Birdhunter
Offline RJNeal
« Reply #23 on: May 25, 2020, 03:47 AM »
I have received brand new rails with the clear strips falling off.
I have been known to use blue masking tape keep the ends on.
Found it a pain(  blue tape)  to clean off upon replacement.
I only replace with the makita black tape now.
Online Bohdan
« Reply #24 on: May 25, 2020, 04:47 AM »
Got sick of the clear strips peeling off at the ends of my rails, unlike the black strips on my older rails which work perfectly.
Peeled the strips off, cleaned any residual glue off with lacquer thinners and stuck the old clear strips back on with Nitto Denko 512 adhesive strip. Normally used to attach plastic badges to cars.
Have done a couple of rails and so far there has been no hint of delamination as the glue really grips. The real test will be when summer returns and the rails are subject to temperatures in excess of 100°F but I don't expect failure as cars are often out in the sun's heat and their badges don't fall off.
The original strips were moved slightly out on the rail to enable a new saw cut to form a new splinter edge.
Offline ultane
« Reply #25 on: May 25, 2020, 12:30 PM »
Source?
Offline ultane
« Reply #26 on: May 25, 2020, 12:30 PM »
Source?
Offline RJNeal
« Reply #27 on: May 25, 2020, 05:11 PM »
Ultane, I picked some up off of amazon.
I buy the 118” ones. That way I can make different sizes. Cheaper that way.
Definitely need to use a lacquer or acetone for cleaning.
« Last Edit: May 25, 2020, 05:14 PM by RJNeal »
Offline Rick Herrick
« Reply #28 on: May 25, 2020, 05:27 PM »
If you mean this one, that price is great.  Less than half of the price I just paid for the FT 118"
Makita 118" splinter guard strip
Offline ultane
« Reply #29 on: May 25, 2020, 07:51 PM »
Thanks RJ and Rick.
