Author Topic: OF2200 with CMS: router height adjustment  (Read 15700 times)
Offline hathi2
« on: April 04, 2010, 12:09 PM »
Dear all,
I just bought the OF2200 router and CMS unit (570251).  Installation went fine, but when I use the height adjuster built into the CMS module to raise the router, it's not possible.  As I screw the height adjuster higher, it puts pressure on the one side of the router and tilts it until it binds.  It seems as though the strength of the springs plus the weight of the router are too much for the one sided screw height adjuster.  I can only raise the router if I use one hand to help it along and turn the handle at the same time.  I can't imagine this being normal; what am I doing wrong?
Thanks for any tips you might have.
Offline ccmviking
    • Blue River Cabinetry Kitchen and Bath
Re: OF2200 with CMS: router height adjustment
« Reply #1 on: April 04, 2010, 08:17 PM »
The plunge springs probably need to be removed for table use.  Makes sense that you'd have too...
Here's Bill doing it on a Triton
http://www.onlinetoolreviews.com/reviews/tritonrouter.htm
Offline windmill man
« Reply #2 on: April 05, 2010, 03:50 AM »
Hi
Had exactly the same problem with mine . After lots of messing about Festool UK had to replace the OF2200.The tech people at Festool Germany decided that the problem was to much play in the tolerance around the plunge columns. So i suggest that you get it back to your dealer and ask them to install it in the CMS and get it working, if they can`t, its up to them to provide a working set up. Before you do that just check one thing, that you have fully disengaged the plunge lock on the handle. Don`t give up, when you get it sorted it is a fantastic bit of kit. Hope this helps.
John
Offline jonny round boy
« Reply #3 on: April 05, 2010, 06:53 AM »
Hi
John
Good suggestion but he's in the US, and thus isn't supposed to have the CMS module. His dealer may not be able to help him, as they will know nothing of the CMS...
PS -John, hope everything's OK with you, you've been very quiet (ie silent!) on here for the last 6 months or so.
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
« Reply #4 on: April 05, 2010, 08:15 AM »
Hi Jonny
Did not realise that the US did not have the CMS modules. Only other things I can suggest for hathi2 is to check are the following
Are you using the correct end of the journal plate for the 2200?
Are you locating it in the correct reference hole?
Have you got the correct set up for the 2200 on the spindle rise and fall head?
Don't lubricate the columns as I found it made it worse.
There is a little bit of play in the reference holes, this play is critical , just a bit off and you get this problem.
Have you removed the base plate?
Are you using the correct locating inserts (the green ring) is it located in the base and table properly?
Is the half moon reference bump located properly(green ring)?
Are you just having trouble raising the router? (Does it lower OK?)
Have you got the 3 clamping elements on the correct position on the base?
Have you got the dust shroud locked and retracted during installation? Have you released it once everything is installed?
Is the dust guard sat properly (clear one that comes in the mounting kit)?
That's all i can think of without going into workshop and demounting and remounting it.
Hope some of this helps.
Thanks for the enquiry Jonny, I am good, I am just run off my feet with work.(I`m doing sketch-up drawings for a customer for tomorrow on Easter Monday that's how busy i am.) I drop into FOG most times I look at my mail. I was thinking of trying my hand at doing a tutorial on the CMS with the 2200/1400/1010 and TS75 but not had the time and i think it would challenge my computer and photographic  skills to breaking point.
Regards John
Offline bellchippy
« Reply #5 on: April 05, 2010, 12:27 PM »
Some pictures of my setup, this work fine, hope it helps.
20939-0
Offline bellchippy
« Reply #6 on: April 05, 2010, 12:30 PM »
And another.
20941-0
Offline gasman
« Reply #7 on: April 05, 2010, 02:47 PM »
Has anyone apart from me had major problems with sawdust getting into the OF220 when inverted in the CMS? Mine has been back to Festol UK under warranty as the auto unlock mechanism for securing router bits stopped working. Turns out this is a 'design fault' according to the engineer at Festool UK and it has since occurred twice more to me. It is cured by removing the dark blue plate on the underside of the router and vaccuuming but that is irritating. He said Festool knew of the problem and were 'working on it'. Ring any bells for folks with a CMS?
« Reply #8 on: April 05, 2010, 03:14 PM »
Hi Gasman,
Know exactly what you you are on about. Saw dust gets into the works via the little grills in the blue plate either side of the rocker spindle of the  auto lock mechanism. when there is enough debris in there it stops the ratchet system working. My solution is to blow it out with compressed air.
John
Offline justinmcf
  • Queensland Builder
« Reply #9 on: April 05, 2010, 06:47 PM »
hi john.
i would love to see a tutorial for the cms on the fog.
i have the cms ts-75, jigsaw and of1400 modules.
i like to think i know how to use them properly, but i am sure i would learn something new if you decided to take a few photos and write a tutorial.
i do like the idea of fitting the wheels to the cms so it can moved easily by one person.
regards, justin.
Offline hathi2
« Reply #10 on: April 10, 2010, 08:56 PM »
Thanks to all who wrote with tips!
I spoke to the great people at Festool here in the US on Monday and they dispatched a replacement router which arrived yesterday.  I installed it in the CMS module today and the lift mechanism is working with this one, so it must have been a shaft tolerance issue.
I learned about the CMS system late last year and was disappointed that it wasn't available in the US, though Shane at Festool has indicated that it's just a matter of time.  Impatient as I am, I ordered the CMS extension to the MFT/3 plus the TS-75 module, the router module and the jigsaw module in Germany and had them shipped to the US.  The effort paid off (clearly for Festool as well); I am really enjoying these great tools.
« Reply #11 on: April 10, 2010, 09:20 PM »
Can you post some pics of the cms setup or using to build some projects?  This is something I am really interested in buying.
Bill
Re: OF2200 with CMS: router height adjustment PICS
« Reply #12 on: April 11, 2010, 12:18 PM »
No Idea if you will get these pics21055-0
« Reply #13 on: April 11, 2010, 08:42 PM »
hathi2 I sent you a PM
Bill
Bonetto's Carpentry
Offline narrowboatboy
    • DJ property maintenance
« Reply #14 on: February 24, 2016, 01:15 PM »
yeah i've had that a few times, blow it out with airgun
Sarcasm: the ability to insult idiots without them realizing it
« Reply #15 on: February 24, 2016, 01:22 PM »
my 2200 has always been a little sticky when raising it in the CMS module, today i put it in CMS and it refused to raise,looking at router when winding lift mechanism i could clearly see it twisting on shafts, oh boy another design failure, well done Festool, I wonder if they will repair for free if it's a design fault?
Offline tjbnwi
« Reply #16 on: February 24, 2016, 08:45 PM »
Once I learned to lock the dust guard in place the problem went away.
Offline tjbnwi
« Reply #17 on: February 24, 2016, 08:48 PM »
Dear all,
Make sure the post lock is completely disengaged.
Mine works very smoothly. Try a few drops of very light weight oil on the post.
Offline GarryMartin
« Reply #18 on: May 19, 2019, 09:56 AM »
Resurrecting this post as I'm suffering from exactly the same problem described by the original poster.
My OF 1400 has always been fine, but not so long ago I bought the OF 2200 for use in the table and have been setting it up today in anger for the first time. I *cannot* raise the height of the bit with the height adjuster, although lowering it is not a problem. As originally noted, the router simply tips and binds.
Do I really have to send the OF 2200 back to Festool under warranty as a potentially faulty unit, or are there other reasons for this sort of behaviour when using the OF 2200 in the CMS OF that I might be able to resolve myself?
(cc @Phil Beckley)
Offline Roachmill
« Reply #19 on: May 19, 2019, 11:04 AM »
There's a slightly different setup in the raising column between the 1400 and 2200. Could that have anything to do with it?
Offline GarryMartin
« Reply #20 on: May 19, 2019, 11:43 AM »
@Roachmill I've definitely set it up correctly and am aware of the changes you need to be aware of for the different routers.
A little more investigation shows that this is a common problem, even with Festool (allegedly) suggesting that you should remove the plunge springs. I found an article on the Internet Archives that's no longer available from Ideal Tool in Australia that shows how to remove the spring and it's much easier to adjust bit height now.
The downside is that you obviously have to put the spring back in if you want to remove the OF 2200 from the table for handheld use.
Crazy that Festool hasn't engineered a solution that works effectively when it sells it as an integrated system.
Offline DynaGlide
« Reply #21 on: May 19, 2019, 01:00 PM »
@GarryMartin Care to share how I can access those no longer available pages? Are you referencing the now gone CMS setup guides?
Instagram @matts.garage
Offline Roachmill
« Reply #22 on: May 19, 2019, 02:05 PM »
@garrymartin That is pretty shocking from Festool especially as a, as far as I'm aware, officially supported option over here. Removing springs sounds like something you really shouldn't need to do!
Offline jobsworth
  • Festool Baby.....
« Reply #23 on: May 19, 2019, 02:09 PM »
I have no issue with mine in the 5 years I used it in the CMS
Offline Vondawg
« Reply #24 on: May 19, 2019, 02:20 PM »
I can’t say here  in the USA   [wink]...but never had a problem with mine either.
Offline rst
« Reply #25 on: May 19, 2019, 05:33 PM »
Ditto on not using my 2200 in the lift but never had a problem with my two CMSs.
Offline GarryMartin
« Reply #26 on: May 19, 2019, 05:37 PM »
Yes. The Internet Archive (or the Way Back Machine as it used to be called) caches old pages for some sites.
https://web.archive.org/web/2017*/http://www.idealtools.com.au/articles/2013/03/20/tips-for-maintaining-cms-router-table-mounted-of-2200/
Offline Sparktrician
« Reply #27 on: May 19, 2019, 06:03 PM »
This is one of the best threads on setting up the OF 2200 and the CMS.   [smile]
- Willy -
Offline GarryMartin
« Reply #28 on: May 19, 2019, 06:29 PM »
Thanks @Sparktrician. I'm confident it's set up correctly and that thread just confirms that. As some people have no issues, I guess we're back to the original observation that some OF 2200 routers have issues and others don't. Plenty of warranty left on my machine, so I'll see how it goes with the spring removed and decide what to do from there.
Of course, if someone from Festool wants to confirm what course of action I should be taking, and whether removing the spring is really the correct approach, that would be awesome...  [poke] @Phil Beckley
« Reply #29 on: May 19, 2019, 06:37 PM »
@GarryMartin, I've never seen a need to remove any plunge springs. Just be sure to NOT lock the plunge mechanism when installing the OF 2200 into the CMS.
- Willy -
