Author Topic: new ro 150 feq does not work  (Read 485 times)
Offline rich sdr
« on: May 31, 2020, 08:08 AM »
I just have a new festool ro 150 feq
In short
Open the box, get the festool out, then i plugged the power cable
Then push button forward and nothing happend.
I checked the cable for power with screw driver and there is power on it
I think the machine is not working but you can not check this (warranty)
Or is there something else
Offline Alex
Re: new ro 150 feq does not work
« Reply #1 on: May 31, 2020, 08:11 AM »
Are you sure you put the cable in properly? With a new cable it can be that you have to twist it in very firmly.
If that's not it, then contact your dealer and get a replacement/repair.
Offline Peter Halle
« Reply #2 on: May 31, 2020, 09:12 AM »
Once you install the cable - which will be tight- push in and turn a full 90 degrees clockwise.  If that doesn’t help contact your dealer and return for a replacement.
Offline bkharman
« Reply #3 on: May 31, 2020, 10:22 AM »
In short
If you can pull the plug it cord out without twisting, it isn’t seated. Like others said, push it in and twist a quarter turn clockwise.
I also am a little curious as to testing power with a screwdriver but let’s tackle that another day.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline Alex
« Reply #4 on: May 31, 2020, 02:01 PM »
Online Cheese
« Reply #5 on: May 31, 2020, 03:25 PM »
I've never seen a screwdriver style circuit tester for anything other than low voltage...from around 3-40 volts.  [tongue]
Offline SteveW
« Reply #6 on: May 31, 2020, 06:30 PM »
That type of testing screwdriver is common in the UK for testing 240V.  Neon and resistor in the handle.
Offline Alex
« Reply #7 on: May 31, 2020, 06:42 PM »
Yep, 240.
